Uploading a Part (SDK for Go)
Function
After a multipart upload is initiated, this API uploads a part to a specified bucket. In the upload request, the multipart upload ID must be included. Except for the part lastly being uploaded whose size ranges from 0 to 5 GB, sizes of the other parts range from 100 KB to 5 GB. Part numbers can be any number from 1 to 10,000.
When uploading a part, you must specify its upload ID and part number. A part number uniquely identifies a part and its position in the object you are uploading. If you upload a new part with the same part number as that of a previous part, the previously uploaded part will be overwritten. Whenever you upload a part, OBS returns the ETag header in the response. For each part upload task, you must record the part number and ETag value. These values are required in subsequent requests for you to complete a multipart upload.
Restrictions
- To upload a part, you must be the bucket owner or have the required permission (obs:object:PutObject in IAM or PutObject in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
- After initiating a multipart upload and uploading one or more parts, you must assemble the parts or abort the multipart upload. Only after that can OBS stops billing you for storing the uploaded parts.
- partNumber in a multipart upload must be unique. When the same partNumber of the same object is concurrently uploaded, last write wins policy is applied. The time of last write is defined as the time when the part metadata is created. To ensure data accuracy, the client must be locked to ensure concurrent uploads of the same part of the same object. Concurrent uploads for different parts of the same object do not need to be locked.
Method
func (obsClient ObsClient) UploadPart(input *UploadPartInput) (output *UploadPartOutput, err error)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| input | Yes | Explanation: Input parameters for uploading a part. For details, see Table 2. |
| Bucket | string | Yes | Explanation: Bucket name Restrictions:
Default value: None |
| Key | string | Yes | Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
| PartNumber | int | Yes | Explanation: Part number Value range: An integer ranging from 1 to 10000 Default value: None |
| UploadId | string | Yes | Explanation: Multipart upload ID which can be returned by initiating a multipart upload Restrictions: Value range: The value must contain 32 characters. Example: 000001648453845DBB78F2340DD460D8 Default value: None |
| ContentMD5 | string | No | Explanation: Base64-encoded MD5 value of the object data to be uploaded. It is provided for the OBS server to verify data integrity. Value range: Base64-encoded 128-bit MD5 value of the request body calculated according to RFC 1864 Example: n58IG6hfM7vqI4K0vnWpog== Default value: None |
| SseHeader | No | Explanation: Server-side encryption header. If SSE-C is used, see Table 3. | |
| Body | io.Reader | No | Explanation: Data stream of the object to be uploaded Value range: The value ranges from 0 TB to 48.8 TB, in bytes. Default value: None |
| SourceFile | string | No | Explanation: Source file path of the object to be uploaded Default value: None |
| Offset | int64 | No | Explanation: Start offset of a part in the source file Value range: A non-negative integer smaller than the size of the object to be uploaded, in bytes Default value: 0 |
| PartSize | int64 | No | Explanation: Part size Restrictions:
Value range: The value ranges from 100 KB to 5 GB, in bytes. Default value: 102400 |
| Encryption | string | Yes if used as a request parameter | Explanation: SSE-C used for encrypting objects Restrictions: None Value range: AES256, indicating objects are encrypted using SSE-C Default value: None |
| Key | string | Yes if used as a request parameter | Explanation: Key for encrypting the object when SSE-C is used Restrictions: The value is a Base64-encoded 256-bit key, for example, K7QkYpBkM5+hca27fsNkUnNVaobncnLht/rCB2o/9Cw=. Value range: None Default value: None |
| KeyMD5 | string | No if used as a request parameter | Explanation: MD5 value of the key for encrypting objects when SSE-C is used. This value is used to check whether any error occurs during the transmission of the key. Restrictions: The value is encrypted by MD5 and then encoded by Base64, for example, 4XvB3tbNTN+tIEVa0/fGaQ==. Value range: None Default value: None |
Responses
| Parameter | Type | Description |
| output | Explanation: Returned results. For details, see Table 5. | |
| err | error | Explanation: Error messages returned by the API |
| StatusCode | int | Explanation: HTTP status code Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
| RequestId | string | Explanation: Request ID returned by the OBS server Default value: None |
| ResponseHeaders | map[string][]string | Explanation: HTTP response headers Default value: None |
| PartNumber | int | Explanation: Part number Value range: An integer ranging from 1 to 10000 Default value: None |
| ETag | string | Explanation: Base64-encoded, 128-bit MD5 value of an object. ETag is the unique identifier of the object content. It can be used to determine whether the object content is changed. For example, if the ETag value is A when an object is uploaded, but changes to B when the object is downloaded, it indicates that the object content has been changed. The ETag reflects changes to the object content, rather than the object metadata. An uploaded or copied object has a unique ETag after being encrypted using MD5. Restrictions: If an object is encrypted using server-side encryption, the ETag is not the MD5 value of the object. Value range: The value must contain 32 characters. Default value: None |
| SseHeader | Explanation: Server-side encryption header. If SSE-C is used, see Table 6. If SSE-KMS is used, see Table 7. |
| Encryption | string | Yes if used as a request parameter | Explanation: SSE-KMS is used for encrypting objects on the server side. Value range: kms Default value: None |
| Key | string | No if used as a request parameter | Explanation: ID of the KMS master key when SSE-KMS is used Value range: Valid value formats are as follows:
In the preceding formats:
Default value:
| ProjectID | string | No if used as a request parameter | Explanation: ID of the project (not an enterprise project) where the KMS CMK belongs when SSE-KMS is used Restrictions: None Value range: Project ID (not enterprise project ID) that matches the key ID specified by Key. Default value: None |
Code Example
This example uploads a part to bucket examplebucket by specifying a multipart upload ID.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 | package main import ( "fmt" "os" "strings" obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs" ) func main() { //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html. ak := os.Getenv("AccessKeyID") sk := os.Getenv("SecretAccessKey") // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // securityToken := os.Getenv("SecurityToken") // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com" // Create an obsClient instance. // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance. obsClient, err := obs.New(ak, sk, endPoint/*, obs.WithSecurityToken(securityToken)*/) if err != nil { fmt.Printf("Create obsClient error, errMsg: %s", err.Error()) } input := &obs.UploadPartInput{} // Specify a bucket name. input.Bucket = "examplebucket" // Specify an object name (example/objectname as an example). input.Key = "example/objectname" // Specify the multipart upload ID (00000188677110424014075CC4A77xxx as an example). input.UploadId = "00000188677110424014075CC4A77xxx" // Specify the part number (1 as an example) of part to upload. The part number can be any integer from 1 to 10,000. input.PartNumber = 1 // Specify the source file path (localfile as an example) of the part to upload. input.SourceFile = "localfile" // Upload the part. output, err := obsClient.UploadPart(input) if err == nil { fmt.Printf("Upload part(%d) successful with bucket(%s) and object(%s)!!\n", input.PartNumber, input.Bucket, input.Key) fmt.Printf("ETag:%s\n", output.ETag) return } fmt.Printf("Upload part(%d) fail with bucket(%s) and object(%s)!!\n", input.PartNumber, input.Bucket, input.Key) if obsError, ok := err.(obs.ObsError); ok { fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.") fmt.Println(obsError.Error()) } else { fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.") fmt.Println(err) } } |
