Help Center/ Object Storage Service/ SDK Reference/ Go/ Buckets (SDK for Go)/ Configuring Bucket Encryption (SDK for Go)
Updated on 2024-09-05 GMT+08:00
Function
After you enable encryption for a bucket, the objects you upload to this bucket will be encrypted with the specified encryption method before they are stored in OBS. When you later download these encrypted objects, OBS decrypts them first and then returns them to you.
This API configures or updates encryption for a bucket.
Restrictions
Method
func (obsClient ObsClient) SetBucketEncryption(input *SetBucketEncryptionInput) (output *BaseModel, err error)
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
input
Yes
Explanation:
Input parameters for configuring bucket encryption. For details, see Table 2.
Table 2 SetBucketEncryptionInput
Type
Mandatory (Yes/No)
Bucket
string
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name must be unique across all accounts and regions.
  • A bucket name:
    • Must be 3 to 63 characters long and start with a digit or letter. Lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot be formatted as an IP address.
    • Cannot start or end with a hyphen (-) or period (.).
    • Cannot contain two consecutive periods (..), for example, my..bucket.
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
SSEAlgorithm
string
Yes
Explanation:
Objects are encrypted using server-side SSE-KMS.
Value range:
kms
Default value:
None
KMSMasterKeyID
string
No
Explanation:
KMS master key used for SSE-KMS
Value range:
Valid value formats are as follows:
  1. regionID:domainID:key/key_id
  2. key_id
In the preceding formats:
Default value:
If this parameter is not specified, the default master key will be used.
ProjectID
string
No
Explanation:
ID of the project where the KMS master key belongs in SSE-KMS
Restrictions:
  • The project ID must match KMSMasterKeyID.
  • Leave the project ID blank if KMSMasterKeyID is not specified.
Value range:
To obtain the project ID, see How Do I Obtain a Project ID?.
Default value:
None
Responses
Table 3 List of returned results
Type
output
*BaseModel
Explanation:
Returned results. For details, see Table 4.
err
error
Explanation:
Error messages returned by the API
Table 4 BaseModel
Type
StatusCode
int
Explanation:
HTTP status code
Value range:
A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
RequestId
string
Explanation:
Request ID returned by the OBS server
Default value:
None
ResponseHeaders
map[string][]string
Explanation:
HTTP response headers
Default value:
None
Code Examples
This example configures encryption for bucket examplebucket, with the encryption method kms and key ce706220-a1f1-4e78-9ebb-xxxxxxxxxx32 used.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
package main
import (
    "fmt"
    "os"
    obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs"
func main() {
    //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
    //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
    ak := os.Getenv("AccessKeyID")
    sk := os.Getenv("SecretAccessKey")
    // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
    // securityToken := os.Getenv("SecurityToken")
    // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
    endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com"
    // Create an obsClient instance.
    // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance.
    obsClient, err := obs.New(ak, sk, endPoint /*, obs.WithSecurityToken(securityToken)*/)
    if err != nil {
        fmt.Printf("Create obsClient error, errMsg: %s", err.Error())
    input := &obs.SetBucketEncryptionInput{}
    // Specify a bucket name.
    input.Bucket = "examplebucket"
    // Specify a server-side encryption algorithm (kms as an example).
    input.SSEAlgorithm = "kms"
    // Specify a KMS customer master key (CMK). If no CMK is specified, the default one will be used.
    input.KMSMasterKeyID = "ce706220-a1f1-4e78-9ebb-xxxxxxxxxx32"
    // Configure encryption for the bucket.
    output, err := obsClient.SetBucketEncryption(input)
    if err == nil {
        fmt.Printf("Set bucket(%s)'s encryption configuration successful!\n", input.Bucket)
        fmt.Printf("RequestId:%s\n", output.RequestId)
        return
    fmt.Printf("Set bucket(%s)'s encryption configuration fail!\n", input.Bucket)
    if obsError, ok := err.(obs.ObsError); ok {
        fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.")
        fmt.Println(obsError.Error())
    } else {
        fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.")
        fmt.Println(err)
