- What's New
- Function Overview
- Getting Started
- User Guide
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
APIs
- AS Groups
- AS Configurations
- Instances
AS Policies
- Creating an AS Policy
- Creating an AS Policy (V2)
- Modifying an AS Policy
- Modifying an AS Policy (V2)
- Querying AS Policies Bound to an AS Group
- Querying AS Policies Bound to a Scaling Resource (V2)
- Querying AS Policies (V2)
- Querying an AS Policy
- Querying an AS Policy (V2)
- Executing, Enabling, or Disabling an AS Policy
- Deleting an AS Policy
- Batch Managing AS Policies
- AS Policy Execution Logs
- Scaling Action Logs
- Quotas
- Notifications
- Lifecycle Hooks
- Tags
- Planned Tasks
- API Version Query
- Application Examples
- Appendix
- Change History
- SDK Reference
FAQ
General
- What Are Restrictions on Using AS?
- Must I Use AS Together With ELB and Cloud Eye?
- Is AS Billed?
- Will an Abrupt Change in Monitoring Metric Values Trigger an Unnecessary Scaling Action?
- How Many AS Policies and AS Configurations Can I Create and Use?
- Can AS Automatically Scale Up or Down vCPUs, Memory, and Bandwidth of ECSs?
- What Is an AS Quota?
- How Do I Fix the Error "The key pair does not exist" When I Connect to an Instance?
- What Types of EIP and Shared Bandwidths Can Be Adjusted by AS?
- What Types of ECS and HECS Instances Can Be Scaled by AS?
- If the OS of an ECS Instance in an AS Group Is Upgraded, Can AS Automatically Add Instances with the Newest OS During the Next Scale-out Action?
- Can AS Add Yearly/Monthly ECS Instances When It Scales Out an AS Group?
- Can AS Increase Bandwidths as Required?
- AS Group
AS Policy
- How Many AS Policies Can I Enable?
- What Are the Conditions to Trigger an Alarm-based AS Policy?
- What Is a Cooldown Period and Why Is It Required?
- Can AS Scale Capacity Based on Custom Monitoring by Cloud Eye?
- What Monitoring Metrics for an AS Group Will Be Affected If VM Tools Are Not Installed on the Instances in the Group?
- What Can I Do If an AS Policy Fails to Be Enabled?
- How Do I Install the Agent on Instances in an AS Group to Use Agent Monitoring Metrics?
Instance
- How Do I Prevent Instances Manually Added to an AS Group from Being Automatically Removed?
- When There Are Multiple Flavors Included in the AS Configuration of an AS Group, What Order Are the Flavors Selected in During Scale-out Events?
- When an Instance Is Removed from an AS Group and Deleted, Is the Application Data Saved?
- Can I Add Yearly/Monthly ECS Instances to an AS Group?
- Can the System Automatically Delete the Instances Added Based on an AS Policy When They Are Not Required?
- What Is the Expected Number of Instances?
- How Do I Delete an ECS Instance Created in a Scaling Action?
- Will a Yearly/Monthly ECS Instance Be Deleted If It Becomes Unhealthy?
- How Do I Handle Unhealthy Instances in an AS Group?
- Why Instances in an AS Group Keep Failing Health Checks and Getting Deleted and Recreated?
- How Do I Prevent Instances from Being Automatically Removed from an AS Group?
- Why Is an Instance that Was Removed from an AS Group and Deleted Still Displayed in the ECS List?
- Do I Need to Bind an EIP to an Instance Before I Manually Add the Instance to an AS Group?
- Can I Apply the Configurations of an Existing Instance in an AS Group to Instances to Be Added in the Future?
- Will the System Bind a New EIP or an Existing One a Newly Added ECS Instance?
- How Can I Automatically Deploy My Application on an Instance?
- How Does Cloud-Init Affect the AS Service?
- Why Can't I Use a Key File to Log In to an ECS?
- Do I Need to Configure an EIP in an AS Configuration When a Load Balancer Has Been Enabled for an AS Group?
- How Do I Enable Automatic Initialization of EVS Disks on Instances that Have Been Added to an AS Group During Scaling Actions?
General
- Videos
- Glossary
More Documents
- Best Practices
- Quick Start
- AS Management
General
- Are ELB and Cloud Eye Mandatory for AS?
- Is AS Billed?
- Does an Abrupt Change on Monitoring Indicator Values Cause an Incorrect Scaling Action?
- What Is the AS Quota?
- Why is a message displayed indicating that the key pair does not exist and the operation is discontinued when several users under the same account operate AS resources?
- AS Group
AS Policy
- How Many AS Policies Can Be Enabled?
- What Are the Conditions to Trigger an Alarm in the AS Policy?
- What Is a Cooldown Period? Why Is It Required?
- Can AS Scale Capacity Based on Custom Monitoring of Cloud Eye?
- What Will Monitoring Metrics for an AS Group Be Affected If VM Tools Are Not Installed on ECSs?
- How Can I Install the Agent Plug-in on the Instances in an AS Group to Use Agent Monitoring Metrics?
Instance
- How Do I Prevent Instances Manually Added to an AS Group from Being Removed Automatically?
- What Are the Sequence of Selecting Flavors in Multi-Flavor AS Configuration?
- Will the Application Data on an Instance Be Retained After the Instance Is Removed from an AS Group and Deleted?
- Can I Add ECSs Charged in Yearly/Monthly Mode?
- Can Instances That Have Been Added Based on an AS Policy Be Automatically Deleted When They Are Not Required?
- How Do I Delete an ECS Created in a Scaling Action?
- Will a Yearly/Monthly ECS Be Deleted When the ECS Becomes Faulty?
- How Should I Handle Abnormal Instances in an AS Group?
- What Can I Do If Instances in an AS Group Frequently Fail in Health Checks and Are Deleted and Then Created Repeatedly?
- How Do I Prevent ECSs from Being Removed from an AS Group Automatically?
- Why Is an Instance Removed and Deleted from an AS Group Still Displayed in the ECS List?
- What Can I Do to Enable My Application to Be Automatically Deployed on an Instance?
- How Can I Run Existing Services on an Instance Newly Added to an AS Group?
- Why Cannot I Use a Key File to Log In to an ECS?
- Do I Need to Configure an EIP in an AS Configuration When A Load Balancer Has Been Enabled in an AS Group?
- How Can I Enable Automatic Initialization of EVS Disks of Instances That Have Been Added in a Scaling Action to an AS Group?
General
- Change History
- Before You Start
- API Overview
- Calling APIs
- Getting Started
API
- AS Groups
- AS Configurations
- Instances in an AS Group
AS Policies
- Querying All AS Policies (V2)
- Querying AS Policy Details
- Querying Details of an AS Policy (V2)
- Performing Operations on AS Policies in Batches
- Quotas
- Notifications
- Lifecycle Hook
- Tag Management
- API Management
- Appendix
- Change History
User Guide (Paris Regions)
- Best Practices
- Quick Start
- AS Management
General
- AS Group
AS Policy
Instance
- Can AS Automatically Delete Instances Added Based on an AS Policy When They Are Not Required?
General
- Change History
- API Reference (Paris Regions)
- Best Practices
- Quick Start
- AS Management
General
- Is AS Billed?
- AS Group
AS Policy
Instance
General
- Change History
- Before You Start
- API Overview
- Calling APIs
- Getting Started
APIs
- AS Groups
- AS Configurations
AS Policies
- Quotas
- Notifications
- Lifecycle Hook
- Tag Management
- API Management
- Appendix
- Change History
User Guide (Ankara Region)
- Best Practices
- Quick Start
- AS Management
General
- AS Group
AS Policy
Instance
General
- Change History
API Reference (Ankara Region)
- Before You Start
- API Overview
- Calling APIs
- Getting Started
APIs
- AS Groups
- AS Configurations
- Instances
AS Policies
- Quotas
- Notifications
- Lifecycle Hooks
- API Version Query
- Appendix
- Change History
Help Center/
Auto Scaling/
User Guide/
AS Group and Instance Monitoring/
Setting Monitoring Alarm Rules
Setting alarm rules allows you to customize the monitored objects and notification policies and determine the running status of your ECS instances at any time.
- Click
in the upper left corner and select the desired region and project.
- Under Management & Governance, select Cloud Eye.
- In the navigation pane, choose Alarm Management > Alarm Rules.
- On the Alarm Rules page, click Create Alarm Rule to create an alarm rule for the AS service or modify an existing alarm rule of the AS service.
- After setting the parameters, click Create.
- For more information about how to set alarm rules, see Cloud Eye User Guide.
- You can create alarm rules on the Cloud Eye console to dynamically expand resources.
Parent topic: AS Group and Instance Monitoring
