Help Center/ Auto Scaling/ User Guide/ Instance Scaling/ AS Configurations/ Copying an AS Configuration
Updated on 2026-06-16 GMT+08:00
You can copy an existing AS configuration.
When copying an AS configuration, you can modify parameter settings, such as the configuration name, ECS specifications, and image of the existing AS configuration to rapidly add a new AS configuration.
- Log in to the AS console.
- Click the AS Configurations tab, locate the row containing the target AS configuration, and click Replicate in the Operation column.
- On the Copy AS Configuration page, modify parameter settings, such as Name, Specifications, and Image, and configure the ECS login mode based on service requirements.
- Click OK.
Parent topic: AS Configurations
