Buying a CCE Autopilot Cluster
A CCE Autopilot cluster runs on Cloud Container Instance (CCI) and provides Kubernetes-native extended APIs, allowing you to run containers without creating or managing servers. You pay only for the resources used by your applications.
- After a cluster is created, the following items cannot be changed:
- Cluster type
- Network configuration of the cluster, such as the VPC, pod subnet, Service CIDR block, and kube-proxy (request forwarding) settings.
- When using a CCE Autopilot cluster, pay attention to the quotas of related resources. The following table lists the resources required by each cluster.
Table 1 Cluster resource usage details Service
Quota Item
Minimum Usage
Minimum Usage
Region Limits
Quota Increase
CCE
Cluster
Maximum number of clusters that can be created by each account in a region: 50
Increase the quota on the My Quotas page.
VPC
VPC
1 per cluster
Select one VPC for each cluster to provide an isolated, private virtual network environment for the cluster.
Maximum number of VPCs that can be created by each account in a region: 5
Subnet
1 per cluster
At least one subnet must be selected for each cluster to allocate container IP addresses.
By default, the cluster control plane occupies eight IP addresses for control plane deployment and interconnection with external services.
Maximum number of subnets that can be created by each account in a region: 50
Security group
2 per cluster
Two security groups are automatically created for each cluster for network access control of the cluster control plane and elastic network interfaces.
Maximum number of security groups that can be created by each account in a region: 100
Security group rules
7 per cluster
Seven security group rules are automatically added for each cluster to allow traffic over specified ports and ensure normal network communication in the cluster.
Maximum number of security groups rules that can be added by each account in a region: 1,000
Endpoint
3 per cluster
Reserve at least three endpoints for each cluster so that the cluster can access peripheral services such as SWR and OBS.
Maximum number of VPC endpoints that can be created by each account in a region: 50
Domain Name Service (DNS)
Private zone
2 per cluster
Each cluster requires at least two private zones for normal communication within the cluster or across clusters.
Maximum number of private zones that can be created by each account in a region: 50
Record set
6 per cluster
Each cluster requires at least six DNS record sets for mapping specified domain names to IP addresses or other domain names in the cluster.
Maximum number of record sets that can be added by each account in a region: 500
Step 1: Log In to the CCE Console
- Log in to the CCE console.
- On the Clusters page, click Buy Cluster in the upper right corner.
Step 2: Configure the Cluster
On the Buy Cluster page, configure the parameters.
Basic Settings
Parameter |
Example Value |
Description |
Type |
CCE Autopilot Cluster |
CCE allows you to create various types of clusters for diverse needs.
For more information about cluster types, see Cluster Comparison. |
Cluster Name |
autopilot-example |
Enter a cluster name. Cluster names in the same account must be unique. Enter 4 to 128 characters. Start with a lowercase letter and do not end with a hyphen (-). Only lowercase letters, digits, and hyphens (-) are allowed. |
Enterprise Project |
default |
This parameter is only available for enterprise users who have enabled an enterprise project. After you select an enterprise project (for example, default), the cluster and resources in the cluster are created in the selected enterprise project. To manage clusters and other resources like nodes, load balancers, and node security groups, you can use the Enterprise Project Management Service (EPS). For more information, see Enterprise Management. If there is no special requirement, you can select default. |
Cluster Version |
v1.31 |
Select the Kubernetes version used by the cluster. You are advised to select the latest version. |
Network Settings
Parameter |
Example Value |
Description |
VPC |
vpc-autopilot |
Select a VPC where the cluster will be running. If no VPC is available, click Create VPC on the right to create one. For details, see Creating a VPC and Subnet. The VPC cannot be changed after the cluster is created. |
Pod Subnet |
subnet-502f |
Select the subnet where the pods will be running. Each pod requires a unique IP address. The number of IP addresses in a subnet determines the maximum number of pods in a cluster and the maximum number of containers. After the cluster is created, you can add subnets. If no subnet is available, click Create Subnet on the right to create one. For details, see Creating a VPC and Subnet. |
Service CIDR Block |
10.247.0.0/16 |
Select a Service CIDR block, which will be used by containers in the cluster to access each other. This CIDR block determines the maximum number of Services. After the cluster is created, the Service CIDR block cannot be changed. |
Image Access |
To ensure that the nodes in a cluster can pull images from SoftWare Repository for Container (SWR), existing endpoints in the selected VPC are used by default. If there are no endpoints in the VPC, new endpoints will be created for you to access SWR and OBS. VPC endpoints are billed. For details, see VPC Endpoint Price Calculator. |
SNAT |
Enabled |
This option is enabled by default, and the cluster can access the Internet through a NAT gateway. By default, an existing NAT gateway in the selected VPC is used. If there are no NAT gateways, CCE Autopilot automatically creates a NAT gateway with default specifications, binds an EIP to the NAT gateway, and configures SNAT rules. The NAT gateway will be billed. For details, see NAT Gateway Billing. |
(Optional) Advanced Settings
Parameter |
Example Value |
Description |
Alarm Center |
Disabled |
Alarm Center provides comprehensive cluster alarm capabilities so that alarms can be generated in a timely manner when faults occur during cluster running, ensuring service stability. If this option is enabled, the default alarm rules will be created, and notifications will be sent to the selected contact group. For details, see Configuring Alarms in Alarm Center. |
Resource Tag |
You can add resource tags to classify resources. You can create predefined tags on the Tag Management Service (TMS) console. The predefined tags are available to all resources that support tags. You can use predefined tags to improve the tag creation and resource migration efficiency. For details, see Creating Predefined Tags.
Description |
Enter a maximum of 200 characters except the following: ^~#$%&*<>()[]{}"'\. |
Step 3: Select Add-ons
Click Next: Select Add-on. On the displayed page, select the add-ons to be installed. For details about the parameters, see Figure 4, Table 5, and Table 6.
Add-on |
Example Value |
Description |
CoreDNS |
This add-on (CoreDNS) is installed by default. It provides DNS resolution for your cluster and can be used to access the cloud DNS servers. |
Add-on |
Example Value |
Description |
Kubernetes Metrics Server |
This add-on is installed by default. It collects resource usage metrics, such as the container CPU and memory usages, for the cluster. |
Cloud Native Cluster Monitoring |
Select this add-on. |
This is an optional add-on. If selected, this add-on (Cloud Native Cluster Monitoring) will be automatically installed. It collects monitoring metrics for your cluster and reports the metrics to Application Operations Management (AOM). The agent mode does not support HPA based on custom Prometheus statements. If related functions are required, install this add-on manually after the cluster is created. If this add-on is selected, pod billing is involved. You can view the prices on the console. |
Cloud Native Log Collection |
This is an optional add-on. If selected, this add-on (Cloud Native Log Collection) will be automatically installed. Cloud Native Log Collection helps report logs to LTS. After the cluster is created, you are allowed to obtain and manage collection rules on the Logging page of the CCE cluster console. LTS does not charge you for creating log groups and offers a free quota for log collection every month. You pay only for log volume that exceeds the quota. For details, see Price Calculator. For details, see Collecting Logs. If this add-on is selected, pod billing is involved. You can view the prices on the console. |
Step 4: Configure Add-ons
Click Next: Configure Add-on to configure the add-ons. For details about the parameters, see Figure 5 and Table 7. The add-ons that are installed by default cannot be configured. After the cluster is created, you can go to the Add-ons page to modify their settings.
Add-on |
Example Value |
Description |
test |
Select an AOM instance for the add-on to report metrics. If no AOM instance is available, create one first. Basic metrics are free, but custom metrics are billed based on the standard pricing of AOM. For details, see AOM Pricing Details. |
Select Container log and Kubernetes events. |
Select the logs to be collected. If enabled, a log group named k8s-log-{clusterId} will be automatically created, and a log stream will be created for each selected log type.
If log collection is disabled, choose Logging in the navigation pane of the cluster console after the cluster is created and enable this option. LTS does not charge you for creating log groups and offers a free quota for log collection every month. You pay only for log volume that exceeds the quota. For details, see Price Calculator. For details, see Collecting Logs. |
Step 5: Confirm the Configuration
Click Next: Confirm configuration. The cluster resource list is displayed. Confirm the information and click Submit.
It takes about 5 to 10 minutes to create a cluster. You can click Back to Cluster List to perform other operations or click Go to Cluster Events to view the cluster details.
Related Operations
- After creating a cluster, you can use the Kubernetes command line (CLI) tool kubectl to connect to the cluster. For details, see Connecting to a Cluster Using kubectl.
- Connect to multiple clusters using kubectl. For details, see Connecting to Multiple Clusters Using kubectl.
