File Backup Process
Figure 1 shows the file backup process.
- Create a hybrid cloud backup vault.
Before installing the file backup Agent, create a vault. It will be used to store file backups.
- Download and install the Agent.
Install the Agent on target servers. After the Agent is successfully installed, the servers automatically appear as backup clients in the backup client list.
- Configure the vault for the backup clients.
Configure the vault for the backup clients. Generated file backups will be stored in this vault.
- Add files and directories.
- Create file backups.
Manually perform backups or have the system automatically create backups. Generated backups will be stored in the vault.
- Restore data from file backups.
Restore data by referring to Restoring from a File Backup. You can restore data to source servers or different servers.
