Updated on 2026-11-26 GMT+08:00
Restoring from a File Backup
You can use a file backup to restore individual files of a server to their state when the backup was created.
  • The Agent on the server must be Normal.
  • You are advised not to restore file backups when applications are running. Stop the applications and then restore files.
Method 1
  1. Log in to the CBR console.
    2. Click in the upper left corner and select a region.
    3. Choose Storage > Cloud Backup and Recovery > File Backups.
  2. On the File Backups tab, click the resource name of the target file.
  3. In the row of the backup, click Restore.
    Figure 1 Restoring files
  4. Select where you want to restore the backup to:
    • Source location: Data will be restored to the original file path, and any file with the same name will be overwritten. This option is available only for Linux backup clients.
    • New location: Data will be restored to a path on another server you select.
      You can only choose the backup clients whose Agent status is Normal. If your target server is not on the list, install the Agent on the server and try again.
      The storage path cannot contain spaces.
  5. Click OK. You can check whether data is successfully restored in the Backup Details area of the client details page or on the local host.
    When the backup status changes to Available, the restoration is successful.
Method 2
  2. On the Backup Clients tab, locate the name of the target backup client.
  3. Click Restore Points in the Operation column.
  4. Select a checkpoint and click Restore Data.
    Backup data will be restored to the state at the selected time.
    Figure 2 Checkpoints
  5. Select a restore location.
  6. Click OK. You can check whether data is successfully restored in the Backup Details area of the client details page or on the local host.
