Updated on 2025-11-13 GMT+08:00
HBase Source Table
Function
Create a source stream to obtain data from HBase as input for jobs. HBase is a reliable, high-performance, scalable, column-oriented distributed cloud storage system suitable for mass data storage and distributed computing scenarios. You can use HBase to establish a storage system capable of handling terabytes to petabytes of data, easily filtering and analyzing data with millisecond response times, swiftly uncovering data insights. DLI can read data from HBase for filtering, analysis, and data dumping.
  • An enhanced datasource connection has been created for DLI to connect to HBase, so that jobs can run on the dedicated queue of DLI and you can set the security group rules as required.
  • If MRS HBase is used, IP addresses of all hosts in the MRS cluster have been added to host information of the enhanced datasource connection.
    For details, see Modifying Host Information.
  • In Flink cross-source development scenarios, there is a risk of password leakage if datasource authentication information is directly configured. You are advised to use the datasource authentication provided by DLI.
    For details about datasource authentication, see Datasource Authentication Overview.
Precautions
  • When creating a Flink OpenSource SQL job, you need to set Flink Version to 1.12 on the Running Parameters tab of the job editing page, select Save Job Log, and set the OBS bucket for saving job logs.
  • The column families in created HBase source table must be declared as the ROW type, the field names map the column family names, and the nested field names map the column qualifier names.
    There is no need to declare all the families and qualifiers in the schema. Users can declare what is used in the query. Except the ROW type fields, the single atomic type field (for example, STRING or BIGINT) will be recognized as the HBase rowkey. The rowkey field can be an arbitrary name, but should be quoted using backticks if it is a reserved keyword.
Syntax
create table hbaseSource (
  attr_name attr_type
  (',' attr_name attr_type)*
  (',' watermark for rowtime_column_name as watermark-strategy_expression)
  ','PRIMARY KEY (attr_name, ...) NOT ENFORCED)
with (
  'connector' = 'hbase-2.2',
  'table-name' = '',
  'zookeeper.quorum' = ''
Parameters
Table 1 Parameter description
Mandatory
Default Value
Data Type
connector
Yes
None
String
Connector to be used. Set this parameter to hbase-2.2.
table-name
Yes
None
String
Name of the HBase table to connect.
zookeeper.quorum
Yes
None
String
HBase ZooKeeper quorum, in the format of "ZookeeperAddress:ZookeeperPort".
The following uses an MRS HBase cluster as an example to describe how to obtain the IP address and port number of ZooKeeper used by this parameter:
  • On MRS Manager, choose Cluster and click the name of the desired cluster. Choose Services > ZooKeeper > Instance, and obtain the IP address of the ZooKeeper instance.
  • On MRS Manager, choose Cluster and click the name of the desired cluster. Choose Services > ZooKeeper > Configurations > All Configurations, search for the clientPort parameter, and obtain its value, that is, the ZooKeeper port number.
zookeeper.znode.parent
No
/hbase
String
Root directory in ZooKeeper. The default value is /hbase.
null-string-literal
No
None
String
Representation for null values for string fields.
HBase source encodes/decodes empty bytes as null values for all types except the string type.
krb_auth_name
No
None
String
Name of datasource authentication of the Kerberos type created on DLI.
Data Type Mapping
HBase stores all data as byte arrays. The data needs to be serialized and deserialized during read and write operations.
When serializing and de-serializing, Flink HBase connector uses utility class org.apache.hadoop.hbase.util.Bytes provided by HBase (Hadoop) to convert Flink data types to and from byte arrays.
Flink HBase connector encodes null values to empty bytes, and decodes empty bytes to null values for all data types except the string type. For string type, the null literal is determined by the null-string-literal option.
Table 2 Data type mapping
Flink SQL Type
HBase Conversion
CHAR/VARCHAR/STRING
byte[] toBytes(String s)
String toString(byte[] b)
BOOLEAN
byte[] toBytes(boolean b)
boolean toBoolean(byte[] b)
BINARY/VARBINARY
Returns byte[] as is.
DECIMAL
byte[] toBytes(BigDecimal v)
BigDecimal toBigDecimal(byte[] b)
TINYINT
new byte[] { val }
bytes[0] // returns first and only byte from bytes
SMALLINT
byte[] toBytes(short val)
short toShort(byte[] bytes)
INT
byte[] toBytes(int val)
int toInt(byte[] bytes)
BIGINT
byte[] toBytes(long val)
long toLong(byte[] bytes)
FLOAT
byte[] toBytes(float val)
float toFloat(byte[] bytes)
DOUBLE
byte[] toBytes(double val)
double toDouble(byte[] bytes)
DATE
Number of days since 1970-01-01 00:00:00 UTC. The value is an integer.
TIME
Number of milliseconds since 1970-01-01 00:00:00 UTC. The value is an integer.
TIMESTAMP
Number of milliseconds since 1970-01-01 00:00:00 UTC. The value is of the long type.
ARRAY
Not supported
MAP/MULTISET
Not supported
ROW
Not supported
Example
In this example, data is read from the HBase data source and written to the Print result table. The procedure is as follows (the HBase versions used in this example are 1.3.1, 2.1.1, and 2.2.3):
  1. Create an enhanced datasource connection in the VPC and subnet where HBase locates, and bind the connection to the required Flink queue. For details, see Enhanced Datasource Connections. Add MRS host information in the enhanced datasource connection by referring to Modifying Host Information.
  2. Set HBase cluster security groups and add inbound rules to allow access from the Flink job queue. Test the connectivity using the HBase address by referring to Testing Address Connectivity. If the connection is successful, the datasource is bound to the queue. Otherwise, the binding fails.
  3. Use the HBase shell to create HBase table order that has only one column family detail. For details, see Using HBase from Scratch. The creation statement is as follows:
    create 'order', {NAME => 'detail'}
  4. Run the following command in the HBase shell to insert a data record:
    put 'order', '202103241000000001', 'detail:order_channel','webShop'
    put 'order', '202103241000000001', 'detail:order_time','2021-03-24 10:00:00'
    put 'order', '202103241000000001', 'detail:pay_amount','100.00'
    put 'order', '202103241000000001', 'detail:real_pay','100.00'
    put 'order', '202103241000000001', 'detail:pay_time','2021-03-24 10:02:03'
    put 'order', '202103241000000001', 'detail:user_id','0001'
    put 'order', '202103241000000001', 'detail:user_name','Alice'
    put 'order', '202103241000000001', 'detail:area_id','330106'
  5. Create a Flink OpenSource SQL job. Enter the following job script and submit the job. The job script uses the HBase data source and the Print result table.
    When you create a job, set Flink Version to 1.12 on the Running Parameters tab. Select Save Job Log, and specify the OBS bucket for saving job logs. Change the values of the parameters in bold as needed in the following script.
      order_id string,-- Indicates the unique rowkey.
      detail Row( -- Indicates the column family.
        order_channel string,
        order_time string,
        pay_amount string,
        real_pay string,
        pay_time string,
        user_id string,
        user_name string,
        area_id string),
      primary key (order_id) not enforced
    ) with (
       'table-name' = 'order',
       'zookeeper.quorum' = 'ZookeeperAddress:ZookeeperPort'
    create table printSink (
      order_id string,
      order_time string,
      pay_amount string,
      real_pay string,
      pay_time string,
      user_id string,
      user_name string,
      area_id string
    ) with (
     'connector' = 'print'
    insert into printSink select order_id, detail.order_channel,detail.order_time,detail.pay_amount,detail.real_pay,
    detail.pay_time,detail.user_id,detail.user_name,detail.area_id from hbaseSource;
  6. Perform the following operations to view the data result in the taskmanager.out file:
    1. Log in to the DLI console. In the navigation pane, choose Job Management > Flink Jobs.
    2. Click the name of the corresponding Flink job, choose Run Log, click OBS Bucket, and locate the folder of the log you want to view according to the date.
    3. Go to the folder of the date, find the folder whose name contains taskmanager, download the taskmanager.out file, and view result logs.
    The data result is as follows:
    +I(202103241000000001,webShop,2021-03-24 10:00:00,100.00,100.00,2021-03-24 10:02:03,0001,Alice,330106)
FAQ
  • Q: What should I do if the Flink job execution fails and the log contains the following error information?
    java.lang.IllegalArgumentException: offset (0) + length (8) exceed the capacity of the array: 6
    A: If data in the HBase table is imported in other modes, the data is represented in the string format. Therefore, this error is reported when other data formats are used. Change the type of the non-string fields in the HBase source table created by Flink to the string format.
    org.apache.zookeeper.ClientCnxn$SessionTimeoutException: Client session timed out, have not heard from server in 90069ms for connection id 0x0
    A: The datasource connection is not bound, the binding fails, or the security group of the HBase cluster is not configured to allow access from the network segment of the DLI queue. Configure the datasource connection by referring to Enhanced Datasource Connections or configure the security group of the HBase cluster to allow access from the DLI queue.
