Updated on 2025-02-11 GMT+08:00
OBS Authorization
  • You have configured the Java SDK environment by following the instructions provided Overview.
  • You have initialized the DLI Client by following the instructions provided in Initializing the DLI Client.
Example Code
You can use the API to grant operation rights on OBS buckets to DLI to save data and run logs of users' jobs.
The example code is as follows:
3
4
5
6
7
private static void authorizeBucket(DLIClient client) throws DLIException {
        String bucketName ="obs_name";
        ObsBuckets obsBuckets = new ObsBuckets();
        obsBuckets.addObsBucketsItem(bucketName);
        GlobalResponse res = client.authorizeBucket(obsBuckets);
        System.out.println(res);
