Updated on 2025-12-30 GMT+08:00
Configuring a Certificate
You can bind up to 10 certificates.
Adding a Certificate
  1. Log in to CAE.
  2. Choose System Settings.
  3. Click Edit in the Certificates module.
  4. Click Add Certificate.
  5. Enter a certificate name For example, test-1.
  6. Upload Server Certificate Content and Server Private Key Content.
  7. Click OK.
Editing a Certificate
  1. Log in to CAE.
  4. Select the target certificate and click Edit in the Operation column.
  5. Edit Server Certificate Content and Server Private Key Content.
    Figure 1 Editing a certificate
  6. Click OK.
Deleting a Certificate
  1. Log in to CAE.
  4. Select the target certificate and click Delete in the Operation column.
  5. If Deleted is displayed, the certificate is deleted.
    If Failed to unbind xx is displayed when you delete a certificate, choose Component Configurations > Access Mode > Forwarding Policy to check whether the certificate is in use.
