Viewing a Customer's Resources
A partner can view each associated customer's pay-per-use or yearly/monthly resources, reserved instances, and savings plans.
- Sign in to Huawei Cloud as a partner.
- In the drop-down list of your account name, click Partner Center to go to the Partner Center.
- In the top navigation, select Sales > Customers > Customer Management.
- On the Customer Management page, set the search criteria for a fuzzy search. Select a target customer and choose More > View Resource to enter the resource management page.
For distributors, their own customers and customers of their resellers are separated into the Customers and Resellers' Customers tabs. To view customer resources, a distributor needs to go to the corresponding tab.
- View the resources purchased by customers.
- View yearly/monthly resources.
On the Yearly/Monthly Resources page, set the search criteria and query the desired yearly/monthly resource records.
- Click Export to export all yearly/monthly resource records of a customer.
- Click
to check instance information and resource status. - Click
to check associated resources.
- View pay-per-use resources.
On the Pay-per-use Resources page, set the search criteria and query the desired pay-per-use resource records.
Click Export to export all pay-per-use resource records of a customer.
- View the reserved instances.
On the Reserved Instance page, set the search criteria and query the desired reserved instance records.
- View savings plans.
On the Savings Plans tab, set search options to query target savings plans.
