Updated on 2025-07-04 GMT+08:00
Kafka Source Table
Function
Create a source stream to obtain data from Kafka as input data for jobs.
Apache Kafka is a fast, scalable, and fault-tolerant distributed message publishing and subscription system. It delivers high throughput and built-in partitions and provides data replicas and fault tolerance. Apache Kafka is applicable to scenarios of handling massive messages.
  • You have created a Kafka cluster.
  • An enhanced datasource connection has been created for DLI to connect to Kafka clusters, so that jobs can run on the dedicated queue of DLI and you can set the security group rules as required.
  • In Flink cross-source development scenarios, there is a risk of password leakage if datasource authentication information is directly configured. You are advised to use the datasource authentication provided by DLI.
    For details about datasource authentication, see Introduction to Datasource Authentication.
Precautions
  • When creating a Flink OpenSource SQL job, you need to set Flink Version to 1.12 on the Running Parameters tab of the job editing page, select Save Job Log, and set the OBS bucket for saving job logs.
  • For details about how to use data types when creating tables, see Format.
Syntax
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
create table kafkaSource(
  attr_name attr_type
  (',' attr_name attr_type)*
  (','PRIMARY KEY (attr_name, ...) NOT ENFORCED)
  (',' WATERMARK FOR rowtime_column_name AS watermark-strategy_expression)
with (
  'connector' = 'kafka',
  'topic' = '',
  'properties.bootstrap.servers' = '',
  'properties.group.id' = '',
  'scan.startup.mode' = '',
  'format' = ''
Parameters
Table 1 Parameter description
Mandatory
Default Value
Data Type
connector
Yes
None
String
Connector to be used. Set this parameter to kafka.
topic
Yes
None
String
Topic name of the Kafka record.
Note:
  • Only one of topic and topic-pattern can be specified.
  • If there are multiple topics, separate them with semicolons (;), for example, topic-1;topic-2.
topic-pattern
No
None
String
Regular expression for a pattern of topic names to read from.
For example:
'topic.*'
'(topic-c|topic-d)'
'(topic-a|topic-b|topic-\\d*)'
'(topic-a|topic-b|topic-[0-9]*)'
Yes
None
String
Comma separated list of Kafka brokers.
properties.group.id
Yes
None
String
ID of the consumer group for the Kafka source.
properties.*
No
None
String
This parameter can set and pass arbitrary Kafka configurations.
Note:
  • The suffix to properties. must match the configuration key in Apache Kafka.
    For example, you can disable automatic topic creation via 'properties.allow.auto.create.topics' = 'false'.
  • Some configurations are not supported, for example, 'key.deserializer' and 'value.deserializer'.
format
Yes
None
String
Format used to deserialize and serialize the value part of Kafka messages. Note: Either this parameter or the value.format parameter is required.
Refer to Format for more details and format parameters.
key.format
No
None
String
Format used to deserialize and serialize the key part of Kafka messages.
Note:
  • If a key format is defined, the key.fields parameter is required as well. Otherwise, the Kafka records will have an empty key.
  • Refer to Format for more details and format parameters.
key.fields
No
List<String>
Defines the columns in the table as the list of keys. This parameter must be configured in pair with key.format.
This parameter is left empty by default. Therefore, no key is defined.
The format is like field1;field2.
key.fields-prefix
No
None
String
Defines a custom prefix for all fields of the key format to avoid name clashes with fields of the value format.
value.format
Yes
None
String
Note:
  • Either this parameter or the format parameter is required. If two parameters are configured, a conflict occurs.
value.fields-include
No
ALL
Enum
Possible values: [ALL, EXCEPT_KEY]
Whether to contain the key field when parsing the message body.
Possible values are:
  • ALL (default): All defined fields are included in the value of Kafka messages.
  • EXCEPT_KEY: All the fields except those defined by key.fields are included in the value of Kafka messages.
scan.startup.mode
No
group-offsets
String
Start position for Kafka to read data.
  • earliest-offset: Data is read from the earliest Kafka offset.
  • latest-offset: Data is read from the latest Kafka offset.
  • group-offsets (default): Data is read based on the consumer group.
  • timestamp: Data is read from a user-supplied timestamp. When setting this option, you also need to specify scan.startup.timestamp-millis in WITH.
  • specific-offsets: Data is read from user-supplied specific offsets for each partition. When setting this option, you also need to specify scan.startup.specific-offsets in WITH.
No
None
String
This parameter takes effect only when scan.startup.mode is set to specific-offsets. It specifies the offsets for each partition, for example, partition:0,offset:42;partition:1,offset:300.
No
None
Long
Startup timestamp. This parameter takes effect when scan.startup.mode is set to timestamp.
scan.topic-partition-discovery.interval
No
None
Duration
Interval for a consumer to periodically discover dynamically created Kafka topics and partitions.
ssl_auth_name
No
None
String
Name of datasource authentication of the Kafka_SSL type created on DLI. This configuration is used when SSL is configured for Kafka.
Note: If only the SSL type is used, you need to set properties.security.protocol to SSL.
If SASL_SSL is used, set the following parameters:
  • 'properties.security.protocol' = 'SASL_SSL';
  • 'properties.sasl.mechanism' = 'GSSAPI or PLAIN';
  • 'properties.sasl.jaas.config' = 'org.apache.kafka.common.security.plain.PlainLoginModule required username=\"xxx\" password=\"xxx\";'
krb_auth_name
No
None
String
Name of datasource authentication of the Kerberos type created on DLI. This configuration is used when SASL is configured for Kafka.
Note: If the SASL_PLAINTEXT type and Kerberos authentication are used, you need to set properties.sasl.mechanism to GSSAPI and properties.security.protocol to SASL_PLAINTEXT.
Metadata Column
You can define metadata columns in the source table to obtain the metadata of Kafka messages. For example, if multiple topics are defined in the WITH parameter and the metadata column is defined in the Kafka source table, the data read by Flink is labeled with the topic from which the data is read.
Table 2 Metadata column
Key
Data Type
R/W
topic
STRING NOT NULL
R
partition
INT NOT NULL
R
Partition ID of the Kafka record.
headers
MAP<STRING, BYTES> NOT NULL
R/W
Headers of Kafka messages.
leader-epoch
INT NULL
R
Leader epoch of the Kafka record.
For details, see example 1.
offset
BIGINT NOT NULL
R
Offset of the Kafka record.
timestamp
TIMESTAMP(3) WITH LOCAL TIME ZONE NOT NULL
R/W
Timestamp of the Kafka record.
timestamp-type
STRING NOT NULL
R
Timestamp type of the Kafka record. The options are as follows:
  • NoTimestampType: No timestamp is defined in the message.
  • CreateTime: time when the message is generated.
  • LogAppendTime: time when the message is added to the Kafka broker.
Example (SASL_SSL Disabled for the Kafka Cluster)
  • Example 1: Read data from the Kafka metadata column and write it to the Print sink.
    1. Create an enhanced datasource connection in the VPC and subnet where Kafka locates, and bind the connection to the required Flink elastic resource pool. For details, see Enhanced Datasource Connections.
    2. Set Kafka security groups and add inbound rules to allow access from the Flink queue. Test the connectivity using the Kafka address by referring to Testing Address Connectivity. If the connection is successful, the datasource is bound to the queue. Otherwise, the binding fails.
    3. Create a Flink OpenSource SQL job. Enter the following job script and submit the job.
      When you create a job, set Flink Version to 1.12 on the Running Parameters tab. Select Save Job Log, and specify the OBS bucket for saving job logs. Change the values of the parameters in bold as needed in the following script.
      CREATE TABLE orders (
        `topic` String metadata,
        `partition` int metadata,
        `headers` MAP<STRING, BYTES> metadata,
        `leaderEpoch` INT metadata from 'leader-epoch',
        `offset` bigint metadata,
        `timestamp` TIMESTAMP(3) metadata,
        `timestampType` string metadata from 'timestamp-type',
        `message` string
      ) WITH (
        'topic' = 'KafkaTopic',
        'properties.bootstrap.servers' = 'KafkaAddress1:KafkaPort,KafkaAddress2:KafkaPort',
        'properties.group.id' = 'GroupId',
        'scan.startup.mode' = 'latest-offset',
        "format" = "csv",
        "csv.field-delimiter" = "\u0001",
        "csv.quote-character" = "''"
      CREATE TABLE printSink (
        `topic` String,
        `partition` int,
        `headers` MAP<STRING, BYTES>,
        `leaderEpoch` INT,
        `offset` bigint,
        `timestamp` TIMESTAMP(3),
        `timestampType` string,
        `message` string -- Indicates that data written by users is read from Kafka.
      ) WITH (
        'connector' = 'print'
      insert into printSink select * from orders;
      If you need to read the value of each field instead of the entire message, use the following statements:
        order_id string,
        order_channel string,
        order_time string,
        pay_amount double,
        real_pay double,
        pay_time string,
        user_id string,
        user_name string,
        area_id string
      ) WITH (
        'topic' = '<yourTopic>',
        "format" = "json"
        `topic` String,
        `partition` int,
        `leaderEpoch` INT,
        `offset` bigint,
        order_id string,
        order_time string,
        pay_amount double,
        real_pay double,
        pay_time string,
        user_id string,
        user_name string,
        area_id string
      ) WITH (
    4. Send the following data to the corresponding topics in Kafka:
      {"order_id":"202103241000000001", "order_channel":"webShop", "order_time":"2021-03-24 10:00:00", "pay_amount":"100.00", "real_pay":"100.00", "pay_time":"2021-03-24 10:02:03", "user_id":"0001", "user_name":"Alice", "area_id":"330106"}
      {"order_id":"202103241606060001", "order_channel":"appShop", "order_time":"2021-03-24 16:06:06", "pay_amount":"200.00", "real_pay":"180.00", "pay_time":"2021-03-24 16:10:06", "user_id":"0001", "user_name":"Alice", "area_id":"330106"}
      {"order_id":"202103251202020001", "order_channel":"miniAppShop", "order_time":"2021-03-25 12:02:02", "pay_amount":"60.00", "real_pay":"60.00", "pay_time":"2021-03-25 12:03:00", "user_id":"0002", "user_name":"Bob", "area_id":"330110"}
    5. Perform the following operations to view the output:
      1. Log in to the DLI console. In the navigation pane, choose Job Management > Flink Jobs.
      2. Click the name of the corresponding Flink job, choose Run Log, click OBS Bucket, and locate the folder of the log you want to view according to the date.
      3. Go to the folder of the date, find the folder whose name contains taskmanager, download the taskmanager.out file, and view result logs.
      The data result is as follows:
      +I(fz-source-json,0,{},0,243,2021-12-27T09:23:32.253,CreateTime,{"order_id":"202103241000000001", "order_channel":"webShop", "order_time":"2021-03-24 10:00:00", "pay_amount":"100.00", "real_pay":"100.00", "pay_time":"2021-03-24 10:02:03", "user_id":"0001", "user_name":"Alice", "area_id":"330106"})
      +I(fz-source-json,0,{},0,244,2021-12-27T09:23:39.655,CreateTime,{"order_id":"202103241606060001", "order_channel":"appShop", "order_time":"2021-03-24 16:06:06", "pay_amount":"200.00", "real_pay":"180.00", "pay_time":"2021-03-24 16:10:06", "user_id":"0001", "user_name":"Alice", "area_id":"330106"})
      +I(fz-source-json,0,{},0,245,2021-12-27T09:23:48.405,CreateTime,{"order_id":"202103251202020001", "order_channel":"miniAppShop", "order_time":"2021-03-25 12:02:02", "pay_amount":"60.00", "real_pay":"60.00", "pay_time":"2021-03-25 12:03:00", "user_id":"0002", "user_name":"Bob", "area_id":"330110"})
  • Example 2: Use the Kafka source table and Print result table to read JSON data from Kafka and output it to the log file.
        order_id string,
        order_time timestamp(3),
        pay_amount double,
        real_pay double,
        pay_time string,
        user_id string,
        user_name string,
        area_id string
      ) WITH (
        "format" = "json"
        order_id string,
        pay_amount double,
        real_pay double,
        pay_time string,
        user_id string,
        user_name string,
        area_id string
      ) WITH (
    4. Send the following test data to the corresponding topics in Kafka:
      +I(202103241000000001,webShop,2021-03-24T10:00,100.0,100.0,2021-03-2410:02:03,0001,Alice,330106)
      +I(202103241606060001,appShop,2021-03-24T16:06:06,200.0,180.0,2021-03-2416:10:06,0001,Alice,330106)
      +I(202103251202020001,miniAppShop,2021-03-25T12:02:02,60.0,60.0,2021-03-2512:03:00,0002,Bob,330110)
Example (SASL_SSL Enabled for the Kafka Cluster)
  • Example 1: Enable SASL_SSL authentication for the DMS cluster.
    Create a Kafka cluster for DMS, enable SASL_SSL, download the SSL certificate, and upload the downloaded certificate client.jks to an OBS bucket.
    CREATE TABLE ordersSource (
      order_id string,
      pay_amount double,
      real_pay double,
      pay_time string,
      user_id string,
      user_name string,
      area_id string
    ) WITH (
      'topic' = 'xx',
      'properties.bootstrap.servers' = 'xx:9093,xx:9093,xx:9093',
      'properties.connector.auth.open' = 'true',
      'properties.ssl.truststore.location' = 'obs://xx/xx.jks',  -- Location where the user uploads the certificate to
      'properties.sasl.mechanism' = 'PLAIN',  --  Value format: SASL_PLAINTEXT
      'properties.security.protocol' = 'SASL_SSL',
      'properties.sasl.jaas.config' = 'org.apache.kafka.common.security.plain.PlainLoginModule required username=\"xx\" password=\"xx\";', -- Account and password set when the Kafka cluster is created
      "format" = "json"
    CREATE TABLE ordersSink (
      order_id string,
      pay_amount double,
      real_pay double,
      pay_time string,
      user_id string,
      user_name string,
      area_id string
    ) WITH (
      'topic' = 'xx',
      "format" = "json"
    insert into ordersSink select * from ordersSource;
  • Example 2: Enable Kafka SASL_SSL authentication for the MRS cluster.
    • Enable Kerberos authentication for the MRS cluster.
    • Click the Components tab and click Kafka. In the displayed page, click the Service Configuration tab, locate the security.protocol, and set it to SASL_SSL.
    • Download the user credential. Log in to the MRS Manager of the MRS cluster and choose System > Permission > User. Locate the row that contains the target user, click More, and select Download Authentication Credential.
      Obtain the truststore.jks file using the authentication credential and store the credential and truststore.jks file in OBS.
    • If "Message stream modified (41)" is displayed, the JDK version may be incorrect. Change the JDK version in the sample code to a version earlier than 8u_242 or delete the renew_lifetime = 0m configuration item from the krb5.conf configuration file.
    • Set the port to the sasl_ssl.port configured in the Kafka service configuration.
    • In the following statements, set security.protocol to SASL_SSL.
      order_id string,
      pay_amount double,
      real_pay double,
      pay_time string,
      user_id string,
      user_name string,
      area_id string
    ) WITH (
      'topic' = 'xx',
      'properties.bootstrap.servers' = 'xx:21009,xx:21009',
      'properties.sasl.kerberos.service.name' = 'kafka',
      'properties.connector.kerberos.principal' = 'xx', --Username
      'properties.connector.kerberos.krb5' = 'obs://xx/krb5.conf',
      'properties.connector.kerberos.keytab' = 'obs://xx/user.keytab',
      'properties.ssl.truststore.location' = 'obs://xx/truststore.jks',
      'properties.ssl.truststore.password' = 'xx',  -- Password set for generating truststore.jks
      'properties.sasl.mechanism' = 'GSSAPI',
      "format" = "json"
      order_id string,
      pay_amount double,
      real_pay double,
      pay_time string,
      user_id string,
      user_name string,
      area_id string
    ) WITH (
      'topic' = 'xx',
      "format" = "json"
  • Example 3: Enable Kerberos SASL_PAINTEXT authentication for the MRS cluster
    • Click the Components tab and click Kafka. In the displayed page, click the Service Configuration tab, locate the security.protocol, and set it to SASL_PLAINTEXT.
    • Log in to the MRS Manager of the MRS cluster and download the user credential. Choose System > Permission > User. Locate the row that contains the target user, choose More > Download Authentication Credential. Upload the credential to OBS.
    • If error message "Message stream modified (41)" is displayed, the JDK version may be incorrect. Change the JDK version in the sample code to a version earlier than 8u_242 or delete the renew_lifetime = 0m configuration item from the krb5.conf configuration file.
    • Set the port to the sasl.port configured in the Kafka service configuration.
    • In the following statements, set security.protocol to SASL_PLAINTEXT.
    CREATE TABLE ordersSources (
      order_id string,
      pay_amount double,
      real_pay double,
      pay_time string,
      user_id string,
      user_name string,
      area_id string
    ) WITH (
      'topic' = 'xx',
      'properties.bootstrap.servers' = 'xx:21007,xx:21007',
      'properties.security.protocol' = 'SASL_PLAINTEXT',
      "format" = "json"
      order_id string,
      pay_amount double,
      real_pay double,
      pay_time string,
      user_id string,
      user_name string,
      area_id string
    ) WITH (
      'topic' = 'xx',
      "format" = "json"
  • Example 4: Use SSL for the MRS cluster
    • Do not enable Kerberos authentication for the MRS cluster.
    • Set the port to the ssl.port configured in the Kafka service configuration.
    • In the following statements, set security.protocol to SSL.
    • Set ssl.mode.enable to true.
        order_id string,
        pay_amount double,
        real_pay double,
        pay_time string,
        user_id string,
        user_name string,
        area_id string
      ) WITH (
        'topic' = 'xx',
        'properties.security.protocol' = 'SSL',
        "format" = "json"
        order_id string,
        pay_amount double,
        real_pay double,
        pay_time string,
        user_id string,
        user_name string,
        area_id string
      ) WITH (
FAQ
  • Q: What should I do if the Flink job execution fails and the log contains the following error information?
    org.apache.kafka.common.errors.TimeoutException: Timeout expired while fetching topic metadata
    A: The datasource connection is not bound, the binding fails, or the security group of the Kafka cluster is not configured to allow access from the network segment of the DLI queue. Configure the datasource connection by referring to Enhanced Datasource Connection or configure the security group of the Kafka cluster to allow access from the DLI queue.
    Caused by: java.lang.RuntimeException: RealLine:45;Table 'default_catalog.default_database.printSink' declares persistable metadata columns, but the underlying DynamicTableSink doesn't implement the SupportsWritingMetadata interface. If the column should not be persisted, it can be declared with the VIRTUAL keyword.
    A: The metadata type is defined in the sink table, but the Print connector does not support deletion of matadata from the sink table.
