Viewing a Customer's Resources
Distributors can view pay-per-use or yearly/monthly resources, reserved instances, and savings plans of its customers and customers associated with their resellers.
- Access the Customer Management page.
a) Log in to Huawei Cloud as a distributor.
b) Click Partner Center in the drop-down list of your account name in the upper right corner.
c) In the top navigation bar, select Sales > Customers > Customer Management.
- Click the Customers or Resellers' Customers tab as required.
- Locate the target customer and click More > View Resources in the Operation column. The resource management page is displayed.
You can search for customers by whether the account is automatically frozen, association type, association time, customer name, customer account, customer ID, account manager name, month-to-date expenditure, resource expiration date, mobile number, budget usage, or customer tag.
- View the resources purchased by customers.
- View yearly/monthly resources.
On the Yearly/Monthly Resources page, set the search criteria and query the desired yearly/monthly resource records.
- View pay-per-use resources.
On the Pay-per-use Resources page, set the search criteria and query the desired pay-per-use resource records.
Pay-per-use resources of the last month are displayed by default. You can filter the resources of specified time range in the subscription time area.
- View the reserved instances.
On the Reserved Instance page, set the search criteria and query the desired reserved instance records.
- View savings plans.
On the Savings Plans tab, set search options to query target savings plans.
