Mailing Invoice
Partners must issue invoices based on the invoicing information and mail them to Huawei after their reimbursement applications are approved.
- Use your account to log in to Huawei Cloud.
- Click Partner Center in the drop-down list of your account name in the upper right corner.
- Choose Benefits > Market Development Fund (MDF) in the menu on the top.
- Select the Application History tab, select an activity in the MDF reimbursement approved state, and click View Invoicing Information in the Operation column.
- On the displayed page, check the supplier information and invoice amount, and click Print.
Manually fill in the invoice number on the printed file.
Note: The invoice number can be found on the invoice you issued.
- Mail the invoicing information form and the invoice to Huawei.
