Editing an AS Policy
This section describes how to edit an AS policy.
- Log in to CAE.
- Choose Component Configurations.
- Select the target component from the component drop-down list in the upper part of the page.
- Click Edit in the AS Policies module.
- Update configuration parameters.
- Configure a metric AS policy
- Select Metric.
- Reconfigure the metric AS policy by referring to the following table.
Table 1 Parameters Parameter
Max. Instances
Max. number of instances that can be reached during scale-out.
Value range: 1 to 99.
NOTE:Max. Instances cannot be less than Min Instances.
Min Instances
Min number of instances that can be reached during scale-in.
Value range: 0 to 99
Metric
- CPU usage, a preset metric in the system
- Memory usage, a preset metric in the system
- Custom metrics.
Click Add Expected Value and select a custom metric from the drop-down list to add a custom metric. For details about how to create a custom metric, see Configuring Custom Metrics.
You can add multiple custom metrics.
NOTE:- You must enter a PromQL statement. PromQL is a built-in data query language from Prometheus, and is used to select, aggregate, and perform logical calculation on time series data. For details, see Prometheus.
- The query result of the PromQL statement must be a single value of the vector or scalar type.
- Upgrade the component created/upgraded before November 3, 2023 for the custom scaling policy to take effect.
Figure 1 Configure a metric AS policy - (Optional) Expand Advanced Settings and configure advanced settings by referring to Table 2.
Table 2 Configuring advanced settings Parameter
Scale-out Step
Number of pods to be added per minute.
Value range: 1 to 99. Default value: 4.
Stable Scale-out Window (s)
Value range: 1 to 3600, in seconds. Default value: 0.
Scale-in Step
Number of pods to be reduced per minute.
Value range: 1 to 99. Default value: 99.
Stable Scale-in Window (s)
Value range: 1 to 3600, in seconds. Default value: 300.
Disable Scale-in
Click
to disable scale-in.
- Configure a time AS policy
- Select Time.
- Reconfigure the time AS policy by referring to the following table.
Table 3 Parameters Parameter
Max. Instances
NOTE:Max. Instances must be greater than Min Instances.
Min Instances
Trigger Cycle
The policy is expected to be executed at a specified interval. Value: Every day, Every day, or Monthly.
Trigger Time in a Day
This parameter is mandatory when Trigger Cycle is set to Every day.
Configure the policy triggered every day.
For example, the number of instances remains 5 after 11:00 every day.
Click Add Trigger Time to add more time policies.
Trigger Time in a Week
This parameter is mandatory when Trigger Cycle is set to Every week.
Configure the policy triggered every week.
For example, the number of instances remains 2 after 08:00 on every Monday.
Trigger Time in a Month
This parameter is mandatory when Trigger Cycle is set to Monthly.
Configure the policy triggered every month.
For example, the number of instances remains 3 after 06:00 on the fifth day of each month.
Figure 2 Configuring a time policy
- Configure a hybrid AS policy
- Select Hybrid.
- Reconfigure the hybrid AS policy by referring to the following table.
Table 4 Configuring a hybrid policy Parameter
Max. Instances
Min Instances
Metric
- Custom metrics.
Trigger Cycle
For example, the number of instances remains 3 after 18:00 every day.
For example, the number of instances remains 4 after 08:00 on every Monday.
For example, the number of instances remains 4 after 06:00 on the fifth day of each month.
- (Optional) Expand Advanced Settings and configure advanced settings by referring to Table 5.
Table 5 Configuring advanced settings Parameter
Scale-out Step
Scale-in Step
Disable Scale-in
Click
Figure 3 Advanced settings
- Click OK.
- Click Activate Settings in the upper part of the page. In the dialog box displayed on the right, confirm the configurations and click OK for the configurations to take effect.
