Updated on 2026-01-22 GMT+08:00
Purchasing a Hybrid Cloud Backup Vault
This section describes how to purchase a hybrid cloud backup vault for storing file backups.
  1. Log in to the CBR console.
    2. Click in the upper left corner and select a region.
    3. Click and choose Storage > Cloud Backup and Recovery > File Backups.
  2. In the upper right corner of the page, click Buy Hybrid Cloud Backup Vault.
  3. Select a billing mode.
    • Yearly/Monthly is a prepaid billing mode. You are billed based on the subscription duration you specify. This mode is ideal when the resource use duration is predictable. A longer subscription often means a lower cost.
    • Pay-per-use is a postpaid billing mode. You are billed based on your resource usage and you can add or delete resources anytime.
  4. Specify a vault capacity ranging from 1 to 10,240 TB.
    Properly plan the vault capacity, which must be at least as large as the files you want to back up. Check the file size on your local hosts. As the vault's used space grows, you can expand the vault capacity if it becomes insufficient.
  5. Configure auto backup.
    • If you select Configure, you must then select an existing backup policy or create a new policy. After the vault is created, CBR will apply the policy to this vault, and all files associated with this vault will be automatically backed up based on this policy.
    • If you select Skip, files associated with this vault will not be automatically backed up until you apply a backup policy to the vault.
  6. (Optional) Add tags to the vault.
    Tags are key-value pairs, which are used to identify, classify, and search for vaults. You can add a maximum of 10 tags for a vault, and vault tags are only used to filter and manage vaults.
    Table 1 describes the parameters of a tag.
    Table 1 Tag parameter description
    Example Value
    Key
    Each tag has a unique key. You can customize a key or select the key of an existing tag created in TMS.
    A tag key:
    • Can contain 1 to 36 Unicode characters.
    • Can contain only letters, digits, hyphens (-), and underscores (_).
    Key_0001
    Value
    A tag value can be repetitive or left blank.
    A tag value:
    • Can contain 0 to 43 Unicode characters.
    Value_0001
  7. Specify a name for the vault.
    The name must contain 1 to 64 characters including digits, letters, underscores (_), or hyphens (-), for example, vault-f61e.
    You can also use the default name vault_xxxx.
  8. Specify the required duration if you select yearly/monthly billing. The validity period ranges from 1 month to 5 years.
    Determine whether to enable auto renewal. If you select Auto-renew:
    • Your monthly subscription will be renewed each month.
    • Your yearly subscription will be renewed each year.
  9. Complete the payment as prompted.
  10. Go back to the File Backups page and view the created vault in the vault list.
