Help Center/ Object Storage Service/ SDK Reference/ Go/ Objects (SDK for Go)/ Obtaining Object Metadata (SDK for Go)
Updated on 2024-12-09 GMT+08:00
Function
Object metadata is a set of name-value pairs that describe the object and is used for object management.
Currently, only the metadata defined by the system is supported. There are two kinds of metadata: system-controlled metadata and user-controlled metadata.
You can use this API to send a HEAD request to the object of a specified bucket to obtain its metadata.
Restrictions
  • To obtain object metadata, you must be the bucket owner or have the required permission (obs:object:GetObject in IAM or GetObject in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
  • The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
  • Users with the read permission on an object can perform the HEAD operation to obtain the object metadata. The object metadata is included in the response.
Method
func (obsClient ObsClient) GetObjectMetadata(input *GetObjectMetadataInput) (output *GetObjectMetadataOutput, err error)
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
input
Yes
Explanation:
Input parameters for obtaining object metadata. For details, see Table 2.
Table 2 GetObjectMetadataInput
Type
Mandatory (Yes/No)
Bucket
string
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name must be unique across all accounts and regions.
  • A bucket name:
    • Must be 3 to 63 characters long and start with a digit or letter. Lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot be formatted as an IP address.
    • Cannot start or end with a hyphen (-) or period (.).
    • Cannot contain two consecutive periods (..), for example, my..bucket.
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
Key
string
Yes
Explanation:
Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name.
For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt.
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
VersionId
string
No
Explanation:
Object version ID, for example, G001117FCE89978B0000401205D5DC9A
Value range:
The value must contain 32 characters.
Default value:
None
SseHeader
SseCHeader
No
Explanation:
Server-side decryption headers. For details, see Table 3.
Table 3 SseCHeader
Type
Mandatory (Yes/No)
Encryption
string
Yes if used as a request parameter
Explanation:
SSE-C used for encrypting objects
Value range:
AES256, indicating objects are encrypted using SSE-C
Default value:
None
Key
string
Explanation:
Key for encrypting the object when SSE-C is used
Restrictions:
The value is a Base64-encoded 256-bit key, for example, K7QkYpBkM5+hca27fsNkUnNVaobncnLht/rCB2o/9Cw=.
Default value:
None
KeyMD5
string
No if used as a request parameter
Explanation:
MD5 value of the key for encrypting objects when SSE-C is used. This value is used to check whether any error occurs during the transmission of the key.
Restrictions:
The value is encrypted by MD5 and then encoded by Base64, for example, 4XvB3tbNTN+tIEVa0/fGaQ==.
Default value:
None
Responses
Table 4 List of returned results
Type
output
Explanation:
Returned results. For details, see Table 5.
err
error
Explanation:
Error messages returned by the API
Table 5 GetObjectMetadataOutput
Type
StatusCode
int
Explanation:
HTTP status code
Value range:
A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
RequestId
string
Explanation:
Request ID returned by the OBS server
Default value:
None
ResponseHeaders
map[string][]string
Explanation:
HTTP response headers
Default value:
None
StorageClass
StorageClassType
Explanation:
Object storage class. If you do not specify this header, the object inherits the storage class of the bucket.
Value range:
See Table 6.
Default value:
None
AllowOrigin
string
Explanation:
If Origin in the request meets the CORS rules of the bucket, AllowedOrigin specified in the CORS rules is returned. AllowedOrigin indicates the origin from which the requests can access the bucket.
Restrictions:
Domain name of the origin. Each origin can contain only one wildcard character (*), for example, https://*.vbs.example.com.
Default value:
None
AllowHeader
string
Explanation:
If RequestHeader in the request meets the CORS rules of the bucket, AllowedHeader specified in the CORS rules is returned. AllowedHeader indicates the allowed headers for cross-origin requests. Only CORS requests matching the allowed headers are valid.
Restrictions:
Each header can contain only one wildcard character (*). Spaces, ampersands (&), colons (:), and less-than signs (<) are not allowed.
Default value:
None
AllowMethod
string
Explanation:
AllowedMethod in the CORS rules of the bucket. It specifies the HTTP method of cross-origin requests, that is, the operation type of buckets and objects.
Value range:
The following HTTP methods are supported:
  • GET
  • PUT
  • HEAD
  • POST
  • DELETE
Default value:
None
ExposeHeader
string
Explanation:
ExposeHeader in the CORS rules of the bucket. It specifies the CORS-allowed additional headers in the response. These headers provide additional information to clients. By default, your browser can only access headers Content-Length and Content-Type. If your browser needs to access other headers, add them to a list of the allowed additional headers.
Restrictions:
Spaces, wildcard characters (*), ampersands (&), colons (:), and less-than signs (<) are not allowed.
Default value:
None
MaxAgeSeconds
int
Explanation:
MaxAgeSeconds in the CORS rules of the bucket. It specifies the time your client can cache the response for a cross-origin request.
Restrictions:
Each CORS rule can specify only one value for MaxAgeSeconds.
Value range:
0 to (231 – 1), in seconds
Default value:
100
ContentLength
int64
Explanation:
Object size in bytes
Value range:
0 to (263 – 1), in bytes
Default value:
None
ContentType
string
Explanation:
MIME type of the object file. MIME type is a standard way of describing a data type and is used by the browser to decide how to display data.
Value range:
See What Is Content-Type (MIME)?
Default value:
If you do not specify this parameter when uploading an object, the SDK determines the object type based on the suffix of the specified object name and automatically assigns a value to this parameter.
LastModified
time.Time
Explanation:
Time when the last modification was made to the object
Restrictions:
The time must be in the ISO8601 format, for example, 2018-01-01T00:00:00.000Z.
Default value:
None
ETag
string
Explanation:
ETag of the object Base64-encoded, 128-bit MD5 value of an object. ETag is the unique identifier of the object content. It can be used to determine whether the object content is changed. For example, if ETag value is A when an object is uploaded but changes to B when the object is downloaded, it indicates that the object content is changed. The ETag reflects changes to the object content, rather than the object metadata. An uploaded object or copied object has a unique ETag.
Restrictions:
If an object is encrypted using server-side encryption, the ETag is not the MD5 value of the object.
Value range:
Default value:
None
VersionId
string
Explanation:
Object version ID
Value range:
Default value:
None
Restore
string
Explanation:
Restore status of an object. For an Archive object that is being restored or has been restored, this header is returned.
For example, ongoing-request="true" indicates that the object is being restored. ongoing-request="false", expiry-date="Wed, 7 Nov 2012 00:00:00 GMT" indicates that the object has been restored. expiry-date indicates when the restored object expires.
Restrictions:
This parameter is only available for Archive objects.
Default value:
None
Expiration
string
Explanation:
Expiration details of the object. Example: "expiry-date=\"Mon, 11 Sep 2023 00:00:00 GMT\""
Default value:
None
SseHeader
SseCHeader or SseKmsHeader
Explanation:
Server-side encryption header information. If SSE-C is used, see Table 7. If SSE-KMS is used, see Table 8.
WebsiteRedirectLocation
string
Explanation:
If the bucket is configured with website hosting, the request for obtaining the object can be redirected to another object in the bucket or an external URL.
The request is redirected to object anotherPage.html in the same bucket:
WebsiteRedirectLocation:/anotherPage.html
The request is redirected to an external URL http://www.example.com/:
WebsiteRedirectLocation:http://www.example.com/
OBS obtains the specified value from the header and stores it in the object metadata WebsiteRedirectLocation.
Restrictions:
  • The value must start with a slash (/), http://, or https:// and cannot exceed 2 KB.
  • OBS only supports redirection for objects in the root directory of a bucket.
Default value:
None
Metadata
map[string]string
Explanation:
Custom metadata of the object. You can add a header starting with x-obs-meta- in the request to define metadata. The custom metadata will be returned in the response when you retrieve the object or query the object metadata.
Restrictions:
  • The custom metadata cannot exceed 8 KB. To measure the custom metadata, sum the number of bytes in the UTF-8 encoding of each key and value.
  • The custom metadata keys are case insensitive, but are stored in lowercase in OBS. The key values are case sensitive.
  • Both custom metadata keys and their values must conform to US-ASCII standards. If non-ASCII or unrecognizable characters are necessary, they must be encoded and decoded in URL or Base64 on the client, because the server side does not perform any decoding.
Default value:
None
Table 6 StorageClassType
Constant
Default Value
StorageClassStandard
STANDARD
OBS Standard
Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response.
StorageClassWarm
WARM
OBS Infrequent Access
Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but is instantly available when needed.
StorageClassCold
COLD
OBS Archive
Used for storing rarely accessed (once a year) data.
Table 7 SseCHeader
Type
Mandatory (Yes/No)
Encryption
string
Explanation:
Value range:
Default value:
None
Key
string
Explanation:
Restrictions:
Default value:
None
KeyMD5
string
Explanation:
Restrictions:
Default value:
None
Table 8 SseKmsHeader
Type
Mandatory (Yes/No)
Encryption
string
Explanation:
SSE-KMS used for encrypting objects
Value range:
kms, indicating objects are encrypted using SSE-KMS
Default value:
None
Key
string
Explanation:
ID of the KMS master key when SSE-KMS is used
Value range:
Valid value formats are as follows:
  1. regionID:domainID:key/key_id
  2. key_id
In the preceding formats:
Default value:
  • If this parameter is not specified, the default master key will be used.
  • If there is no such a default master key, OBS will create one and use it by default.
Code Examples
This example returns the metadata of object example/objectname.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
package main
import (
    "fmt"
    "os"
    obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs"
func main() {
    //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
    //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
    ak := os.Getenv("AccessKeyID")
    sk := os.Getenv("SecretAccessKey")
    // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
    // securityToken := os.Getenv("SecurityToken")
    // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
    endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com"
    // Create an obsClient instance.
    // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance.
    obsClient, err := obs.New(ak, sk, endPoint, obs.WithSignature(obs.SignatureObs)/*, obs.WithSecurityToken(securityToken)*/)
    if err != nil {
        fmt.Printf("Create obsClient error, errMsg: %s", err.Error())
    input := &obs.GetObjectMetadataInput{}
    // Specify a bucket name.
    input.Bucket = "examplebucket"
    // Specify an object (example/objectname as an example).
    input.Key = "example/objectname"
    // Obtain the custom metadata of the object.
    output, err := obsClient.GetObjectMetadata(input)
    if err == nil {
        fmt.Printf("Get object(%s)'s metadata successful with bucket(%s)!\n", input.Key, input.Bucket)
        fmt.Printf("StorageClass:%s, ETag:%s, ContentType:%s, ContentLength:%d, LastModified:%s\n",
            output.StorageClass, output.ETag, output.ContentType, output.ContentLength, output.LastModified)
        fmt.Printf("Metadata:%v\n", output.Metadata)
        return
    fmt.Printf("Get object(%s)'s metadata fail with bucket(%s)!\n", input.Key, input.Bucket)
    if obsError, ok := err.(obs.ObsError); ok {
        fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.")
        fmt.Println(obsError.Error())
    } else {
        fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.")
        fmt.Println(err)
