- Function Overview
- Product Bulletin
- Billing
- Getting Started
User Guide
- Clusters
- Workloads
- Network
- Storage
- O&M
- Namespaces
- ConfigMaps and Secrets
- Auto Scaling
- Add-ons
- Helm Chart
- Permissions
- Settings
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- Autopilot Cluster Management
- Add-on Management for Autopilot Clusters
Autopilot Cluster Upgrade
- Upgrading a Cluster
- Performing a Pre-upgrade Check for a Cluster
- Performing a Post-upgrade Check for a Cluster
- Backing Up a Cluster
- Obtaining Details About a Specified Cluster Upgrade Booting Task
- Quota Management for Autopilot Clusters
- Tag Management for Autopilot Clusters
Chart Management for Autopilot Clusters
- Uploading a Chart
- Obtaining a Chart List
- Obtaining a Release List
- Creating a Release
- Updating a Chart
- Deleting a Chart
- Updating a Release
- Obtaining a Chart
- Deleting a Release
- Downloading a Chart
- Obtaining Chart Values
- Kubernetes APIs
- Appendix
- Billing
- Workloads
- Network Management
- Can PVs of the EVS Type in a CCE Autopilot Cluster Be Restored After They Are Deleted or Expire?
- Can CCE Autopilot PVCs Detect Underlying Storage Faults?
- How Can I Delete the Underlying Storage If It Remains After a Dynamically Created PVC is Deleted?
- Permissions
Managing Workload Scaling Policies
You can view an HPA policy, edit an HPA policy on the console, edit an HPA policy using YAML, clone an HPA policy, and delete an HPA policy.
Viewing an HPA Policy
You can view the rules, status, and events of an HPA policy and handle exceptions based on the error information displayed.
- In the navigation pane on the left, choose Policies. On the HPA Policies tab, locate the HPA policy you want to view and click
next to the policy.
- In the expanded area, choose View Events in the Operation column. If the policy malfunctions, locate and rectify the fault based on the error message displayed on the page.
You can also view an HPA policy on the workload details page.
- In the navigation pane on the left, choose Workloads. Click the workload name to view its details.
- On the workload details page, switch to the Policies tab to view the HPA policy. You can also view the policies you configured in Workload Scaling.
Table 1 Event types and names Event Type
Event Name
Normal
SuccessfulRescale
The scaling is performed successfully.
Abnormal
InvalidTargetRange
Invalid target range.
InvalidSelector
Invalid selector.
FailedGetObjectMetric
Objects fail to be obtained.
FailedGetPodsMetric
Pods fail to be obtained.
FailedGetResourceMetric
Resources fail to be obtained.
FailedGetExternalMetric
External metrics fail to be obtained.
InvalidMetricSourceType
Invalid metric source type.
FailedConvertHPA
HPA conversion failed.
FailedGetScale
The scale fails to be obtained.
FailedComputeMetricsReplicas
Failed to calculate metric-defined replicas.
FailedGetScaleWindow
Failed to obtain ScaleWindow.
FailedRescale
Failed to scale the workload.
Editing an HPA Policy on the Console
To edit an HPA policy on the console, take the following steps:
- In the navigation pane on the left, choose Policies. On the HPA Policies tab, locate the HPA policy you want to edit and choose More > Edit in the Operation column.
- On the Edit HPA Policy page, modify the parameter settings based on Table 1.
- Click OK.
Editing an HPA Policy Using YAML
- In the navigation pane on the left, choose Policies. On the HPA Policies tab, locate the HPA policy you want to edit and click Edit YAML in the Operation column.
- In the Edit YAML dialog box displayed, edit or download the YAML file.
Cloning an HPA Policy
Copy the configuration of an existing HPA policy to create a new one, and associate it with a different namespace or workload.
- In the navigation pane on the left, choose Policies. On the HPA Policies tab, locate the HPA policy you want to edit and choose More > Clone in the Operation column.
- On the Create HPA Policy page, set basic policy information by referring to 3.
- Click OK.
Deleting an HPA Policy
- In the navigation pane on the left, choose Policies. On the HPA Policies tab, locate the HPA policy you want to edit and choose More > Delete in the Operation column.
- In the dialog box displayed, click Yes.
