Listing Uploaded Parts (SDK for Go)
Function
This API lists the uploaded parts in a specified bucket. This request must contain the multipart upload ID.
You can list the uploaded parts of a specified multipart upload or of all ongoing multipart uploads. A maximum of 1,000 uploaded parts can be returned in a response. If your multipart upload has more than 1,000 parts, you need to send multiple requests to list all uploaded parts. Assembled parts will not be listed.
Restrictions
- To list uploaded parts, you must be the bucket owner or have the required permission (obs:object:ListMultipartUploadParts in IAM or ListMultipartUploadParts in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
func (obsClient ObsClient) ListParts(input *ListPartsInput) (output *ListPartsOutput, err error)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| input | Yes | Explanation: Input parameters for listing uploaded parts. For details, see Table 2. |
| Bucket | string | Yes | Explanation: Bucket name Restrictions:
Default value: None |
| Key | string | Yes | Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
| UploadId | string | Yes | Explanation: Multipart upload ID, for example, 000001648453845DBB78F2340DD460D8 Value range: The value must contain 1 to 32 characters. Default value: None |
| PartNumberMarker | int | No | Explanation: Part number after which uploaded parts listing begins Restrictions: OBS lists only parts with greater numbers than that specified by this parameter. Default value: None |
| MaxParts | int | No | Explanation: Maximum number of parts that can be listed per page Restrictions: If the specified value is greater than 1000, only 1,000 parts are returned. Value range: The value ranges from 1 to 1000. Default value: 1000 |
| EncodingType | string | No | Explanation: Encoding type for Key in the response. If Key in the response contains control characters that are not supported by the XML 1.0 standard, you can specify this parameter to encode Key. Value range: url Default value: None. If you leave this parameter blank, encoding is not applied to Key. |
Responses
| Parameter | Type | Description |
| output | Explanation: Returned results. For details, see Table 4. | |
| err | error | Explanation: Error messages returned by the API |
| StatusCode | int | Explanation: HTTP status code Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
| RequestId | string | Explanation: Request ID returned by the OBS server Default value: None |
| ResponseHeaders | map[string][]string | Explanation: HTTP response headers Default value: None |
| Bucket | string | Explanation: Bucket name Restrictions:
Value range: The value must contain 3 to 63 characters. |
| Key | string | Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
| UploadId | string | Explanation: Multipart upload ID, for example, 000001648453845DBB78F2340DD460D8 Value range: The value must contain 32 characters. Default value: None |
| Initiator | Explanation: Initiator of the multipart upload. For details, see Table 5. | |
| Owner | Explanation: Owner of the multipart upload, which is consistent with Initiator | |
| StorageClass | Explanation: Object storage class Value range: See Table 8. Default value: None | |
| PartNumberMarker | int | Explanation: Part number to start with for listing parts, which is consistent with that set in the request Value range: A non-negative integer Default value: None |
| NextPartNumberMarker | int | Explanation: Part number to start with for the next part listing request. NextPartNumberMarker is returned when not all the parts are listed. You can set PartNumberMarker to this value in the next request to list the remaining parts. Value range: A non-negative integer Default value: None |
| MaxParts | int | Explanation: Maximum number of listed parts that can be listed per page. This parameter is consistent with that set in the request. Restrictions: If the specified value is greater than 1000, only 1,000 parts are returned. Value range: The value ranges from 1 to 1000. Default value: 1000 |
| IsTruncated | bool | Explanation: Whether all results are returned in the response Value range:
| Parts | []Part | Explanation: List of uploaded parts. For details, see Table 7. |
| EncodingType | string | Explanation: Encoding type for Key in the response. If Key in the response contains control characters that are not supported by the XML 1.0 standard, you can specify this parameter to encode Key. Value range: url Default value: None. If you leave this parameter blank, encoding is not applied to Key. |
| ID | string | Yes if used as a request parameter | Explanation: Account (domain) ID of the initiator Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
| DisplayName | string | No | Explanation: Account name of the initiator Restrictions: The account name can contain 6 to 32 characters and must start with a letter. Only letters, digits, hyphens (-), and underscores (_) are allowed. Default value: None |
| ID | string | Yes if used as a request parameter | Explanation: Account (domain) ID of the owner Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? |
| PartNumber | int | Explanation: Part number Value range: An integer ranging from 1 to 10000 Default value: None |
| ETag | string | Explanation: Part ETag, which is a Base64-encoded, 128-bit MD5 value Value range: The value must contain 32 characters. Default value: None |
| Constant | Default Value | Description |
| StorageClassStandard | STANDARD | OBS Standard Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response. |
| StorageClassWarm | WARM | OBS Infrequent Access Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but is instantly available when needed. |
| StorageClassCold | COLD | OBS Archive Used for storing rarely accessed (once a year) data. |
Code Examples
This example lists the parts that have been uploaded for a multipart upload.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 | package main import ( "fmt" "os" obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs" ) func main() { //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html. ak := os.Getenv("AccessKeyID") sk := os.Getenv("SecretAccessKey") // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // securityToken := os.Getenv("SecurityToken") // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com" // Create an obsClient instance. // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance. obsClient, err := obs.New(ak, sk, endPoint/*, obs.WithSecurityToken(securityToken)*/) if err != nil { fmt.Printf("Create obsClient error, errMsg: %s", err.Error()) } input := &obs.ListPartsInput{} // Specify a bucket name. input.Bucket = "examplebucket" // Specify an object name (example/objectname as an example). input.Key = "example/objectname" // Specify the multipart upload ID (00000188677110424014075CC4A77xxx as an example). input.UploadId = "00000188677110424014075CC4A77xxx" // List the uploaded parts. output, err := obsClient.ListParts(input) if err == nil { fmt.Printf("List part successful with bucket(%s) and object(%s)!\n", input.Bucket, input.Object) for index, part := range output.Parts { fmt.Printf("Part[%d]-ETag:%s, PartNumber:%d, LastModified:%s, Size:%d\n", index, part.ETag, part.PartNumber, part.LastModified, part.Size) } return } fmt.Printf("List part fail with bucket(%s) and object(%s)!\n", input.Bucket, input.Object) if obsError, ok := err.(obs.ObsError); ok { fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.") fmt.Println(obsError.Error()) } else { fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.") fmt.Println(err) } } |
