Adding Directories
After the Agent is installed on target servers, CBR will automatically detect and show the servers as backup clients in the backup client list (Cloud Backup and Recovery > File Backups > Backup Clients). You need to add the paths of the files and directories you want to back up.
- A backup client can have a maximum of 100 directories added.
- A single directory can contain a maximum of 500,000 files. You are advised to reserve at least 4 GB of memory on each backup client to perform file backups.
- A path must be an absolute path, for example, a path starting with /, C:\, or D:\.
- Windows root folders such as C:\ and D:\ cannot be backed up.
- Log in to the CBR console.
- Click in the upper left corner and select a region.
- Click
and choose Storage > Cloud Backup and Recovery > File Backups.
- Locate the target backup client and click its name to go to the details page.
- Click Add Backup Directory. Figure 1 Add Backup Directory
- Paste the paths to the text box and click OK.
- The file paths will be displayed in the lower part of the page.
Removing Directories
If backup is no longer required for a directory or the maximum number of directories allowed has been reached, you can remove directories.
- Choose Storage > Cloud Backup and Recovery > File Backups.
- Locate the target directory and click Remove Directory. After a directory is removed, files in this directory cannot be backed up. Backups already generated will not be deleted and can be used to restore data. A directory with no backups generated will be removed permanently.Figure 2 Remove Directory
- Click Yes.
