Creating File Backups
This section describes how to manually create file backups.
To implement automatic backup, create a policy and apply it to a vault by referring to Creating a Backup Policy. Then, CBR will automatically perform backups at the time points specified in the policy.
Only backup clients whose Agent status is Normal can be backed up.
- Log in to the CBR console.
- Click
in the upper left corner and select a region. - Choose Storage > Cloud Backup and Recovery > File Backups.
- Click the Backup Clients tab and locate the target backup client.
- Click Perform Backup in the Operation column. CBR automatically creates backups for the files.
- On the Backup Clients tab, click the name of the target backup client. In the Backup Details area of the displayed page, if the statuses of all generated backups are Available, the backup is successful.
If you delete data from the files during the backup, the deleted files may fail to be backed up. To ensure data integrity, delete the data after the backup is complete, and then perform the backup.
After the backup task is complete, you can restore file data by referring to Restoring from a File Backup as needed.
