Copying an Object (SDK for Java)
Function
This API copies an object stored in OBS to another path, with a copy created during the process. You can create a copy of an object up to 5 GB in a single operation.
If you have any questions during development, post them on the Issues page of GitHub.
Restrictions
- To copy an object, you must be the bucket owner or have the required permission (obs:object:PutObject in IAM or PutObject in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
- You must have the read permission on the source object.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
- The object copy request carries the information about the source bucket and object to be copied in the header field. The message body cannot be carried.
- Cross-bucket replication in the same region is supported, but cross-region replication is not supported.
- An object copy can be up to 5 GB in size. If the source object exceeds 5 GB, you can only perform a multipart copy.
- If the source object is in the Archive storage class, you must restore it first.
Method
obsClient.copyObject(CopyObjectRequest request)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
request |
Yes |
Explanation: Request parameters for copying an object. For details, see Table 2. |
Parameter |
Type |
Description |
bucketName |
String |
Yes |
Explanation: Target bucket name. Restrictions:
Default value: None |
objectKey |
String |
Yes |
Explanation: Target object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
sseKmsHeader |
No |
Explanation: Server-side encryption header used for encrypting the target object. For details, see Table 3. Default value: None |
sseCHeader |
No |
Explanation: Server-side encryption header used for encrypting the target object. For details, see Table 4. Default value: None |
acl |
No |
Explanation: An ACL specified for the object. You can use either a pre-defined or a user-defined ACL. For more information about ACLs, see ACLs. Value range:
Default value: AccessControlList.REST_CANNED_PRIVATE |
successRedirectLocation |
String |
No |
Explanation: Address (URL) to which a successfully answered request is redirected.
sourceBucketName |
String |
Yes |
Explanation: Name of the source bucket. Restrictions:
sourceObjectKey |
String |
Yes |
Explanation: Source object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
newObjectMetadata |
No |
Explanation: User-defined metadata of the target object. For details, see Table 16. Restrictions: replaceMetadata must be used together with newObjectMetadata. Default value: None |
replaceMetadata |
boolean |
No |
Explanation: Whether to rewrite the metadata of the source object. Restrictions: replaceMetadata must be used together with newObjectMetadata. Value range: true: The metadata of the source object is rewritten. false: The metadata of the source object is not rewritten. Default value: None |
ifModifiedSince |
java.util.Date |
No |
Explanation: The source object is copied if it has been modified since the specified time; otherwise, an exception is thrown. Restrictions:
ifUnmodifiedSince |
java.util.Date |
No |
Explanation: If the source object has not been modified since the specified time, it is copied. Otherwise, an exception is thrown. Restrictions:
ifMatchTag |
String |
No |
Explanation: Preset ETag. If the ETag of the source object is the same as the preset ETag, the object is returned. Otherwise, an error is returned. The ETag of the source object is the MD5 value of it. Restrictions:
Value range: The value must contain 32 characters. Default value: None |
ifNoneMatchTag |
String |
No |
Explanation: Preset ETag. If the ETag of the source object is different from the preset ETag, the object is returned. Otherwise, an error is returned. The ETag of the source object is the MD5 value of it. Restrictions:
versionId |
String |
No |
Explanation: Source object version ID. Value range: The value must contain 32 characters. Default value: None |
sseCHeaderSource |
No |
Explanation: Server-side decryption header used for decrypting the source object. For details, see Table 4. Default value: None |
Parameter |
Type |
Description |
encryption |
Yes |
Explanation: SSE-KMS is used for encrypting objects on the server side. Value range: kms. For details, see Table 5. Default value: None |
sseAlgorithm |
No |
Explanation: Encryption algorithm. Restrictions: Only KMS is supported. Value range: See Table 6. Default value: None |
kmsKeyId |
String |
No |
Explanation: ID of the KMS master key when SSE-KMS is used. Value range: Valid value formats are as follows:
In the preceding formats:
Default value:
Parameter |
Type |
Description |
algorithm |
Yes |
Explanation: SSE-C is used for encrypting objects on the server side. Value range: AES256, indicating AES is used to encrypt the object in SSE-C. For details, see Table 7. Default value: None |
sseAlgorithm |
No |
Explanation: Encryption algorithm. Restrictions: Only AES256 is supported. Value range: See Table 6. Default value: None |
sseCKey |
byte[] |
Yes |
Explanation: Key used for encrypting the object when SSE-C is used, in byte[] format. Default value: None |
sseCKeyBase64 |
String |
No |
Explanation: Base64-encoded key used for encrypting the object when SSE-C is used. Default value: None |
Constant |
Description |
Private read/write. A bucket or object can only be accessed by its owner. |
AccessControlList.REST_CANNED_PUBLIC_READ |
Public read. If this permission is granted on a bucket, anyone can read the object list, multipart uploads, bucket metadata, and object versions in the bucket. If this permission is granted on an object, anyone can read the content and metadata of the object. |
AccessControlList.REST_CANNED_PUBLIC_READ_WRITE |
Public read/write. If this permission is granted on a bucket, anyone can read the object list, multipart uploads, and bucket metadata, and can upload or delete objects, initiate multipart uploads, upload parts, assemble parts, copy parts, and abort multipart upload tasks. If this permission is granted on an object, anyone can read the content and metadata of the object. |
AccessControlList.REST_CANNED_PUBLIC_READ_DELIVERED |
Public read on a bucket as well as objects in the bucket. If this permission is granted on a bucket, anyone can read the object list, multipart tasks, and bucket metadata, and can also read the content and metadata of the objects in the bucket. This permission cannot be granted on objects. |
AccessControlList.REST_CANNED_PUBLIC_READ_WRITE_DELIVERED |
Public read/write on a bucket as well as objects in the bucket. If this permission is granted on a bucket, anyone can read the object list, multipart uploads, and bucket metadata, and can upload or delete objects, initiate multipart upload tasks, upload parts, assemble parts, copy parts, and abort multipart uploads. They can also read the content and metadata of the objects in the bucket. This permission cannot be granted on objects. |
AccessControlList.REST_CANNED_BUCKET_OWNER_FULL_CONTROL |
If this permission is granted on an object, only the bucket and object owners have the full control over the object. By default, if you upload an object to a bucket owned by another user, the bucket owner does not have the permissions on your object. After you grant this permission to the bucket owner, the bucket owner can have full control over your object. For example, if user A uploads object x to user B's bucket, user B does not have the control over object x. If user A sets bucket-owner-full-control for object x, user B then has the control over object x. |
Parameter |
Type |
Type |
owner |
No |
Explanation: Bucket owner information. For details, see Table 10. |
delivered |
boolean |
No |
Explanation: Whether the bucket ACL is applied to all objects in the bucket. Value range: true: The bucket ACL is applied to all objects in the bucket. false: The bucket ACL is not applied to any objects in the bucket. Default value: false |
grants |
Set<GrantAndPermission> |
No |
Explanation: Grantee information. For details, see Table 11. |
Parameter |
Type |
Description |
id |
String |
Yes |
Explanation: Account (domain) ID of the bucket owner. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
displayName |
String |
No |
Explanation: Account name of the owner. Value range: To obtain the account name, see How Do I Get My Account ID and User ID? Default value: None |
Parameter |
Type |
Description |
grantee |
Yes |
Explanation: Grantees (users or user groups). For details, see Table 13. |
permission |
Yes |
Explanation: Permissions to grant. Value range: See Table 12. Default value: None |
delivered |
boolean |
No |
Constant |
Default Value |
Description |
PERMISSION_READ |
READ |
Read permission. A grantee with this permission for a bucket can obtain the list of objects, multipart uploads, bucket metadata, and object versions in the bucket. A grantee with this permission for an object can obtain the object content and metadata. |
PERMISSION_WRITE |
WRITE |
Write permission. A grantee with this permission for a bucket can upload, overwrite, and delete any object or part in the bucket. This permission is not available for objects. |
PERMISSION_READ_ACP |
READ_ACP |
Permission to read an ACL. A grantee with this permission can obtain the ACL of a bucket or object. A bucket or object owner has this permission for their bucket or object by default. |
PERMISSION_WRITE_ACP |
WRITE_ACP |
Permission to modify an ACL. A grantee with this permission can update the ACL of a bucket or object. A bucket or object owner has this permission for their bucket or object by default. This permission allows the grantee to change the access control policies, meaning the grantee has full control over a bucket or object. |
PERMISSION_FULL_CONTROL |
FULL_CONTROL |
Full control access, including read and write permissions for a bucket and its ACL, or for an object and its ACL. A grantee with this permission for a bucket has READ, WRITE, READ_ACP, and WRITE_ACP permissions for the bucket. A grantee with this permission for an object has READ, READ_ACP, and WRITE_ACP permissions for the object. |
Parameter |
Type |
Description |
Yes |
Explanation: Grantee (user) information. For details, see Table 14. |
Yes |
Explanation: Grantee (user group) information. Value range: See Table 15. Default value: None |
Parameter |
Type |
Description |
grantId |
String |
Yes if Type is set to GranteeUser |
Explanation: Account (domain) ID of the grantee. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
displayName |
String |
No |
Explanation: Account name of the grantee. Value range: To obtain the account name, see How Do I Get My Account ID and User ID? Default value: None |
Constant |
Description |
ALL_USERS |
All users. |
AUTHENTICATED_USERS |
Authorized users. This constant is deprecated. |
LOG_DELIVERY |
Log delivery group. This constant is deprecated. |
Parameter |
Type |
Description |
contentLength |
Long |
No |
Explanation: Object size. Restrictions:
Default value: If this parameter is not specified, the SDK automatically calculates the size of the object. |
contentType |
String |
No |
Explanation: MIME type of the object file. MIME type is a standard way of describing a data type and is used by the browser to decide how to display data. Value range: See What Is Content-Type (MIME)? (Java SDK) Default value: If this parameter is not specified, the SDK determines the file type based on the suffix of the object name and assigns a value to the parameter. For example, if the suffix of the object name is .xml, the object is an application/xml file. If the suffix is .html, the object is a text/html file. |
contentEncoding |
String |
No |
Explanation: Content-Encoding header in the response. It specifies which encoding is applied to the object. Default value: None |
contentDisposition |
String |
No |
Explanation: Provides a default file name for the requested object. When the object with the default file name is being downloaded or accessed, the content is displayed as part of a web page in the browser or as an attachment in a download dialog box. Default value: None |
cacheControl |
String |
No |
Explanation: Cache-Control header in the response. It specifies the cache behavior of the web page when an object is downloaded. Default value: None |
contentLanguage |
String |
No |
Explanation: Language or language combination for visitors to customize and use. For details, see the definition of ContentLanguage in the HTTP protocol. Default value: None |
expires |
String |
No |
Explanation: The time a cached web page object expires. Restrictions: The time must be in the GMT format. Default value: None |
contentMd5 |
String |
No |
Explanation: Base64-encoded MD5 value of the object data. It is provided for the OBS server to verify data integrity. The OBS server will compare this MD5 value with the MD5 value calculated based on the file data. If the two values are not the same, HTTP status code 400 is returned. Restrictions:
Value range: Base64-encoded 128-bit MD5 value of the request body calculated according to RFC 1864. Example: n58IG6hfM7vqI4K0vnWpog== Default value: None |
storageClass |
No |
Explanation: Storage class of an object that can be specified at object creation. If you do not specify this header, the object inherits the storage class of the bucket. Value range: See Table 17. Default value: None |
webSiteRedirectLocation |
String |
No |
Explanation: If the bucket is configured with website hosting, the request for obtaining the object can be redirected to another object in the bucket or an external URL. This parameter specifies the address the request for the object is redirected to. The request is redirected to an object anotherPage.html in the same bucket: WebsiteRedirectLocation:/anotherPage.html The request is redirected to an external URL http://www.example.com/: WebsiteRedirectLocation:http://www.example.com/ Restrictions:
nextPosition |
long |
No |
Explanation: Start position for the next append upload. Value range: 0 to the object length, in bytes. Default value: None |
appendable |
boolean |
No |
Explanation: Whether the object is appendable. Value range: true: The object is appendable. false: The object is not appendable. Default value: None |
userMetadata |
Map<String, Object> |
No |
Explanation: User-defined metadata of the object. To define it, you can add a header starting with x-obs-meta- in the request. In Map, the String key indicates the name of the user-defined metadata that starts with x-obs-meta-, and the Object value indicates the value of the user-defined metadata. To obtain the user-defined metadata of an object, use ObsClient.getObjectMetadata. For details, see Obtaining Object Metadata (SDK for Java). Restrictions:
Responses
Parameter |
Type |
Description |
statusCode |
int |
Explanation: HTTP status code. Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
responseHeaders |
Explanation: Response header list, composed of tuples. In a tuple, the String key indicates the name of the header, and the Object value indicates the value of the header. Default value: None |
lastModified |
java.util.Date |
Explanation: Last time the target object was modified. Default value: None |
etag |
String |
Explanation: ETag of the target object. Base64-encoded, 128-bit MD5 value of an object. ETag is the unique identifier of the object contents and is used to determine whether the contents of an object are changed. For example, if the ETag value is A when an object is uploaded and is B when the object is downloaded, this indicates the contents of the object are changed. The ETag reflects changes only to the contents of an object, not its metadata. Objects created by the upload and copy operations have unique ETags after being encrypted using MD5. Restrictions: If an object is encrypted using server-side encryption, the ETag is not the MD5 value of the object. Value range: The value must contain 32 characters. Default value: None |
versionId |
String |
Explanation: Version ID of the target object. Value range: The value must contain 32 characters. Default value: None |
copySourceVersionId |
String |
Explanation: Version ID of the source object. Value range: The value must contain 32 characters. Default value: None |
storageClass |
Explanation: Storage class of the target object. Value range: See Table 17. Default value: None |
Code Example: Copying an Object
This example copies object sourceobjectname from bucket sourcebucketname to bucket destbucketname as object destobjectname.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 |
import com.obs.services.ObsClient;
import com.obs.services.exception.ObsException;
import com.obs.services.model.CopyObjectResult;
public class CopyObject001 {
// Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage.
// Obtain an AK/SK pair on the management console.
// (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage.
// Obtain an AK/SK pair and a security token using environment variables or import them in other ways.
// String securityToken = System.getenv("SECURITY_TOKEN");
// Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in your actual situation.
String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com";
// Obtain an endpoint using environment variables or import it in other ways.
//String endPoint = System.getenv("ENDPOINT");
// Create an ObsClient instance.
// Use the permanent AK/SK pair to initialize the client.
ObsClient obsClient = new ObsClient(ak, sk,endPoint);
// Use the temporary AK/SK pair and security token to initialize the client.
// ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint);
try {
// Copy an object.
CopyObjectResult result =
obsClient.copyObject("sourcebucketname", "sourceobjectname", "destbucketname", "destobjectname");
System.out.println("copyObject successfully");
System.out.println("StatusCode:" + result.getStatusCode());
System.out.println("Etag:" + result.getEtag());
} catch (ObsException e) {
System.out.println("copyObject failed");
// Request failed. Print the HTTP status code.
System.out.println("HTTP Code:" + e.getResponseCode());
// Request failed. Print the server-side error code.
System.out.println("Error Code:" + e.getErrorCode());
// Request failed. Print the error details.
System.out.println("Error Message:" + e.getErrorMessage());
// Request failed. Print the request ID.
System.out.println("Request ID:" + e.getErrorRequestId());
System.out.println("Host ID:" + e.getErrorHostId());
e.printStackTrace();
} catch (Exception e) {
// Print other error information.
Code Example: Copying an Object and Rewriting Object Attributes
This example rewrites object attributes when object sourceobjectname is copied from bucket sourcebucketname to bucket destbucketname as object destobjectname.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 |
import com.obs.services.model.CopyObjectRequest;
import com.obs.services.model.ObjectMetadata;
import com.obs.services.model.StorageClassEnum;
public class CopyObject002 {
try {
// Rewrite object attributes when copying an object.
CopyObjectRequest request = new CopyObjectRequest("sourcebucketname", "sourceobjectname", "destbucketname", "destobjectname");
// Rewrite object attributes.
request.setReplaceMetadata(true);
HashMap<String, String> userHeaders = new HashMap<>();
userHeaders.put("Content-Type","image/jpeg");
request.setUserHeaders(userHeaders);
CopyObjectResult result = obsClient.copyObject(request);
Code Example: Copying an Object Conditionally
This example specifies conditions when object sourceobjectname is copied from bucket sourcebucketname to bucket destbucketname as object destobjectname.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 |
import java.text.SimpleDateFormat;
public class CopyObject003 {
try {
// Set conditions for the copy.
request.setIfModifiedSince(new SimpleDateFormat("yyyy-MM-dd").parse("2016-01-01"));
request.setIfNoneMatchTag("none-match-etag");
Code Example: Copying an Object and Rewriting its ACL
This example rewrites the object ACL when object sourceobjectname is copied from bucket sourcebucketname to bucket destbucketname as object destobjectname.
import com.obs.services.model.AccessControlList;
public class CopyObject004 {
try {
// Rewrite the object ACL when copying the object.
// Rewrite the object ACL to Private.
request.setAcl(AccessControlList.REST_CANNED_PRIVATE);
