Help Center/Object Storage Service/SDK Reference/Java/Object Upload (SDK for Java)/Uploading an Object - File-Based (SDK for Java)
Updated on 2025-12-02 GMT+08:00
Function
This API uploads local files to OBS over the Internet. The file to be uploaded can be of any type.
If you have any questions during development, post them on the Issues page of GitHub.
Restrictions
Method
obsClient.putObject(PutObjectRequestrequest)
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
request
PutObjectRequest
Yes
Explanation:
Request parameters for uploading an object. For details, see Table 2.
Table 2 PutObjectRequest
Type
Mandatory (Yes/No)
bucketName
String
Yes
Explanation:
Bucket name.
Restrictions:
  • A bucket name must be unique across all accounts and regions.
  • A bucket name:
    • Must be 3 to 63 characters long and start with a digit or letter. Lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot be formatted as an IP address.
    • Cannot start or end with a hyphen (-) or period (.).
    • Cannot contain two consecutive periods (..), for example, my..bucket.
    • Cannot contain periods (.) and hyphens (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
objectKey
String
Yes
Explanation:
Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name.
For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt.
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
metadata
ObjectMetadata
No
Explanation:
Object metadata. For details, see Table 19.
Default value:
None
acl
AccessControlList
No
Explanation:
ACL that can be pre-defined when an object is created. Refer to Table 12 to choose the option you need. For details about ACLs, see ACLs.
Value range:
  • To use a pre-defined ACL, see Table 21 for the available options.
  • To use a user-defined ACL, see Table 12 to configure the required parameters.
Default value:
None
sseKmsHeader
SseKmsHeader
No
Explanation:
Server-side encryption header. For details, see Table 14.
Default value:
None
sseCHeader
SseCHeader
No
Explanation:
Server-side encryption header. For details, see Table 13.
Default value:
None
input
java.io.InputStream
No
Explanation:
Data stream of the object to be uploaded.
Default value:
None
file
java.io.File
No
Explanation:
File stream of the object to be uploaded.
Default value:
None
extensionPermissionMap
Map<ExtensionObjectPermissionEnum, Set<String>>
No
Explanation:
A permission map for granting bucket ACL permissions to one or more accounts. ExtensionObjectPermissionEnum specifies the permissions to grant, and Set<String> describes the list of account IDs (indicated by domain_id) the granted permissions apply to.
Value range:
Default value:
None
expires
int
No
Explanation:
Expiration time of the object. The calculation starts from the time when the object was last modified. Once the object expires, it is automatically deleted.
Restrictions:
This parameter can be configured when uploading an object or using the x-obs-expires header in a metadata API call.
Value range:
An integer greater than 0, in days
Default value:
None
needCalculateCRC64
boolean
No
Explanation:
Whether to automatically calculate the CRC64 value of the data to be uploaded and submit the CRC64 value to the server for verification.
Restrictions:
This parameter is not supported for POSIX or SFS objects.
This parameter is supported only for file uploads.
Value range:
true: The SDK calculates CRC64 and submits it to the server for verification.
false: CRC64 is not calculated.
Default value:
false
progressListener
ProgressListener
No
Explanation:
Upload progress. For details, see Table 3.
encodeHeaders
boolean
No
Explanation:
Whether to enable OBS to automatically encode request headers.
Due to HTTP coding restrictions, only ASCII characters can be sent. If your request headers contain full-width characters, the SDK will URL encode these characters before sending the request. When you use a browser to access the object metadata, the browser automatically decodes the data.
Value range:
true: Encoding with SDK is enabled.
false: Encoding with SDK is disabled.
Default value:
true
Table 3 ProgressListener
Method
Return Value Type
Mandatory (Yes/No)
progressChanged
void
Yes
Explanation:
Used for obtaining the upload progress. For details, see Table 4.
Default value:
None
Table 4 progressChanged
Type
Mandatory (Yes/No)
status
ProgressStatus
Yes
Explanation:
Progress status. For details, see Obtaining the Upload Progress (SDK for Java).
Default value:
None
Table 5 ProgressStatus
Method
Return Value Type
getAverageSpeed()
double
Average transmission rate.
getInstantaneousSpeed()
double
Instantaneous transmission rate.
getTransferPercentage()
int
Transmission progress, in percentage.
getNewlyTransferredBytes()
long
Number of the newly transmitted bytes.
getTransferredBytes()
long
Number of bytes that have been transmitted.
getTotalBytes()
long
Number of the bytes to be transmitted.
Table 6 ExtensionObjectPermissionEnum
Constant
GRANT_READ
Grants a specific tenant the permissions to read the object and object metadata.
GRANT_READ_ACP
Grants a specific tenant the permissions to obtain the object ACL.
GRANT_WRITE_ACP
Grants a specific tenant the permissions to write the object ACL.
GRANT_FULL_CONTROL
Grants a specific tenant the permissions to read the content, metadata, and ACL of the object and write the object ACL.
Table 7 SseKmsHeader
Type
Mandatory (Yes/No)
encryption
ServerEncryption
Yes
Explanation:
SSE-KMS used for encrypting objects.
Explanation:
SSE-KMS is used for encrypting objects on the server side.
Value range:
kms. For details, see Table 9.
Default value:
None
sseAlgorithm
SSEAlgorithmEnum
No
Explanation:
Encryption algorithm.
Restrictions:
Only KMS is supported.
Value range:
See Table 10.
Default value:
None
kmsKeyId
String
No
Explanation:
ID of the KMS master key when SSE-KMS is used.
Value range:
Valid value formats are as follows:
  1. regionID:domainID:key/key_id
  2. key_id
In the preceding formats:
Default value:
  • If this parameter is not specified, the default master key will be used.
  • If there is no such a default master key, OBS will create one and use it by default.
Table 8 SseCHeader
Type
Mandatory (Yes/No)
algorithm
ServerAlgorithm
Yes
Explanation:
SSE-C is used for encrypting objects on the server side.
Value range:
AES256, indicating AES is used to encrypt the object in SSE-C. For details, see Table 11.
Default value:
None
sseAlgorithm
SSEAlgorithmEnum
No
Explanation:
Restrictions:
Only AES256 is supported.
Value range:
See Table 10.
Default value:
None
sseCKey
byte[]
Yes
Explanation:
Key used for encrypting the object when SSE-C is used, in byte[] format.
Default value:
None
sseCKeyBase64
String
No
Explanation:
Base64-encoded key used for encrypting the object when SSE-C is used.
Default value:
None
Table 9 ServerEncryption
Constant
Default Value
OBS_KMS
kms
Table 10 SSEAlgorithmEnum
Constant
Default Value
KMS
kms
AES256
AES256
Table 11 ServerAlgorithm
Constant
Default Value
AES256
AES256
Table 12 AccessControlList
Type
Mandatory (Yes/No)
Type
owner
Owner
No
Explanation:
Bucket owner information. For details, see Table 13.
delivered
boolean
No
Explanation:
Whether the bucket ACL is applied to all objects in the bucket.
Value range:
true: The bucket ACL is applied to all objects in the bucket.
false: The bucket ACL is not applied to any objects in the bucket.
Default value:
false
grants
Set<GrantAndPermission>
No
Explanation:
Grantee information. For details, see Table 14.
Table 13 Owner
Type
Mandatory (Yes/No)
id
String
Yes
Explanation:
Account (domain) ID of the bucket owner.
Value range:
To obtain the account ID, see How Do I Get My Account ID and User ID?
Default value:
None
displayName
String
No
Explanation:
Account name of the owner.
Value range:
To obtain the account name, see How Do I Get My Account ID and User ID?
Default value:
None
Table 14 GrantAndPermission
Type
Mandatory (Yes/No)
grantee
GranteeInterface
Yes
Explanation:
Grantees (users or user groups). For details, see Table 16.
permission
Permission
Yes
Explanation:
Permissions to grant.
Value range:
See Table 15.
Default value:
None
delivered
boolean
No
Explanation:
Value range:
Default value:
false
Table 15 Permission
Constant
Default Value
PERMISSION_READ
READ
Read permission.
A grantee with this permission for a bucket can obtain the list of objects, multipart uploads, bucket metadata, and object versions in the bucket.
A grantee with this permission for an object can obtain the object content and metadata.
PERMISSION_WRITE
WRITE
Write permission.
A grantee with this permission for a bucket can upload, overwrite, and delete any object or part in the bucket.
This permission is not available for objects.
PERMISSION_READ_ACP
READ_ACP
Permission to read an ACL.
A grantee with this permission can obtain the ACL of a bucket or object.
A bucket or object owner has this permission for their bucket or object by default.
PERMISSION_WRITE_ACP
WRITE_ACP
Permission to modify an ACL.
A grantee with this permission can update the ACL of a bucket or object.
This permission allows the grantee to change the access control policies, meaning the grantee has full control over a bucket or object.
PERMISSION_FULL_CONTROL
FULL_CONTROL
Full control access, including read and write permissions for a bucket and its ACL, or for an object and its ACL.
A grantee with this permission for a bucket has READ, WRITE, READ_ACP, and WRITE_ACP permissions for the bucket.
A grantee with this permission for an object has READ, READ_ACP, and WRITE_ACP permissions for the object.
Table 16 GranteeInterface
Type
Mandatory (Yes/No)
CanonicalGrantee
CanonicalGrantee
Yes
Explanation:
Grantee (user) information. For details, see Table 17.
GroupGrantee
GroupGrantee
Yes
Explanation:
Grantee (user group) information.
Value range:
See Table 18.
Default value:
None
Table 17 CanonicalGrantee
Type
Mandatory (Yes/No)
grantId
String
Yes if Type is set to GranteeUser
Explanation:
Account (domain) ID of the grantee.
Value range:
Default value:
None
displayName
String
No
Explanation:
Account name of the grantee.
Value range:
Default value:
None
Table 18 GroupGrantee
Constant
ALL_USERS
All users.
AUTHENTICATED_USERS
Authorized users. This constant is deprecated.
LOG_DELIVERY
Log delivery group. This constant is deprecated.
Table 19 ObjectMetadata
Type
Mandatory (Yes/No)
contentLength
Long
No
Explanation:
Size of the object.
Restrictions:
  • The object size in a single upload ranges from 0 to 5 GB.
  • To upload files larger than 5 GB, multipart uploads should be used.
Default value:
If this parameter is not specified, the SDK automatically calculates the size of the object.
contentType
String
No
Explanation:
MIME type of the object to be uploaded. MIME type is a standard way of describing a data type and is used by the browser to decide how to display data.
Value range:
See What Is Content-Type (MIME)? (Java SDK)
Default value:
If this parameter is not specified, the SDK determines the file type based on the suffix of the object name and assigns a value to the parameter. For example, if the suffix of the object name is .xml, the object is an application/xml file. If the suffix is .html, the object is a text/html file.
contentEncoding
String
No
Explanation:
Content-Encoding header in the response. It specifies which encoding is applied to the object.
Default value:
None
contentDisposition
String
No
Explanation:
Provides a default file name for the requested object. When the object with the default file name is being downloaded or accessed, the content is displayed as part of a web page in the browser or as an attachment in a download dialog box.
Default value:
None
cacheControl
String
No
Explanation:
Cache-Control header in the response. It specifies the cache behavior of the web page when an object is downloaded.
Default value:
None
contentLanguage
String
No
Explanation:
Language or language combination for visitors to customize and use. For details, see the definition of ContentLanguage in the HTTP protocol.
Default value:
None
expires
String
No
Explanation:
The time a cached web page object expires.
Restrictions:
The time must be in the GMT format.
Default value:
None
contentMd5
String
No
Explanation:
Base64-encoded MD5 value of the object data. It is provided for the OBS server to verify data integrity. The OBS server will compare this MD5 value with the MD5 value calculated based on the object data. If the two values are not the same, HTTP status code 400 is returned.
Restrictions:
  • The MD5 value of the object must be Base64 encoded.
  • If the MD5 value is not specified, the OBS server will not verify the MD5 value of the object.
Value range:
Base64-encoded 128-bit MD5 value of the request body calculated according to RFC 1864.
Example: n58IG6hfM7vqI4K0vnWpog==
Default value:
None
storageClass
StorageClassEnum
No
Explanation:
Object storage class that can be specified at object creation. If this parameter is not specified, the object inherits the storage class of the bucket where it is to be uploaded by default.
Value range:
See Table 20.
Default value:
None
webSiteRedirectLocation
String
No
Explanation:
If the bucket is configured with website hosting, the request for obtaining the object can be redirected to another object in the bucket or an external URL. This parameter specifies the address the request for the object is redirected to.
The request is redirected to an object anotherPage.html in the same bucket:
WebsiteRedirectLocation:/anotherPage.html
The request is redirected to an external URL http://www.example.com/:
WebsiteRedirectLocation:http://www.example.com/
Restrictions:
  • The value must start with a slash (/), http://, or https:// and cannot exceed 2 KB.
  • OBS only supports redirection for objects in the root directory of a bucket.
Default value:
None
nextPosition
long
No
Explanation:
Start position for the next append upload.
Value range:
0 to the object length, in bytes.
Default value:
None
appendable
boolean
No
Explanation:
Whether the object is appendable.
Value range:
true: The object is appendable.
false: The object is not appendable.
Default value:
None
userMetadata
Map<String, Object>
No
Explanation:
User-defined metadata of the object. To define it, you can add a header starting with x-obs-meta- in the request. In Map, the String key indicates the name of the user-defined metadata that starts with x-obs-meta-, and the Object value indicates the value of the user-defined metadata. To obtain the user-defined metadata of an object, use ObsClient.getObjectMetadata. For details, see Obtaining Object Metadata (SDK for Java).
Restrictions:
  • An object can have multiple pieces of metadata. The size of the metadata cannot exceed 8 KB in total.
  • When you call ObsClient.getObject to download an object, its user-defined metadata will also be downloaded.
Default value:
None
Table 20 StorageClassEnum
Constant
Default Value
STANDARD
STANDARD
Standard storage class
WARM
WARM
Infrequent Access storage class.
COLD
COLD
Archive storage class.
Table 21 Pre-defined ACL
Constant
AccessControlList.REST_CANNED_PRIVATE
Private read/write.
A bucket or object can only be accessed by its owner.
AccessControlList.REST_CANNED_PUBLIC_READ
Public read.
If this permission is granted on a bucket, anyone can read the object list, multipart uploads, bucket metadata, and object versions in the bucket.
If this permission is granted on an object, anyone can read the content and metadata of the object.
AccessControlList.REST_CANNED_PUBLIC_READ_WRITE
Public read/write.
If this permission is granted on a bucket, anyone can read the object list, multipart uploads, and bucket metadata, and can upload or delete objects, initiate multipart uploads, upload parts, assemble parts, copy parts, and abort multipart upload tasks.
AccessControlList.REST_CANNED_PUBLIC_READ_DELIVERED
Public read on a bucket as well as objects in the bucket.
If this permission is granted on a bucket, anyone can read the object list, multipart tasks, and bucket metadata, and can also read the content and metadata of the objects in the bucket.
This permission cannot be granted on objects.
AccessControlList.REST_CANNED_PUBLIC_READ_WRITE_DELIVERED
Public read/write on a bucket as well as objects in the bucket.
If this permission is granted on a bucket, anyone can read the object list, multipart uploads, and bucket metadata, and can upload or delete objects, initiate multipart upload tasks, upload parts, assemble parts, copy parts, and abort multipart uploads. They can also read the content and metadata of the objects in the bucket.
AccessControlList.REST_CANNED_BUCKET_OWNER_FULL_CONTROL
If this permission is granted on an object, only the bucket and object owners have the full control over the object.
By default, if you upload an object to a bucket owned by another user, the bucket owner does not have the permissions on your object. After you grant this permission to the bucket owner, the bucket owner can have full control over your object.
For example, if user A uploads object x to user B's bucket, user B does not have the control over object x. If user A sets bucket-owner-full-control for object x, user B then has the control over object x.
Responses
Table 22 PutObjectResult
Type
statusCode
int
Explanation:
HTTP status code.
Value range:
A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response.
For more information, see Status Code.
Default value:
None
responseHeaders
Map<String, Object>
Explanation:
Response header list, composed of tuples. In a tuple, the String key indicates the name of the header, and the Object value indicates the value of the header.
Default value:
None
storageClass
StorageClassEnum
Explanation:
Storage class of an object that can be specified at object creation. If you do not specify this header, the object inherits the storage class of the bucket.
Value range:
See Table 20.
Default value:
None
versionId
String
Explanation:
Object version ID. If versioning is enabled for the bucket, the object version ID will be returned.
Value range:
The value must contain 32 characters.
Default value:
None
etag
String
Explanation:
ETag of an object, which is a Base64-encoded 128-bit MD5 digest. ETag is the unique identifier of the object content. It can be used to determine whether the object content is changed. For example, if the ETag is A when an object is uploaded and is B when the object is downloaded, the object content is changed. The ETag reflects changes only to the contents of the object, not its metadata. An object created by an upload or copy operation has a unique ETag.
Restrictions:
If an object is encrypted using server-side encryption, the ETag is not the MD5 value of the object.
Value range:
Default value:
None
objectKey
String
Explanation:
Value range:
Default value:
None
bucketName
String
Explanation:
Bucket name.
Restrictions:
  • A bucket name:
Default value:
None
Code Examples
This example uploads local files to bucket examplebucket.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
import com.obs.services.ObsClient;
import com.obs.services.exception.ObsException;
import com.obs.services.model.PutObjectRequest;
import java.io.File;
public class PutObject004 {
        // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage.
        // Obtain an AK/SK pair on the management console.
        // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage.
        // Obtain an AK/SK pair and a security token using environment variables or import them in other ways.
        // String securityToken = System.getenv("SECURITY_TOKEN");
        // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in your actual situation.
        String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com";
        // Obtain an endpoint using environment variables or import it in other ways.
        //String endPoint = System.getenv("ENDPOINT");
        // Create an ObsClient instance.
        // Use the permanent AK/SK pair to initialize the client.
        ObsClient obsClient = new ObsClient(ak, sk,endPoint);
        // Use the temporary AK/SK pair and security token to initialize the client.
        // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint);
        try {
            // Upload files.
            // localfile indicates the path of the local file to be uploaded, in which the file name must be specified.
            PutObjectRequest request = new PutObjectRequest();
            request.setBucketName("examplebucket");
            request.setObjectKey("objectkey");
            request.setFile(new File("localfile"));
            obsClient.putObject(request);
            System.out.println("putObject successfully");
        } catch (ObsException e) {
            System.out.println("putObject failed");
            // Request failed. Print the HTTP status code.
            System.out.println("HTTP Code:" + e.getResponseCode());
            // Request failed. Print the server-side error code.
            System.out.println("Error Code:" + e.getErrorCode());
            // Request failed. Print the error details.
            System.out.println("Error Message:" + e.getErrorMessage());
            // Request failed. Print the request ID.
            System.out.println("Request ID:" + e.getErrorRequestId());
            System.out.println("Host ID:" + e.getErrorHostId());
            e.printStackTrace();
        } catch (Exception e) {
            // Print other error information.
