- What's New
- Product Bulletin
- Billing
- Getting Started
User Guide
- Application Service Mesh
- Buying a Service Mesh
- Mesh Management
- Service Management
- Gateway Management
- Grayscale Release
- Mesh Configuration
- Traffic Management
- Security
Best Practices
- Upgrading Data Plane Sidecars Without Service Interruption
- Service Governance for Dubbo-based Applications
- Reserving Source IP Address for Gateway Access
- Creating a Service Mesh with IPv4/IPv6 Dual Stack Enabled
- How Do I Query Application Metrics in AOM?
- Reducing the Agency Permissions of ASM Users
- Istio-ingressgateway HA Configuration
- Service Mesh Cluster
Mesh Management
- Why Cannot I Create a Mesh for My Cluster?
- Why Are Exclusive Nodes Still Exist After Istio Is Uninstalled?
- How Do I Upgrade ICAgent?
- How Do I Enable Namespace Injection for a Cluster?
- How Do I Disable Sidecar Injection for Workloads?
- What Can I Do If A Pod Cannot Be Started Due to Unready Sidecar
- How Do I Handle a Canary Upgrade Failure?
Adding a Service
- What Do I Do If an Added Gateway Does Not Take Effect?
- Why Does It Take a Long Time to Start the Demo Application in Experiencing Service Mesh in One Click?
- Why Cannot I Access the page of the Demo Application After It Is Successfully Deployed?
- Why Cannot I Select the Corresponding Service When Adding a Route?
- How Do I Inject a Sidecar for the Pod Created Using a Job or CronJob?
- Performing Grayscale Release
Managing Traffic
- Why Are the Created Clusters, Namespaces, and Applications Not Displayed on the Traffic Management Page?
- How Do I Change the Resource Requests of the istio-proxy Container?
- Does ASM Support HTTP/1.0?
- How Can I Block Access from Some IP Address Ranges or Ports for a Service Mesh?
- How Do I Configure max_concurrent_streams for a Gateway?
- How Do I Fix Compatibility Issues Between Istio CNI and Init Containers?
Monitoring Traffic
- Why Cannot I View Traffic Monitoring Data Immediately After a Pod Is Started?
- Why Are the Latency Statistics on the Dashboard Page Inaccurate?
- Why Is the Traffic Ratio Inconsistent with That in the Traffic Monitoring Chart?
- Why Can't I Find Certain Error Requests in Tracing?
- Why Cannot I Find My Service in the Traffic Monitoring Topology?
- How Do I Connect a Service Mesh to Jaeger or Zipkin for Viewing Traces?
- Videos
More Documents
- Getting Started
- User Guide
- Mesh Management
Adding a Service
On this page
Show all
Features in v1.3
- Mixer-based metrics, access logs, and call chains are supported.
- SDS is supported and the pods do not need to be restarted for certificate rotation.
- Sidecar APIs are supported.
- Control-plane performance optimization is supported.
- The private version of Huawei Virtual Service Delegation goes online, providing decoupling gateway traffic configuration for major customers in advance.
- CCE clusters v1.13, v1.15, v1.17, and v1.19 are supported.
For details, see https://istio.io/latest/news/releases/1.3.x/announcing-1.3/change-notes/.
Parent topic: Upgrades
