Updated on 2025-08-12 GMT+08:00
Submitting a Dedicated Personnel Application
Verify the qualifications of members and submit dedicated personnel applications for the members who meet the requirements of the corresponding development path (Service Partner Development Path, System Integrator Development Path, or Learning Partner Development Path).
  • Confirm the specific requirements of each development path for dedicated personnel with Huawei in advance.
  • Dedicated personnel application is not available for Distribution Partner Program and Cloud Solution Provider Program.
  1. The members have associated their HUAWEI IDs with the partner account, and no dedicated personnel applications have been submitted for them. (The dedicated personnel application can be submitted again for those who have just been disqualified as dedicated personnel.)
  2. The Base Location field in the personal information of the members has been specified.
  1. Use your account to sign in to Huawei Cloud.
  2. Click Partner Center in the drop-down list of your account name in the upper right corner.
  3. Choose Organization > Dedicated Personnel in the menu on the top.
  4. Select a member in the Associated state on the Invited Members tab page and click More > Submit Dedicated Personnel Application in the Operation column.
    • You can submit a dedicated personnel application again for those members in the Dedicated personnel rejected, Disqualification approved, and Disqualified by Huawei statuses.
    • You can select multiple members at a time and submit dedicated personnel applications for them in a batch.
  5. Specify the information of the member you invite to become a dedicated personnel, including the name and the development path or partner program the member has joined, and upload the required materials.
    • Select members who have already associated their HUAWEI IDs with your account, whom you disqualified as a dedicated personnel, or who have been disqualified by Huawei as a dedicated personnel.
    • Confirm with Huawei about the materials required for the application to become a dedicated personnel.
  6. Click OK.
  7. Check the review status of the dedicated personnel application.
    • You can check the review progress of an application by status in the Invited Members tab, or click View Details in the Operation column to view the application information and review progress on the details page.
      If you need to modify the submitted application information or materials, cancel the application, modify it, and submit it again.
    • If the application is rejected, modify the application based on the given rejection reason and submit it again.
    • You can find the member on the Dedicated Personnel tab page after the application is approved.
Table 1 Status description
Status
Normal
The dedicated personnel application is approved, and the member is in the normal state.
Disqualification under review
The application you or Huawei submitted for disqualifying a dedicated personnel is under review.
Disqualification rejected
The application you or Huawei submitted for disqualifying a dedicated personnel has been rejected.
Disqualification (by Huawei) under review
The application Huawei submitted for disqualifying a dedicated personnel is under review.
