Updated on 2025-11-13 GMT+08:00
URL Monitoring
After URL log monitoring is enabled, CAE reports URL routing logs to LTS. You can monitor URL logs of application components using LTS.
  • Only environments created after July 30, 2025 support this function.
  • Reporting logs to LTS and using the LTS log management function will incur extra fees. For details, see LTS Pricing Details.
If you need to use a custom log group and log stream to monitor URL logs, create a log group and log stream on the LTS console in advance. For details, see Managing Log Groups and Managing Log Streams.
Enabling URL Log Monitoring
  1. Log in to CAE.
  2. Choose URL Monitoring.
  3. Click to enable URL log monitoring.
  4. Configure the parameters based on Table 1.
    Table 1 Parameter descriptions
    Auto
    CAE automatically creates a log group and log stream.
    Custom
    • Log Group: Select the log group you have created on the LTS console from the drop-down list. For details about how to create a log group, see Managing Log Groups.
    • Log Stream: Select the log stream you have created on the LTS console from the drop-down list. For details about how to create a log stream, see Managing Log Streams.
  5. Click OK. The URL monitoring is configured.
  6. After the configuration is complete, you can click View log-based monitoring to go to the log stream page of the LTS console and view and manage URL logs of application components.
