Managing Advanced Pages
Setting Watermarks for Advanced Pages
You can add watermarks to mark ownership, status, and details on advanced pages. Keep it minimal for a clean look.
- Log in to the application designer by referring to Logging In to the Application Designer.
- In the navigation pane, choose Page.
- Move the cursor to
of the corresponding advanced page, and choose Settings.
- On the Watermarks tab page, set parameters by referring to Table 1 and click Save.
Figure 1 WatermarkingFigure 2 Effect
Table 1 Parameters for adding a watermark Parameter
Watermark
Whether to enable the watermark function for the page.
Re-render
Enable this function when you need to set a full-page watermark.
Content
Sets the watermark content.
Length
Length of the watermark rectangle.
Width
Width of the watermark rectangle.
Position of X Axis
Horizontal start position of a single watermark on the page. This parameter can be set only when Re-render is disabled.
Position of Y Axis
Vertical start position of a single watermark on the page. This parameter can be set only when Re-render is disabled.
Color
Watermark font color.
Size
Watermark font size.
Rotation Angle
Watermark rotation angle. The value ranges from -180 to 180, indicating that the watermark is rotated 180 degrees counterclockwise or clockwise.
Opacity
Transparency of the watermark.
Setting Basic Information About Advanced Pages
You can modify the basic information, such as name, path name, and title of advanced pages.
- On the Basic Settings tab page, modify parameters and click Save.
Table 2 Parameters for setting basic information on an advanced page Parameter
Name
Advanced page name, that is, the name set when the advanced page is created. You can change the name as required. The naming requirements are as follows:
- Value: 1–100 characters.
- Start with a letter and can contain letters, digits, and underscores (_). Consecutive underscore (_) is not allowed.
URL Name
The path name should match the advanced page name and can be modified. The naming requirements are as follows:
Title
Advanced page title, that is, the label set when the advanced page is created. You can change the name as required.
Description of the advanced page.
Keywords
This parameter is used to interact with APIs.
Stretch
Select this parameter to expand the advanced page width to 100%, ensuring full browser or device visibility. The widget content width will automatically adjust to fit the container. This parameter is deselected by default.
Zoom & Move
Indicates whether a widget can be zoomed in or out or dragged on a released advanced page.
Customizable
Indicates whether the advanced page can be imported from the dependent application in the add-on application.
Browser Cache Expiry (Day)
Interval for refreshing the browser cache, in days.
Publishing an Advanced Page As a Template
After an advanced page is developed, you can publish the page as a template. After the advanced page is released as a template, the developer himself, developers of Huawei ID registered with Huawei Cloud Astro Zero, and other Huawei Cloud Astro Zero developers under the HUAWEI ID can directly use the template to create advanced pages.
- Click the corresponding advanced page. The advanced page design page is displayed.
- Click
. The page for publishing a page template is displayed.
- Enter a name and description.
Figure 3 Publishing as a page template
Table 3 Parameters for publishing a page template Parameter
Name
Name of the template to be published.
The value can contain letters, digits, underscores (_), and hyphens (-).
Description of the template.
Value: 1–255 characters.
- Click Publish.
After an advanced page is published as a template, you can create a page based on this template and manage this page template.
- Create an advanced page based on the advanced page template.
- Preview or delete an advanced page template.
On the Huawei Cloud Astro Zero environment configuration page, choose Maintenance > Global Elements > Page Assets > Page Templates to preview or delete templates. For details, see Managing Page Templates.
Cloning an Advanced Page
You can clone an advanced page to an application. For example, if application A contains advanced pages with similar functions, you can clone one advanced page to make a new one. This allows you to edit the clone without starting the creation process over.
of the corresponding advanced page, and choose Clone.
- Complete the configuration and click Confirm.
After the clone is successful, the cloned advanced page is displayed.
Deleting an Advanced Page
If an advanced page in an application is no longer used, you can delete it from the application to prevent it from occupying the resource quota of the account.
of the corresponding advanced page, and choose Delete.
- In the displayed dialog box, click Confirm. Then the advanced page is deleted.
Managing Page-level Data Sources and Global state
Managing individual interactions between many page widgets can be complex. To simplify this, use a global state that automatically updates data across all widgets on the page.
Advanced pages feature a global state that simplifies data sharing among widgets. This centralized system ensures consistent state changes and follows predefined rules. The global state acts as a shared data pool accessible to all widgets, regardless of their position, while maintaining data integrity and security. To update the global state, use the this.$mstore.dispatch method in any widget's JavaScript file.
When to use global state: If page widgets are simple and do not need to frequently share information, a global state is not necessary. However, if frequent data exchange is needed, using the global state is recommended. It helps manage shared state across all widgets on the page.
- Click the corresponding page to go to the advanced page development page.
- In the upper right corner of the page, click
to define the global state.
Use JavaScript to define the global state. TypeScript is not supported. MStore is the name of the global state structure. With one global state instance per page, it enables easy retrieval of the current state snapshot for widget debugging. The global state structure consists of the following parts:
- state: Sets the initial data for all page widgets, serving as the starting point for the shared state.
- mutations: The only way to change the state is by committing a mutation. Each mutation must be defined to map state changes to views. Mutations are synchronous and receive the entire object as a payload.
- actions: Handle state data changes, linking state with mutation. Actions can include asynchronous operations and are typically used for status binding, widget interaction, and service calling.
- In the JavaScript file of a page widget, use the preset this.$mstore.dispatch () method to modify the status data.
