Help Center/ Auto Scaling/ User Guide/ Cloud Eye Monitoring/ Viewing Monitoring Metrics
Updated on 2026-01-06 GMT+08:00
The cloud platform provides Cloud Eye to help you obtain the status of your ECS instances. This section describes how to view details of AS group metrics to obtain information about the status of the ECS instances in the AS group.
The ECS instance is running properly.
  • Monitoring metrics such as CPU Usage and Disks Read Rate are available only when there is at least one instance in an AS group. If not, only the Number of Instances metric is available.
  • Monitoring data is not displayed for a stopped, faulty, or deleted ECS instance. After such an ECS instance restarts or recovers, the monitoring data is available.
Viewing Monitoring Metrics on Auto Scaling
  1. Log in to the AS console.
  2. On the AS Groups page, find the AS group to view monitoring data and click its name.
  3. Click the Monitoring tab to view the monitoring data.
    You can view data of the last one, three, 12, or 24 hours, or last 7 days. If you want to view data for a longer time range, click View details to go to the Cloud Eye page, hover your mouse over a graph, and click .
Viewing Monitoring Metrics on Cloud Eye
  1. Log in to the Cloud Eye console.
  2. In the navigation pane on the left, choose Cloud Service Monitoring > Auto Scaling.
  3. Locate the row that contains the target AS group and click View Metric in the Operation column to view monitoring data.
    You can view data of the last one, three, 12, or 24 hours, or last 7 days. Hover your mouse over a graph and click to view data for a longer time range.
It can take a period of time to obtain and transfer the monitoring data. Therefore, wait for a while and then check the data.
