JDBC Dimension Table
Updated on 2024-09-29 GMT+08:00
Create a JDBC dimension table to connect to the source stream.
You have created a JDBC instance for your account.
Precautions
  • When you create a Flink OpenSource SQL job, set Flink Version to 1.12 in the Running Parameters tab. Select Save Job Log, and specify the OBS bucket for saving job logs.
  • In Flink cross-source development scenarios, there is a risk of password leakage if datasource authentication information is directly configured. You are advised to use the datasource authentication provided by DLI.
    For details about datasource authentication, see Introduction to Datasource Authentication.
Syntax
 3
 4
 5
 6
 7
 8
 9
10
11
12
CREATE TABLE  table_id (
  attr_name attr_type
  (',' attr_name attr_type)*
  WITH (
  'connector' = 'jdbc',
  'url' = '',
  'table-name' = '',
  'driver' = '',
  'username' = '',
  'password' = ''
Parameters
Table 1 Parameter descriptions
Mandatory
connector
Yes
Data source type. The value is fixed to jdbc.
url
Yes
Database URL
table-name
Yes
Name of the table where the data will be read from the database
driver
No
Driver required for connecting to the database. If you do not set this parameter, the automatically extracted URL will be used.
username
No
Database authentication user name. This parameter must be configured in pair with password.
password
No
Database authentication password. This parameter must be configured in pair with username.
scan.partition.column
No
Name of the column used to partition the input
This parameter must be set when scan.partition.lower-bound, scan.partition.upper-bound, and scan.partition.num are all configured, and should not be set when other three parameters are not.
No
Lower bound of values to be fetched for the first partition
This parameter must be set when scan.partition.column, scan.partition.upper-bound, and scan.partition.num are all configured, and should not be set when other three parameters are not.
No
Upper bound of values to be fetched for the last partition
This parameter must be set when scan.partition.column, scan.partition.lower-bound, and scan.partition.num are all configured, and should not be set when other three parameters are not.
scan.partition.num
No
Number of partitions to be created
This parameter must be set when scan.partition.column, scan.partition.upper-bound, and scan.partition.upper-bound are all configured, and should not be set when other three parameters are not.
scan.fetch-size
No
Number of rows fetched from the database each time. The default value is 0, indicating the hint is ignored.
lookup.cache.max-rows
No
Maximum number of cached rows in a dimension table. When the rows exceed this value, the data that is added first will be marked as expired. The value -1 indicates that data cache disabled.
lookup.cache.ttl
No
Maximum time to live (TTL) of for every rows in lookup cache. Caches exceeding the TTL will be expired. The format is {length value}{time unit label}, for example, 123ms, 321s. The supported time units include d, h, min, s, and ms (default unit).
lookup.max-retries
No
Maximum number of attempts to obtain data from the dimension table. The default value is 3.
pwd_auth_name
No
Name of datasource authentication of the password type created on DLI.
Data Type Mapping
Table 2 Data type mapping
MySQL Type
PostgreSQL Type
Flink SQL Type
TINYINT
TINYINT
SMALLINT
TINYINT UNSIGNED
SMALLINT
INT2
SMALLSERIAL
SERIAL2
SMALLINT
INT
MEDIUMINT
SMALLINT UNSIGNED
INTEGER
SERIAL
INT
BIGINT
INT UNSIGNED
BIGINT
BIGSERIAL
BIGINT
BIGINT UNSIGNED
DECIMAL(20, 0)
BIGINT
BIGINT
BIGINT
FLOAT
REAL
FLOAT4
FLOAT
DOUBLE
DOUBLE PRECISION
FLOAT8
DOUBLE PRECISION
DOUBLE
NUMERIC(p, s)
DECIMAL(p, s)
NUMERIC(p, s)
DECIMAL(p, s)
DECIMAL(p, s)
BOOLEAN
TINYINT(1)
BOOLEAN
BOOLEAN
DATE
DATE
DATE
TIME [(p)]
TIME [(p)] [WITHOUT TIMEZONE]
DATETIME [(p)]
TIMESTAMP [(p)] [WITHOUT TIMEZONE]
CHAR(n)
VARCHAR(n)
TEXT
CHAR(n)
CHARACTER(n)
VARCHAR(n)
CHARACTER
VARYING(n)
TEXT
STRING
BINARY
VARBINARY
BLOB
BYTEA
BYTES
ARRAY
ARRAY
Example
Read data from a Kafka source table, use a JDBC table as the dimension table. Write table information generated by the source and dimension tables to a Kafka result table. The procedure is as follows:
  1. Create an enhanced datasource connection in the VPC and subnet where MySQL and Kafka locate, and bind the connection to the required Flink elastic resource pool. For details, see Enhanced Datasource Connections.
  2. Set MySQL and Kafka security groups and add inbound rules to allow access from the Flink queue. Test the connectivity using the MySQL and Kafka address by referring to Testing Address Connectivity. If the connection passes the test, it is bound to the queue.
  3. Connect to the MySQL database instance, create a table in the flink database as a dimension table, and name the table area_info. Example SQL statements are as follows:
    CREATE TABLE `flink`.`area_info` (
    	`area_id` VARCHAR(32) NOT NULL,
    	`area_province_name` VARCHAR(32) NOT NULL,
    	`area_city_name` VARCHAR(32) NOT NULL,
    	`area_county_name` VARCHAR(32) NOT NULL,
    	`area_street_name` VARCHAR(32) NOT NULL,
    	`region_name` VARCHAR(32) NOT NULL,
    	PRIMARY KEY (`area_id`)
    )	ENGINE = InnoDB
    	DEFAULT CHARACTER SET = utf8mb4
    	COLLATE = utf8mb4_general_ci;
  4. Connect to the MySQL database and run the following statement to insert test data into the JDBC dimension table area_info:
    insert into flink.area_info
      (area_id, area_province_name, area_city_name, area_county_name, area_street_name, region_name)
      values
      ('330102', 'a1', 'b1', 'c1', 'd1', 'e1'),
      ('330106', 'a1', 'b1', 'c2', 'd2', 'e1'),
      ('330108', 'a1', 'b1', 'c3', 'd3', 'e1'),  ('330110', 'a1', 'b1', 'c4', 'd4', 'e1');
  5. Create a Flink OpenSource SQL job Enter the following job script and submit the job. The job script uses Kafka as the data source and a JDBC table as the dimension table. Data is output to a Kafka result table.
    When you create a job, set Flink Version to 1.12 in the Running Parameters tab. Select Save Job Log, and specify the OBS bucket for saving job logs. Set the values of the parameters in bold in the following script as needed.
     3
     4
     5
     6
     7
     8
     9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    33
    34
    35
    36
    37
    38
    39
    40
    41
    42
    43
    44
    45
    46
    47
    48
    49
    50
    51
    52
    53
    54
    55
    56
    57
    58
    59
    60
    61
    62
    63
    64
    CREATE TABLE orders (
      order_id string,
      order_channel string,
      order_time string,
      pay_amount double,
      real_pay double,
      pay_time string,
      user_id string,
      user_name string,
      area_id string,
      proctime as Proctime()
    ) WITH (
      'connector' = 'kafka',
      'topic' = 'KafkaSourceTopic',
      'properties.bootstrap.servers' = 'KafkaAddress1:KafkaPort,KafkaAddress2:KafkaPort',
      'properties.group.id' = 'jdbc-order',
      'scan.startup.mode' = 'latest-offset',
      'format' = 'json'
    -- Create an address dimension table
    create table area_info (
        area_id string,
        area_province_name string,
        area_city_name string,
        area_county_name string,
        area_street_name string,
        region_name string
    ) WITH (
      'url' = 'jdbc:mysql://JDBCAddress:JDBCPort/flink',--flink is the MySQL database where the area_info table locates.
      'table-name' = 'area_info',
      'username' = 'JDBCUserName',
      'password' = 'JDBCPassWord'
    -- Generate a wide table based on the address dimension table containing detailed order information.
    create table order_detail(
        order_id string,
        order_time string,
        pay_amount double,
        real_pay double,
        pay_time string,
        user_id string,
        user_name string,
        area_id string,
        region_name string
    ) with (
      'topic' = 'KafkaSinkTopic',
      'format' = 'json'
    insert into order_detail
        select orders.order_id, orders.order_channel, orders.order_time, orders.pay_amount, orders.real_pay, orders.pay_time, orders.user_id, orders.user_name,
               area.area_id, area.area_province_name, area.area_city_name, area.area_county_name,
               area.area_street_name, area.region_name  from orders
               left join area_info for system_time as of orders.proctime as area on orders.area_id = area.area_id;
  6. Connect to the Kafka cluster and insert the following test data into the source topic in Kafka:
    {"order_id":"202103241606060001", "order_channel":"appShop", "order_time":"2021-03-24 16:06:06", "pay_amount":"200.00", "real_pay":"180.00", "pay_time":"2021-03-24 16:10:06", "user_id":"0001", "user_name":"Alice", "area_id":"330106"}
    {"order_id":"202103251202020001", "order_channel":"miniAppShop", "order_time":"2021-03-25 12:02:02", "pay_amount":"60.00", "real_pay":"60.00", "pay_time":"2021-03-25 12:03:00", "user_id":"0002", "user_name":"Bob", "area_id":"330110"}
    {"order_id":"202103251505050001", "order_channel":"qqShop", "order_time":"2021-03-25 15:05:05", "pay_amount":"500.00", "real_pay":"400.00", "pay_time":"2021-03-25 15:10:00", "user_id":"0003", "user_name":"Cindy", "area_id":"330108"}
  7. Connect to the Kafka cluster and read data from the sink topic of Kafka.
    {"order_id":"202103241606060001","order_channel":"appShop","order_time":"2021-03-24 16:06:06","pay_amount":200.0,"real_pay":180.0,"pay_time":"2021-03-24 16:10:06","user_id":"0001","user_name":"Alice","area_id":"330106","area_province_name":"a1","area_city_name":"b1","area_county_name":"c2","area_street_name":"d2","region_name":"e1"}
    {"order_id":"202103251202020001","order_channel":"miniAppShop","order_time":"2021-03-25 12:02:02","pay_amount":60.0,"real_pay":60.0,"pay_time":"2021-03-25 12:03:00","user_id":"0002","user_name":"Bob","area_id":"330110","area_province_name":"a1","area_city_name":"b1","area_county_name":"c4","area_street_name":"d4","region_name":"e1"}
    {"order_id":"202103251505050001","order_channel":"qqShop","order_time":"2021-03-25 15:05:05","pay_amount":500.0,"real_pay":400.0,"pay_time":"2021-03-25 15:10:00","user_id":"0003","user_name":"Cindy","area_id":"330108","area_province_name":"a1","area_city_name":"b1","area_county_name":"c3","area_street_name":"d3","region_name":"e1"}
None
