Creating a Parallel File System (SDK for Go)
Function
Parallel file systems (PFSs) are containers for storing objects in OBS. Files uploaded to OBS are stored as objects in PFSs. This API creates a PFS.
When creating a PFS, you can also configure parameters such as the storage class, region, and access control as needed.
Restrictions
- To create a PFS, you must have the obs:bucket:CreateBucket permission. IAM is recommended for granting permissions. For details, see IAM Custom Policies.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
When creating a PFS, if you use the endpoint obs.myhuaweicloud.com for client initialization, you do not have to specify a region (indicated by location) where the PFS will be created, because OBS automatically creates the PFS in the CN North-Beijing1 (cn-north-1) region. However, if the endpoint you use is not obs.myhuaweicloud.com, you must specify a region that matches the used endpoint, or status code 400 is returned.
For example, if the endpoint used for initialization is obs.ap-southeast-1.myhuaweicloud.com, you must set Location to ap-southeast-1 when creating a PFS. Otherwise, status code 400 is returned.
- A maximum of 100 PFSs (regardless of regions) can be created for an account. There is no limit on the number and size of objects in a PFS.
- The name of a PFS must be unique in OBS. If you repeatedly create PFSs with the same name in the same region, an HTTP status code 200 will be returned. In other cases, creating a PFS with the same name as an existing PFS will have an HTTP status code 409 returned, indicating that such a PFS already exists.
- The name of a deleted PFS can be reused for another PFS at least 30 minutes after the deletion.
- Not all regions support the creation of multi-AZ PFSs. You can check whether a region allows you to create multi-AZ PFSs by referring to Product Pricing Details.
Method
func (obsClient ObsClient) CreateBucket(input *CreateBucketInput) (output *BaseModel, err error)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| input | Yes | Explanation: Input parameters for creating a PFS. For details, see Table 2. |
| Bucket | string | Yes | Explanation: PFS name. Restrictions:
Default value: None |
| Location | string | Yes if the region where the OBS service resides is not the default region | Explanation: Region where the PFS is to be created. Restrictions: If the specified endpoint is obs.myhuaweicloud.com, this parameter is not required. If any other endpoints are specified, this parameter is required. Value range: To learn about valid regions and endpoints, see Regions and Endpoints. An endpoint is the request address for calling an API. Endpoints vary depending on services and regions. To obtain the regions and endpoints, contact the enterprise administrator. Default value: If obs.myhuaweicloud.com is used as the endpoint and no region is specified, cn-north-1 (the CN North-Beijing1 region) is used by default. |
| ACL | No | Explanation: Access control list (ACL) that can be pre-defined when a PFS is created. For details about ACLs, see ACLs. Value range: For details about the ACL options, see AclType. Default value: private | |
| StorageClass | No | Explanation: PFS storage class that can be specified at PFS creation. Value range: See Table 4. Default value: STANDARD | |
| GrantReadId | string | No | Explanation: ID (domain_id) of an account the READ permission is granted to. The account with the READ permission can list objects, multipart uploads, and object versions in the PFS you are creating, and can obtain PFS metadata. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
| GrantWriteId | string | No | Explanation: ID (domain_id) of an account the WRITE permission is granted to. The account with the WRITE permission can create, delete, and overwrite objects in the PFS you are creating, and can initiate or abort multipart uploads, as well as upload, copy, and assemble parts. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
| GrantReadAcpId | string | No | Explanation: ID (domain_id) of an account the READ_ACP permission is granted to. The account with the READ_ACP permission can read the ACL of the PFS you are creating. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
| GrantWriteAcpId | string | No | Explanation: ID (domain_id) of an account the WRITE_ACP permission is granted to. The account with the WRITE_ACP permission can modify the ACL of the PFS you are creating. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
| GrantFullControlId | string | No | Explanation: ID (domain_id) of an account the FULL_CONTROL permission is granted to. The account with the FULL_CONTROL permission can perform any operation on the PFS you are creating. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
| GrantReadDeliveredId | string | No | Explanation: ID (domain_id) of an account the READ permission is granted to. By default, this READ permission applies to all objects in the PFS. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
| GrantFullControlDeliveredId | string | No | Explanation: ID (domain_id) of an account the FULL_CONTROL permission is granted to. The account with the FULL_CONTROL permission has full control over the PFS you are creating. By default, the FULL_CONTROL permission applies to all objects in the PFS. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
| Epid | string | No | Explanation: Enterprise project ID that can be specified at PFS creation. If you have enabled EPS, you can obtain the project ID from the EPS console. Restrictions: The value of Epid is a UUID. Epid is not required if you have not enabled EPS. Example: 9892d768-2d13-450f-aac7-ed0e44c2585f Default value: None |
| AvailableZone | string | No | Explanation: Data redundancy type that can be specified at PFS creation. Restrictions: Multi-AZ redundancy is not available for Archive storage. If the region where the PFS is to be created does not support multi-AZ storage, the PFS uses single-AZ storage by default. Value range: To configure multi-AZ storage for the PFS, set this parameter to 3az. To configure single-AZ storage (default value assigned by OBS) for the PFS, you do not need to specify this parameter. Default value: single AZ |
| IsFSFileInterface | bool | No | Explanation: Whether a PFS is created Value range:
Default value: false |
| Constant | Default Value | Description |
| AclPrivate | private | Private read/write A bucket or object can only be accessed by its owner. |
| AclPublicRead | public-read | Public read and private write If this permission is granted on a bucket, anyone can read the object list, multipart tasks, metadata, and object versions in the bucket. If it is granted on an object, anyone can read the content and metadata of the object. |
| AclPublicReadWrite | public-read-write | Public read/write If this permission is granted on a bucket, anyone can read the object list, multipart tasks, metadata, and object versions in the bucket, and can upload or delete objects, initiate multipart upload tasks, upload parts, assemble parts, copy parts, and abort multipart upload tasks. If it is granted on an object, anyone can read the content and metadata of the object. |
| AclPublicReadDelivered | public-read-delivered | Public read on a bucket as well as objects in the bucket If this permission is granted on a bucket, anyone can read the object list, multipart tasks, metadata, and object versions, and read the content and metadata of objects in the bucket. NOTE: AclPublicReadDelivered does not apply to objects. |
| AclPublicReadWriteDelivered | public-read-write-delivered | Public read/write on a bucket as well as objects in the bucket If this permission is granted on a bucket, anyone can read the object list, multipart uploads, metadata, and object versions in the bucket, and can upload or delete objects, initiate multipart upload tasks, upload parts, assemble parts, copy parts, and abort multipart uploads. They can also read the content and metadata of objects in the bucket. NOTE: AclPublicReadWriteDelivered does not apply to objects. |
| AclBucketOwnerFullControl | bucket-owner-full-control | If this permission is granted on an object, only the bucket and object owners have the full control over the object. By default, if you upload an object to a bucket of any other user, the bucket owner does not have the permissions on your object. After you grant this permission to the bucket owner, the bucket owner can have full control over your object. |
| StorageClassStandard | STANDARD | OBS Standard Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response. |
| StorageClassWarm | WARM | OBS Infrequent Access Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but is instantly available when needed. |
| StorageClassCold | COLD | OBS Archive Used for storing rarely accessed (once a year) data. |
Responses
| Parameter | Type | Description |
| output | Explanation: Returned results. For details, see Table 6. | |
| err | error | Explanation: Error messages returned by the API |
| StatusCode | int | Explanation: HTTP status code Restrictions: None Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
| RequestId | string | Explanation: Request ID returned by the OBS server Restrictions: None Value range: None Default value: None |
| ResponseHeaders | map[string][]string | Explanation: HTTP response headers Restrictions: None Value range: None Default value: None |
Code Examples
This example creates a parallel file system.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 | package main import ( "fmt" "os" obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs" ) func main() { //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html. ak := os.Getenv("AccessKeyID") sk := os.Getenv("SecretAccessKey") // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are not advised to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // securityToken := os.Getenv("SecurityToken") // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com" // Create an obsClient instance. // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance. obsClient, err := obs.New(ak, sk, endPoint/*, obs.WithSecurityToken(securityToken)*/) if err != nil { fmt.Printf("Create obsClient error, errMsg: %s", err.Error()) } input := &obs.CreateBucketInput{} // Specify the name of the PFS. input.Bucket = "examplebucket" // Specify the region where the bucket is to be created. The region must be the one you specified in the endpoint. ap-southeast-1 is used as an example. input.Location = "ap-southeast-1" // Specify the bucket ACL. obs.AclPrivate is used as an example. input.ACL = obs.AclPrivate // Specify the AZ type for the bucket. 3az is used as an example. If the bucket region does not support multi-AZ storage, single-AZ storage will be applied. If this parameter is not specified, single-AZ storage is used by default. input.AvailableZone = "3az" // Specify the bucket type as PFS. input.IsFSFileInterface = true // Create a parallel file system. output, err := obsClient.CreateBucket(input) if err == nil { fmt.Printf("Create posix bucket:%s successful!\n", input.Bucket) fmt.Printf("RequestId:%s\n", output.RequestId) return } fmt.Printf("Create posix bucket:%s fail!\n", input.Bucket) if obsError, ok := err.(obs.ObsError); ok { fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.") fmt.Println(obsError.Error()) } else { fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.") fmt.Println(err) } } |
