Copying an Object Version (SDK for Java)
Function
This API copies an object version in a specified bucket.
You can call ObsClient.copyObject to copy an object version by specifying the version ID (versionId).
If you have any questions during development, post them on the Issues page of GitHub.
Restrictions
- To copy an object, you must be the bucket owner or have the required permission (obs:object:PutObject in IAM or PutObject in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
- You must have the read permission on the source object.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
- The object copy request carries the information about the source bucket and object to be copied in the header field. The message body cannot be carried.
- Cross-bucket replication in the same region is supported, but cross-region replication is not supported.
- An object copy can be up to 5 GB in size. If the source object exceeds 5 GB, you can only perform a multipart copy.
- If the source object is in the Archive storage class, you must restore it first.
Method
obsClient.copyObject(CopyObjectRequest request)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| request | Yes | Explanation: Request parameters for copying an object. For details, see Table 2. |
| bucketName | String | Yes | Explanation: Target bucket name. Restrictions:
Default value: None |
| objectKey | String | Yes | Explanation: Target object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
| sseKmsHeader | No | Explanation: Server-side encryption header used for encrypting the target object. For details, see Table 3. Default value: None | |
| sseCHeader | No | Explanation: Server-side encryption header used for encrypting the target object. For details, see Table 4. Default value: None | |
| acl | No | Explanation: ACL that can be pre-defined during the object copy. For details, see Table 8. Default value: None | |
| successRedirectLocation | String | No | Explanation: Address (URL) to which a successfully answered request is redirected.
| sourceBucketName | String | Yes | Explanation: Name of the source bucket. Restrictions:
| sourceObjectKey | String | Yes | Explanation: Source object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
| newObjectMetadata | No | Explanation: User-defined metadata of the target object. For details, see Table 15. Restrictions: newObjectMetadata must be used together with replaceMetadata. Default value: None | |
| replaceMetadata | boolean | No | Explanation: Whether to rewrite the metadata of the source object. Restrictions: replaceMetadata must be used together with newObjectMetadata. Value range: true: The metadata of the source object is rewritten. false: The metadata of the source object is not rewritten. Default value: None |
| ifModifiedSince | java.util.Date | No | Explanation: The source object is copied if it has been modified since the specified time; otherwise, an exception is thrown. Default value: None |
| ifUnmodifiedSince | java.util.Date | No | Explanation: If the source object has not been modified since the specified time, it is copied. Otherwise, an exception is thrown. Default value: None |
| ifMatchTag | String | No | Explanation: Preset ETag. If the ETag of the object to be downloaded is the same as the preset ETag, the object is returned. Otherwise, an error is returned. The ETag of the source object is the MD5 value of it. Restrictions:
Value range: The value must contain 32 characters. Default value: None |
| ifNoneMatchTag | String | No | Explanation: Preset ETag. If the ETag of the object to be downloaded is different from the preset ETag, the object is returned. Otherwise, an error is returned. Value range: The value must contain 32 characters. Default value: None |
| versionId | String | No | Explanation: Version ID of the source object. Value range: The value must contain 32 characters. Default value: None |
| sseCHeaderSource | No | Explanation: Server-side decryption header used for decrypting the source object. For details, see Table 4. Default value: None |
| encryption | Yes | Explanation: SSE-KMS is used for encrypting objects on the server side. Value range: kms. For details, see Table 5. Default value: None | |
| sseAlgorithm | No | Explanation: Encryption algorithm. Restrictions: Only KMS is supported. Value range: See Table 6. Default value: None | |
| kmsKeyId | String | No | Explanation: ID of the KMS master key when SSE-KMS is used. Value range: Valid value formats are as follows:
In the preceding formats:
Default value:
| algorithm | Yes | Explanation: SSE-C is used for encrypting objects on the server side. Value range: AES256, indicating AES is used to encrypt the object in SSE-C. For details, see Table 7. Default value: None | |
| sseAlgorithm | No | Explanation: Encryption algorithm. Restrictions: Only AES256 is supported. Value range: See Table 6. Default value: None | |
| sseCKey | byte[] | Yes | Explanation: Key used for encrypting the object when SSE-C is used, in byte[] format. Default value: None |
| sseCKeyBase64 | String | No | Explanation: Base64-encoded key used for encrypting the object when SSE-C is used. Default value: None |
| owner | No | Explanation: Bucket owner information. For details, see Table 9. | |
| delivered | boolean | No | Explanation: Whether the bucket ACL is applied to all objects in the bucket. Value range: true: The bucket ACL is applied to all objects in the bucket. false: The bucket ACL is not applied to any objects in the bucket. Default value: false |
| grants | Set<GrantAndPermission> | No | Explanation: Grantee information. For details, see Table 10. |
| id | String | Yes | Explanation: Account (domain) ID of the bucket owner. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
| displayName | String | No | Explanation: Account name of the owner. Value range: To obtain the account name, see How Do I Get My Account ID and User ID? Default value: None |
| grantee | Yes | Explanation: Grantees (users or user groups). For details, see Table 12. | |
| permission | Yes | Explanation: Permissions to grant. Value range: See Table 11. Default value: None | |
| Constant | Default Value | Description |
| PERMISSION_READ | READ | Read permission. A grantee with this permission for a bucket can obtain the list of objects, multipart uploads, bucket metadata, and object versions in the bucket. A grantee with this permission for an object can obtain the object content and metadata. |
| PERMISSION_WRITE | WRITE | Write permission. A grantee with this permission for a bucket can upload, overwrite, and delete any object or part in the bucket. This permission is not available for objects. |
| PERMISSION_READ_ACP | READ_ACP | Permission to read an ACL. A grantee with this permission can obtain the ACL of a bucket or object. A bucket or object owner has this permission for their bucket or object by default. |
| PERMISSION_WRITE_ACP | WRITE_ACP | Permission to modify an ACL. A grantee with this permission can update the ACL of a bucket or object. A bucket or object owner has this permission for their bucket or object by default. This permission allows the grantee to change the access control policies, meaning the grantee has full control over a bucket or object. |
| PERMISSION_FULL_CONTROL | FULL_CONTROL | Full control access, including read and write permissions for a bucket and its ACL, or for an object and its ACL. A grantee with this permission for a bucket has READ, WRITE, READ_ACP, and WRITE_ACP permissions for the bucket. A grantee with this permission for an object has READ, READ_ACP, and WRITE_ACP permissions for the object. |
| Yes | Explanation: Grantee (user) information. For details, see Table 13. | ||
| Yes | Explanation: Grantee (user group) information. Value range: See Table 14. Default value: None |
| grantId | String | Yes if Type is set to GranteeUser | Explanation: Account (domain) ID of the grantee. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
| displayName | String | No | Explanation: Account name of the grantee. Value range: To obtain the account name, see How Do I Get My Account ID and User ID? Default value: None |
| Constant | Description |
| ALL_USERS | All users. |
| AUTHENTICATED_USERS | Authorized users. This constant is deprecated. |
| LOG_DELIVERY | Log delivery group. This constant is deprecated. |
| contentLength | Long | No | Explanation: Object size. Restrictions:
Default value: If this parameter is not specified, the SDK automatically calculates the size of the object. |
| contentType | String | No | Explanation: MIME type of the object file. MIME type is a standard way of describing a data type and is used by the browser to decide how to display data. Value range: See What Is Content-Type (MIME)? (Java SDK) Default value: If this parameter is not specified, the SDK determines the file type based on the suffix of the object name and assigns a value to the parameter. For example, if the suffix of the object name is .xml, the object is an application/xml file. If the suffix is .html, the object is a text/html file. |
| contentEncoding | String | No | Explanation: Content-Encoding header in the response. It specifies which encoding is applied to the object. Default value: None |
| contentDisposition | String | No | Explanation: Provides a default file name for the requested object. When the object with the default file name is being downloaded or accessed, the content is displayed as part of a web page in the browser or as an attachment in a download dialog box. Default value: None |
| cacheControl | String | No | Explanation: Cache-Control header in the response. It specifies the cache behavior of the web page when an object is downloaded. Default value: None |
| contentLanguage | String | No | Explanation: Language or language combination for visitors to customize and use. For details, see the definition of ContentLanguage in the HTTP protocol. Default value: None |
| expires | String | No | Explanation: The time a cached web page object expires. Restrictions: The time must be in the GMT format. Default value: None |
| contentMd5 | String | No | Explanation: Base64-encoded MD5 value of the file data. It is provided for the OBS server to verify data integrity. The OBS server will compare this MD5 value with the MD5 value calculated based on the file data. If the two values are not the same, HTTP status code 400 is returned. Restrictions:
Value range: Base64-encoded 128-bit MD5 value of the request body calculated according to RFC 1864. Example: n58IG6hfM7vqI4K0vnWpog== Default value: None |
| storageClass | No | Explanation: Storage class of an object that can be specified at object creation. If you do not specify this header, the object inherits the storage class of the bucket. Value range: See Table 16. Default value: None | |
| webSiteRedirectLocation | String | No | Explanation: If the bucket is configured with website hosting, the request for obtaining the object can be redirected to another object in the bucket or an external URL. This parameter specifies the address the request for the object is redirected to. The request is redirected to an object anotherPage.html in the same bucket: WebsiteRedirectLocation:/anotherPage.html The request is redirected to an external URL http://www.example.com/: WebsiteRedirectLocation:http://www.example.com/ Restrictions:
| nextPosition | long | No | Explanation: Start position for the next append upload. Value range: 0 to the object length, in bytes. Default value: None |
| appendable | boolean | No | Explanation: Whether the object is appendable. Value range: true: The object is appendable. false: The object is not appendable. Default value: None |
| userMetadata | Map<String, Object> | No | Explanation: User-defined metadata of the object. To define it, you can add a header starting with x-obs-meta- in the request. In Map, the String key indicates the name of the user-defined metadata that starts with x-obs-meta-, and the Object value indicates the value of the user-defined metadata. To obtain the user-defined metadata of an object, use ObsClient.getObjectMetadata. For details, see Obtaining Object Metadata (SDK for Java). Restrictions:
Responses
| Parameter | Type | Description |
| statusCode | int | Explanation: HTTP status code. Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
| responseHeaders | Map<String, Object> | Explanation: Response header list, composed of tuples. In a tuple, the String key indicates the name of the header, and the Object value indicates the value of the header. Default value: None |
| lastModified | java.util.Date | Explanation: Last time the target object was modified. Default value: None |
| etag | String | Explanation: ETag of the target object. Base64-encoded, 128-bit MD5 value of an object. ETag is the unique identifier of the object contents and is used to determine whether the contents of an object are changed. For example, if the ETag value is A when an object is uploaded and is B when the object is downloaded, this indicates the contents of the object are changed. The ETag reflects changes only to the contents of an object, not its metadata. Objects created by the upload and copy operations have unique ETags after being encrypted using MD5. Restrictions: If an object is encrypted using server-side encryption, the ETag is not the MD5 value of the object. Value range: The value must contain 32 characters. Default value: None |
| versionId | String | Explanation: Version ID of the target object. Value range: The value must contain 32 characters. Default value: None |
| copySourceVersionId | String | Explanation: Version ID of the source object. Value range: The value must contain 32 characters. Default value: None |
| storageClass | Explanation: Storage class of the target object. Value range: See Table 16. Default value: None |
Code Examples
This example sets a version ID to copy object versions of sourceobjectname from bucket sourceexamplebucket to another bucket.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 | import com.obs.services.ObsClient; import com.obs.services.exception.ObsException; import com.obs.services.model.CopyObjectRequest; public class CopyObject001 { public static void main(String[] args) { // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. // Obtain an AK/SK pair and a security token using environment variables or import them in other ways. // String securityToken = System.getenv("SECURITY_TOKEN"); // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in your actual situation. String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com"; // Obtain an endpoint using environment variables or import it in other ways. //String endPoint = System.getenv("ENDPOINT"); // Create an ObsClient instance. // Use the permanent AK/SK pair to initialize the client. ObsClient obsClient = new ObsClient(ak, sk,endPoint); // Use the temporary AK/SK pair and security token to initialize the client. // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint); try { // Copy object versions. CopyObjectRequest request = new CopyObjectRequest(); request.setSourceBucketName("sourceexamplebucket"); request.setSourceObjectKey("sourceobjectname"); // Set the version ID of the object to be copied. request.setVersionId("versionid"); request.setDestinationBucketName("destexamplebucket"); request.setDestinationObjectKey("destobjectname"); obsClient.copyObject(request); System.out.println("copyObject successfully"); } catch (ObsException e) { System.out.println("copyObject failed"); // Request failed. Print the HTTP status code. System.out.println("HTTP Code:" + e.getResponseCode()); // Request failed. Print the server-side error code. System.out.println("Error Code:" + e.getErrorCode()); // Request failed. Print the error details. System.out.println("Error Message:" + e.getErrorMessage()); // Request failed. Print the request ID. System.out.println("Request ID:" + e.getErrorRequestId()); System.out.println("Host ID:" + e.getErrorHostId()); e.printStackTrace(); } catch (Exception e) { System.out.println("copyObject failed"); // Print other error information. e.printStackTrace(); } } } |
Helpful Links
