Updated on 2025-11-18 GMT+08:00
Errors
The Error page displays the error information, including the total number of errors, device error rate, number of affected devices, number of affected versions, error trend, the five versions with the most errors, the five devices with the most errors, and error list.
  1. Log in to the APM console.
  2. Click on the left and choose Management & Governance > Application Performance Management.
  3. In the navigation pane, choose App Monitoring > Error. The error data is displayed.
    Table 1 Error parameters
    Total Errors
    Total number of errors.
    Device Error Rate
    Device error rate = Number of devices that encounter errors/Total number of devices
    Affected Devices
    Number of devices affected by errors.
    Affected Versions
    Number of versions affected by errors.
    • Select an application from the drop-down list in the upper left corner of the page.
    • Select a carrier, region, device, version, and tag from the drop-down lists to view required information.
    • In the upper right corner of the page, select a time range. Default: Last 20 minutes.
Error Trend
The error trend graph displays the total number of errors and the number of affected devices. Move the cursor to the graph. The total number of errors and the number of affected devices will be displayed.
Table 2 Parameters of the error trend graph
Total Errors
Affected Devices
Total number of devices affected by errors.
The 5 Versions with the Most Errors
A bar graph shows the 5 versions with the most errors. Move the cursor to a version in the graph. The total number of errors of the current version will be displayed.
Table 3 Related parameters
Total Errors
Total number of errors that a version encounters.
The 5 Devices with the Most Errors
A bar graph shows the 5 devices with the most errors. Move the cursor to a device in the graph. The total number of errors of the current device will be displayed.
Table 4 Related parameters
Total Errors
Total number of errors that a device encounters.
Error List
The error list displays the error summary, error type, number of errors, number of affected devices, number of affected versions, first occurrence time, last occurrence time, and operation.
  • In the search box in the upper left corner of the error list, enter a keyword about the error summary or type and click to view the errors that meet the search criteria. Note that each keyword is case sensitive.
  • Click in the upper right corner of the error list and select the target metric data.
  • By default, the error list is sorted by Errors in descending order.
Table 5 Parameters related to the error list
Error Summary
Error information summary.
Error Type
Error type.
Errors
Number of errors.
Affected Devices
Affected Versions
First Occurred
Time when the first error occurred.
Last Occurred
Time when the last error occurred.
  1. Click Analyze in the Operation column in the row that contains the target error to view details. The details include the error trend, 5 versions with the most errors, 5 devices with the most errors, and error list.
    • In the search box in the upper left corner of the error list, enter a keyword about the device model/ID or error type and click to view the errors that meet the search criteria. Note that each keyword is case sensitive.
    • By default, the error list is sorted by occurrence time in descending order.
  2. Click View Details in the Operation column of the target device model/ID. The error information and stack are displayed.
    Stack analysis is supported only for iOS and Android, but not for HarmonyOS.
    Figure 1 Error - Stack analysis for iOS apps
    Table 6 Related parameters
    Occurred
    Time when an error occurred.
    User Identifier
    Unique identifier of the user.
    Device Model
    Device model.
    Summary
    Network Access Mode
    Network access mode of the app.
    OS Version
    OS version.
    App Version
    App version.
    Used Memory
    Used memory.
    Idle Memory
    Idle memory.
    CPU Usage
    CPU usage.
    CPU Architecture
    CPU architecture.
    Available Disk Space
    Available disk space.
    Used Disk Space
    Used disk space.
    App Package
    Name of the app package.
    Error Stack
    Error stack.
  3. Enter the OBS bucket address of the symbol table in the crash stack box. For details about how to upload the symbol table file, see Using OBS Console.
  4. Click Stack Analysis. The analysis result is displayed in the box.
