Updating a Stack Set
1. On the Stack Set page, click the name of the stack set in which you want to create a stack.
2. On the Stack Instance tab page, click Update in the upper right corner.
3. When selecting a template, you can select either of the creation modes as shown in the following figure.
Select Current Template or Replace Current Template (use a new template) to update the stack set.
- Click Next. On the displayed parameter configuration page, modify the parameters of the current template.
- Click Next. On the displayed page, enter the tenant ID and select deployment regions.
- Confirm the configurations. Ensure that correct parameters are filled in previous steps and click Deploy.
Solution 2: Replacing the Current Template
For details, refer to Creating a Stack Set.
