Help Center/ Partner Center/ User Guide/ Partner Build Management/ Baseline Solutions/ Requesting Joint Design and Verification
Updated on 2025-12-12 GMT+08:00
After submitting a joint project initiation application in Partner Center, you can apply for joint solution design and verification in InnoStage Workbench.
  1. On the Baseline Solutions page, find the solution which a project initiation application has already been submitted for and click Request Joint Design and Verification in the Operation column.
  2. Design and verify the solution on InnoStage Workbench.
    You can contact Huawei Partner Solution Architect (PSA) to help you complete the solution design and verification.
    For details about the procedure, see Partner-led Solution Tests on InnoStage Workbench.
  3. You can also follow the solution progress on Partner Center when performing joint solution design and verification on InnoStage Workbench.
  4. After the joint design and verification are complete, you can download the test report on the solution details page or go to InnoStage Workbench to check the solution design and verification details.
    During joint design and verification, you can create a joint sales offering and develop a configurator at the same time.
