JDBC
Function
The JDBC connector is provided by Apache Flink and can be used to read data from and write data to common databases, such as MySQL and PostgreSQL. Source tables, result tables, and dimension tables are supported.
| Type | Description |
| Supported Table Types | Source table, dimension table, and result table |
- An enhanced datasource connection with the database has been established, so that you can configure security group rules as required.
- For details about how to set up an enhanced datasource connection, see Enhanced Datasource Connections.
- For details about how to configure security group rules, see Security Group Overview.
Caveats
- The JDBC sink operates in upsert mode for exchanging UPDATE/DELETE messages with the external system if a primary key is defined on the DDL, otherwise, it operates in append mode and does not support to consume UPDATE/DELETE messages.
- When you create a Flink OpenSource SQL job, set Flink Version to 1.15 in the Running Parameters tab. Select Save Job Log, and specify the OBS bucket for saving job logs.
- Storing authentication credentials such as usernames and passwords in code or plaintext poses significant security risks. It is recommended using DEW to manage credentials instead. Storing encrypted credentials in configuration files or environment variables and decrypting them when needed ensures security. For details, see Flink OpenSource SQL Jobs Using DEW to Manage Access Credentials.
Syntax
create table jbdcTable (
attr_name attr_type
(',' attr_name attr_type)*
(','PRIMARY KEY (attr_name, ...) NOT ENFORCED)
(',' watermark for rowtime_column_name as watermark-strategy_expression)
) with (
'connector' = 'jdbc',
'url' = '',
'table-name' = '',
'username' = '',
'password' = ''
); Description
| Parameter | Mandatory | Default Value | Data Type | Description |
| connector | Yes | None | String | Connector to be used. Set this parameter to jdbc. |
| url | Yes | None | String | Database URL
| table-name | Yes | None | String | Name of the table where the data will be read from the database |
| driver | No | None | String | Driver required for connecting to the database. If you do not set this parameter, the automatically extracted URL will be used.
| username | No | None | String | Database authentication user name. This parameter must be configured in pair with password. |
| password | No | None | String | Database authentication password. This parameter must be configured in pair with username. |
| connection.max-retry-timeout | No | 60s | Duration | Maximum timeout between retries. The timeout should be in second granularity and should not be smaller than 1 second. |
| scan.partition.column | No | None | String | Name of the column used to partition the input. For details, see Partitioned Scan. |
| scan.partition.num | No | None | Integer | Number of partitions to be created. For details, see Partitioned Scan. |
| scan.partition.lower-bound | No | None | Integer | Lower bound of values to be fetched for the first partition. For details, see Partitioned Scan. |
| scan.partition.upper-bound | No | None | Integer | Upper bound of values to be fetched for the last partition. For details, see Partitioned Scan. |
| scan.fetch-size | No | 0 | Integer | Number of rows fetched from the database each time. If this parameter is set to 0, the SQL hint is ignored. |
| scan.auto-commit | No | true | Boolean | Whether each statement is committed in a transaction automatically. |
| lookup.cache.max-rows | No | None | Integer | Maximum number of rows in the lookup cache. When the rows exceed this value, the first item added to the cache will be marked as expired. By default, the lookup cache is not enabled. For details, see Lookup Cache Functions. |
| lookup.cache.ttl | No | None | Duration | Maximum survival time of each record in the lookup cache. When the rows exceed this value, the first item added to the cache will be marked as expired. By default, the lookup cache is not enabled. For details, see Lookup Cache Functions. |
| lookup.cache.caching-missing-key | No | true | Boolean | Whether to cache empty query results. The default value is true. For details, see Lookup Cache Functions. |
| lookup.max-retries | No | 3 | Integer | Maximum number of retry attempts when a database query fails. |
| sink.buffer-flush.max-rows | No | 100 | Integer | Maximum number of cached records before flushing, which can be set to 0 to disable it. |
| sink.buffer-flush.interval | No | 1s | Duration | The interval for flushing, after which the asynchronous thread will flush the data. Can be set to 0 to disable it. To fully handle the flush events of the cache asynchronously, sink.buffer-flush.max-rows can be set to 0 and an appropriate flush time interval can be configured. |
| sink.max-retries | No | 3 | Integer | Maximum number of retries after a failed attempt to write records to the database. |
| sink.parallelism | No | None | Integer | Defines the parallelism of the JDBC sink operator. By default, the parallelism is determined by the framework: using the same parallelism as the upstream chained operator. |
Partitioned Scan
To accelerate reading data in parallel Source task instances, Flink provides the partitioned scan feature for the JDBC table. The following parameters describe how to partition the table when reading in parallel from multiple tasks.
- scan.partition.column: name of the column used to partition the input. The data type of the column must be number, date, or timestamp.
- scan.partition.num: number of partitions.
- scan.partition.lower-bound: minimum value of the first partition.
- scan.partition.upper-bound: maximum value of the last partition.
- When a table is created, the preceding partitioned scan parameters must all be specified if any of them is specified.
- The scan.partition.lower-bound and scan.partition.upper-bound parameters are used to decide the partition stride instead of filtering rows in the table. All rows in the table are partitioned and returned.
The JDBC connector can be used as a lookup dimension table in temporal table joins, and currently only supports synchronous lookup mode.
By default, lookup cache is disabled. Therefore, all requests are sent to the external database. You can set lookup.cache.max-rows and lookup.cache.ttl to enable this feature. The main purpose of the lookup cache is to improve the performance of the JDBC connector in temporal table joins.
When the lookup cache is enabled, each process (i.e. TaskManager) will maintain a cache. Flink will first look up the cache, and only when the cache is not found will it send a request to the external database and update the cache with the returned data. When the cache hits the maximum cache rows lookup.cache.max-rows or when the rows exceed the maximum survival time lookup.cache.ttl, the first item added to the cache will be marked as expired. The records in the cache may not be the latest, and users can set lookup.cache.ttl to a smaller value to get better data refresh, but this may increase the number of requests sent to the database. Therefore, a balance between throughput and correctness should be maintained.
By default, Flink caches empty query results for primary keys, but you can switch this behavior by setting lookup.cache.caching-missing-key to false.
Data Type Mapping
| MySQL Type | PostgreSQL Type | Flink SQL Type |
| TINYINT | - | TINYINT |
| SMALLINT TINYINT UNSIGNED | SMALLINT INT2 SMALLSERIAL SERIAL2 | SMALLINT |
| INT MEDIUMINT SMALLINT UNSIGNED | INTEGER SERIAL | INT |
| BIGINT INT UNSIGNED | BIGINT BIGSERIAL | BIGINT |
| BIGINT UNSIGNED | - | DECIMAL(20, 0) |
| BIGINT | BIGINT | BIGINT |
| FLOAT | REAL FLOAT4 | FLOAT |
| DOUBLE DOUBLE PRECISION | FLOAT8 DOUBLE PRECISION | DOUBLE |
| NUMERIC(p, s) DECIMAL(p, s) | NUMERIC(p, s) DECIMAL(p, s) | DECIMAL(p, s) |
| BOOLEAN TINYINT(1) | BOOLEAN | BOOLEAN |
| DATE | DATE | DATE |
| TIME [(p)] | TIME [(p)] [WITHOUT TIMEZONE] | TIME [(p)] [WITHOUT TIMEZONE] |
| DATETIME [(p)] | TIMESTAMP [(p)] [WITHOUT TIMEZONE] | TIMESTAMP [(p)] [WITHOUT TIMEZONE] |
| CHAR(n) VARCHAR(n) TEXT | CHAR(n) CHARACTER(n) VARCHAR(n) CHARACTER VARYING(n) TEXT | STRING |
| BINARY VARBINARY BLOB | BYTEA | BYTES |
| - | ARRAY | ARRAY |
Example
- Example 1: Use JDBC as the data source and Print as the result table to read data from an RDS MySQL database and write it into the Print result table.
- Create an enhanced datasource connection in the VPC and subnet where RDS MySQL locates, and bind the connection to the required Flink elastic resource pool. For details, see Enhanced Datasource Connections.
- Set RDS MySQL security groups and add inbound rules to allow access from the Flink queue. Test the connectivity using the RDS address by referring to Testing Address Connectivity. If the connection passes the test, it is bound to the queue.
- Log in to the RDS MySQL database, create table orders in the Flink database, and insert data. For details about how to create a database, see Creating a Database.
Create table orders in the Flink database.
CREATE TABLE `flink`.`orders` ( `order_id` VARCHAR(32) NOT NULL, `order_channel` VARCHAR(32) NULL, PRIMARY KEY (`order_id`) ) ENGINE = InnoDB DEFAULT CHARACTER SET = utf8mb4 COLLATE = utf8mb4_general_ci;
Insert data into the table.
insert into orders( order_id, order_channel ) values ('1', 'webShop'), ('2', 'miniAppShop'); - Create a Flink OpenSource SQL job. Enter the following job script and submit the job.
When you create a job, set Flink Version to 1.15 in the Running Parameters tab. Select Save Job Log, and specify the OBS bucket for saving job logs. Change the values of the parameters in bold as needed in the following script.
CREATE TABLE jdbcSource ( order_id string, order_channel string ) WITH ( 'connector' = 'jdbc', 'url' = 'jdbc:mysql://MySQLAddress:MySQLPort/flink',--flink is the database name created in RDS MySQL. 'table-name' = 'orders', 'username' = 'MySQLUsername', 'password' = 'MySQLPassword', 'scan.fetch-size' = '10', 'scan.auto-commit' = 'true' ); CREATE TABLE printSink ( order_id string, order_channel string ) WITH ( 'connector' = 'print' ); insert into printSink select * from jdbcSource;
- View the data result in the taskmanager.out file. The data result is as follows:
+I(1,webShop) +I(2,miniAppShop)
- Example 2: Send data using the DataGen source table and output data to a MySQL database through the JDBC result table.
- Log in to the RDS MySQL database, create table orders in the Flink database, and insert data. For details about how to create a database, see Creating a Database. Create table orders in the Flink database.
CREATE TABLE dataGenSource ( order_id string, order_channel string ) WITH ( 'connector' = 'datagen', 'fields.order_id.kind' = 'sequence', 'fields.order_id.start' = '1', 'fields.order_id.end' = '1000', 'fields.order_channel.kind' = 'random', 'fields.order_channel.length' = '5' ); CREATE TABLE jdbcSink ( order_id string, order_channel string, PRIMARY KEY(order_id) NOT ENFORCED ) WITH ( 'connector' = 'jdbc', 'url? = 'jdbc:mysql://MySQLAddress:MySQLPort/flink',-- flink is the MySQL database where the orders table locates. 'table-name' = 'orders', 'username' = 'MySQLUsername', 'password' = 'MySQLPassword', 'sink.buffer-flush.max-rows' = '1' ); insert into jdbcSink select * from dataGenSource;
- Run the SQL statement in the MySQL database to view data in the table:
select * from orders;
- Example 3: Read data from the DataGen source table, use the JDBC table as the dimension table, and write the table information generated by both into the Print result table.
insert into orders( order_id, order_channel ) values ('1', 'webShop'), ('2', 'miniAppShop'); - Create a Flink OpenSource SQL job. Enter the following job script and submit the job. This job script uses DataGen as the data source and JDBC as the dimension table to write data into the Print result table.
CREATE TABLE dataGenSource ( order_id string, order_time timestamp, proctime as Proctime() ) WITH ( 'connector' = 'datagen', 'fields.order_id.kind' = 'sequence', 'fields.order_id.start' = '1', 'fields.order_id.end' = '2' ); --Creating a dimension table CREATE TABLE jdbcTable ( order_id string, order_channel string ) WITH ( 'connector' = 'jdbc', 'url' = 'jdbc:mysql://JDBC address:JDBC port/flink',--flink is the name of the database where the orders table of RDS for MySQL is located. 'table-name' = 'orders', 'username' = 'JDBCUserName', 'password' = 'JDBCPassWord', 'lookup.cache.max-rows' = '100', 'lookup.cache.ttl' = '1000', 'lookup.cache.caching-missing-key' = 'false', 'lookup.max-retries' = '5' ); CREATE TABLE printSink ( order_id string, order_time timestamp, order_channel string ) WITH ( 'connector' = 'print' ); insert into printSink SELECT dataGenSource.order_id, dataGenSource.order_time, jdbcTable.order_channel from dataGenSource left join jdbcTable for system_time as of dataGenSource.proctime on dataGenSource.order_id = jdbcTable.order_id;
+I(1, xxx, webShop) +I(2, xxx, miniAppShop)
FAQ
None
