Updated on 2025-03-24 GMT+08:00
Accessing a Project
You can access the first page of a published project version.
Accessing a Project
- Log in to Huawei Cloud Astro Canvas by referring to Logging In to Huawei Cloud Astro Canvas.
- On the Projects page, click
of the target project. - In the Release Project dialog box, click
next to the version to set it as the version to publish.
For details about how to create and publish a project version, see Publishing and Installing a Project.
Figure 1 Publishing a version
- Set the project access restriction.
- Limited by project: Once a page in a project is verified, there is no need to verify the other pages. For example, token authentication is configured for pages A, B, and C, and share codes are configured for pages D, E, and F. If you select this function, pages B and C will not be verified after the token of page A is verified, and pages E and F will not be verified after the share code of page D is verified.
- Limited by page: The project should comply with the access restrictions of each page.
- Return to the project list, move the cursor to the corresponding project, and click
to preview the page of the published project version.
Parent topic: Managing Projects
