Creating a Trigger
You can design triggers to meet specific needs, allowing the system to automatically execute tasks as intended, thus achieving the desired outcomes. For example, you can create a trigger based on the Employee__CST object. When a record with name set to zhangsan is created or updated in the system, the system sends a notification email to zhangsan@qq.com.
Creating a Trigger
- Log in to the application designer by referring to Logging In to the Application Designer.
- In the navigation pane, click Logic.
- (Optional) Click
next to Trigger to add a folder.By default, triggers are stored in the root folder. Before creating an event, you can create a folder for storing the trigger. You can drag the trigger to a specified folder.
- Move the cursor to the created trigger folder and click
. The page for adding a trigger is displayed.If no trigger folder is created, click
next to Trigger. The page for adding a trigger is displayed. - Set the trigger object, label, name, and trigger type, and click Add. The trigger editing page is displayed.Figure 1 Creating a trigger
- Click Add Criteria, set conditions, and click Save.Figure 2 Creating a rule
- Criteria Name: name of the new rule.
- Execution Condition: condition for entering the rule. For example, set this parameter to When conditions are met.
- Set Condition: Set the field to name, operator to Equal, type to Constant Value, and value to zhangsan.
- Click Add Action, set the action to be executed after the rule conditions are met, and click Save.Figure 3 Creating an action
- Action Type: Specify the action type, for example, Email Alerts.
- Action Name: Enter the name of the action to be created.
- Email Alert: Select the configured email alarm.
- Click
in the upper part of the trigger editing page to activate the trigger. - Verify the configuration.
Create a record based on the Employee__CST object. Set the name field of the object to zhangsan. If the user whose email address is zhangsan@qq.com receives the notification email, the trigger is created successfully.
Who determines the permission to perform actions set by a trigger: the trigger creator or the trigger user?
Answer: Permission to execute trigger actions depends on the user's own permissions, not the trigger creator. For example, a trigger is associated with the object D__CST, the trigger type is On record insert or update, and the event C is executed when the trigger is triggered. That is, when data of the object D__CST is added or updated, the trigger is triggered, to execute the event C. User A is the trigger creator and does not have the permission to operate object D__CST or execute event C. User B has the permission to operate object D__CST and execute event C. When user B updates the data of object D__CST, the trigger is triggered to execute event C.
