- What's New
- Function Overview
- Product Notices
- Billing
- Getting Started
User Guide
- Accessing OBS
- Storage Class
- Bucket Management
- Object Management
- Permissions Control
- Data Security
- Disaster Recovery and Backup
- Domain Name Management
- Data Management
Data Processing
Image Processing
- Overview
- Notes and Constraints
- Basic Concepts
- Using Image Processing on OBS Console
- Using Image Processing with APIs
- Getting Information About an Image
- Getting the Average RGB Value of an Image
- Setting Image Effects
- Resizing Images
- Rotating Images
- Cropping Images
- Watermarking Images
- Converting Formats and Interlacing Images
- Changing Image Quality
- Slimming Images
- Image Processing Persistency
- Online Decompression
Image Processing
- Monitoring and Logging
- Parallel File System
Permissions Configuration Guide
- Differences Between OBS Permissions Control Methods
- OBS Access Control at a Glance
- Permission Control Methods
- Access Requests
Permission Configuration in Typical Scenarios
- Typical Permissions Scenarios
Granting Permissions to an IAM User Under the Current Account
- Granting an IAM User the Permissions to Create and List Buckets
- Granting an IAM User the Read/Write Permission on a Bucket
- Granting an IAM User the Specified Permissions for a Bucket
- Granting an IAM User the Read Permissions on Specific Objects
- Granting an IAM User the Specified Permissions on Specified Objects
Granting Permissions to Multiple IAM Users or User Groups Under the Current Account
- Granting IAM User Groups All Permissions for All OBS Resources
- Granting IAM User Groups Basic Permissions for All OBS Resources
- Granting IAM User Groups the Specified Permissions for All OBS Resources
- Granting IAM User Groups the Specified Permissions for Certain OBS Resources
- Granting IAM User Groups the Specified Permissions for a Folder
Granting Permissions to Other Accounts
- Granting Other Accounts the Read/Write Permission for a Bucket
- Granting Other Accounts the Specified Permissions for a Bucket
- Granting IAM Users Under an Account the Access to a Bucket and the Resources in It
- Granting Other Accounts the Read Permission for Certain Objects
- Granting Other Accounts the Specified Permissions for Certain Objects
- Granting Permissions to All Accounts
- Granting Temporary Access to OBS
- Allowing IAM Users to View Only Authorized Buckets
- Restricting Access to a Bucket for Specific IP Addresses
- Best Practices for Enterprise Data Access Control
- FAQs
- Appendix
Tools Guide
- OBS Tools
OBS Browser+
- Introduction
- OBS Browser+ Function Overview
- Downloading OBS Browser+
- Installing OBS Browser+
- Logging In to OBS Browser+
- Basic Bucket Operations
- Advanced Bucket Settings
- Object Operations
- Task Management
- Best Practices
- Where Can I Obtain Access Keys (AK and SK)?
- Where Can I Obtain an IAM User ID?
- Can I Install Two OBS Browser+ Tools from Different Sites in One System?
- What Are the Differences Between OBS Browser+ and OBS Browser?
- Does OBS Browser+ Support the Migration of Account and Task Information from OBS Browser?
- Why Does the Task Processing Speed Slow After the Number of Tasks Exceeds a Million?
- Why Are the Displayed Number of Objects and Used Storage Capacity Different from the Actual Number of Objects and Storage Capacity?
- Why Is the Deliver Attribute Configured Using an SDK Overwritten to False After I Configure a Bucket ACL on OBS Browser+?
- What If "Login request denied." Is Displayed When I Try to Log In to OBS Browser+ Using an Account?
- What If "Failed to obtain the user token from IAM." Is Displayed When I Try to Log In to OBS Browser+ Using an Account?
- What If Message "Incorrect Account or Password" Is Displayed When I Try to Log In to OBS Browser+ Using an Account?
- Will Incremental Upload Be Used in Auto Upload Tasks?
- How Can I Permanently Share Files or Folders with Other Users?
- How Can I Access a Specific Bucket or Directory?
- Can I Cancel the Directory Sharing After a Directory Has Been Shared with Others?
- Can I Query the Number and Size of Files in a Folder?
- How Do I Troubleshoot a DNS Resolution Failure?
- Can OBS Browser+ List Objects with Special Characters in Their Names?
- Why Are Objects Always in the Restoring State?
- Uninstalling OBS Browser+
- Change History
obsutil
- obsutil Introduction
- Downloading and Installing obsutil
- Getting Started
- Bucket Commands
Object Commands
- Creating a Folder
- Uploading an Object
- Querying Object Properties
- Setting Object Properties
- Listing Objects
- Copying an Object
- Moving an Object
- Downloading an Object
- Generating the Download Link of an Object
- Deleting an Object
- Synchronously Uploading Incremental Objects
- Synchronously Copying Incremental Objects
- Synchronously Downloading Incremental Objects
- Restoring Objects from the Archive Storage
- Resuming a Failed Upload Task
- Resuming a Failed Copy Task
- Resuming a Failed Download Task
- Listing Multipart Upload Tasks
- Deleting a Multipart Upload Task
- Creating an Authorization Code for Directory Sharing
- Listing Objects by Using an Authorization Code
- Downloading Objects by Using an Authorization Code
- Auxiliary Commands
- Common Examples
- Fault Locating
Best Practices
- Using the obsutil help Command to Search for Functions
- Configuring Scheduled Tasks Using the Crontab Command
- Setting obsutil Commands as Built-in Commands
- Configuring Auto Obtaining of Access Keys for obsutil
- Fine-Tuning obsutil Performance
- Using obsutil for Resumable Data Transfer
- Using obsutil to Upload a Symbolic Link
- Configuring an HTTP Proxy for obsutil
- Using obsutil to Share Directories
- Using obsutil to Replicate Data Across Regions on the Client Side
- Limiting the Upload and Download Rate for obsutil
- After Some Files Are Deleted in My Local Directory, Can obsutil Synchronously Delete Them from the Bucket?
- Can I Use obsutil to Directly Save a Listing Result to a Local File?
- Why Is the Size of Objects Queried by obsutil Inconsistent with That on OBS Console?
- How Can I Find Out Why Some Tasks in a Batch Task Failed?
- How Can I Locate and Rectify I/O Timeout and EOF Errors?
- Why Is a Question Mark Displayed in the Batch Task Progress Bar?
- Can Multiple config Files Be Placed in One Directory?
- Why Is the Number of Objects I Downloaded from OBS to My Local Windows PC Different from That in OBS?
- Can I Rename an Object or a Folder?
- Configuration Parameters
- obsfs (abandoned)
Best Practices
- Overview
- Uploading Data to OBS
- Migrating Data to OBS
- Accessing Data Stored in OBS
- Using a User-Defined Domain Name to Host a Static Website
- Verifying Data Consistency
- Suggestions on OBS Security Configuration
- Suggestions on OBS Performance Optimization
- Using OBS to Decouple Storage from Compute in Big Data Scenarios
- Using s3fs to Mount an OBS Bucket
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
APIs
- Operations on Buckets
- Configuring a Bucket Policy
- Obtaining Bucket Policy Information
- Deleting a Bucket Policy
- Configuring a Bucket ACL
- Obtaining Bucket ACL Information
- Configuring Logging for a Bucket
- Obtaining a Bucket Logging Configuration
- Configuring Bucket Lifecycle Rules
- Obtaining Bucket Lifecycle Configuration
- Deleting Lifecycle Rules
- Configuring Versioning for a Bucket
- Obtaining Bucket Versioning Status
- Configuring Storage Class for a Bucket
- Obtaining Bucket Storage Class Information
- Configuring Cross-Region Replication for a Bucket
- Obtaining the Cross-Region Replication Configuration of a Bucket
- Deleting the Cross-Region Replication Configuration of a Bucket
- Configuring Tags for a Bucket
- Obtaining Bucket Tags
- Deleting Tags
- Configuring Bucket Storage Quota
- Querying Bucket Storage Quota
- Obtaining Storage Information of a Bucket
- Configuring Bucket Inventories
- Obtaining a Specific Inventory of a Bucket
- Listing All Inventories of a Bucket
- Deleting Bucket Inventories
- Configuring a Custom Domain Name for a Bucket
- Obtaining the Custom Domain Name of a Bucket
- Deleting the Custom Domain Name of a Bucket
- Configuring Bucket Encryption
- Obtaining Bucket Encryption Configuration
- Deleting the Encryption Configuration of a Bucket
- Setting the Direct Reading Policy for Archive Objects in a Bucket
- Obtaining the Direct Reading Policy of Archive Objects in a Bucket
- Deleting the Direct Reading Policy of Archive Objects in a Bucket
- Configuring Mirroring Back-to-Source Rules
- Obtaining Mirroring Back-to-Source Rules
- Deleting Mirroring Back-to-Source Rules
- Setting an Online Decompression Policy
- Obtaining an Online Decompression Policy
- Deleting an Online Decompression Policy
- Configuring a Default WORM Policy for a Bucket
- Obtaining the Default WORM Policy of a Bucket
Static Website Hosting
- Configuring Static Website Hosting for a Bucket
- Obtaining the Static Website Hosting Configuration of a Bucket
- Deleting the Static Website Hosting Configuration of a Bucket
- Configuring Bucket CORS
- Obtaining the CORS Configuration of a Bucket
- Deleting the CORS Configuration of a Bucket
- OPTIONS Bucket
- OPTIONS Object
Operations on Objects
- Uploading an Object - PUT
- Uploading an Object - POST
- Copying an Object
- Querying Object Metadata
- Deleting Objects
- Restoring Archive or Deep Archive Objects
- Appending an Object
- Configuring an Object ACL
- Obtaining Object ACL Configuration
- Modifying Object Metadata
- Modifying an Object
- Truncating an Object
- Renaming an Object
- Configuring WORM Retention for an Object
- Operations on Multipart Upload
- Server-Side Encryption
- Error Codes
- Appendixes
SDK Reference
- SDK Overview
- SDK Function Matrices
Python
- Before You Start (SDK for Python)
- API Overview of OBS SDK for Python
- Preparations (SDK for Python)
- Downloading and Installing OBS SDK for Python
- Getting Started with OBS SDK for Python
- Initialization (SDK for Python)
Bucket-Related APIs (SDK for Python)
- Creating a Bucket (SDK for Python)
- Obtaining a Bucket List (SDK for Python)
- Checking Whether a Bucket Exists (SDK for Python)
- Deleting a Bucket (SDK for Python)
- Listing Objects in a Bucket (SDK for Python)
- Listing Object Versions in a Bucket (SDK for Python)
- Obtaining Bucket Metadata (SDK for Python)
- Obtaining the Region of a Bucket (SDK for Python)
- Obtaining Storage Information of a Bucket (SDK for Python)
- Configuring a Storage Quota (SDK for Python)
- Obtaining a Bucket Storage Quota (SDK for Python)
- Configuring a Storage Class for a Bucket (SDK for Python)
- Obtaining the Storage Class of a Bucket (SDK for Python)
- Configuring a Bucket ACL (SDK for Python)
- Obtaining a Bucket ACL (SDK for Python)
- Configuring Logging for a Bucket (SDK for Python)
- Obtaining the Logging Configuration of a Bucket (SDK for Python)
- Configuring a Bucket Policy (SDK for Python)
- Obtaining the Policy of a Bucket (SDK for Python)
- Deleting a Bucket Policy (SDK for Python)
- Configuring Lifecycle Rules for a Bucket (SDK for Python)
- Obtaining the Lifecycle Configuration of a Bucket (SDK for Python)
- Deleting the Lifecycle Configuration of a Bucket (SDK for Python)
- Configuring Static Website Hosting for a Bucket (SDK for Python)
- Obtaining Static Website Hosting for a Bucket (SDK for Python)
- Deleting Static Website Hosting for a Bucket (SDK for Python)
- Configuring Versioning for a Bucket (SDK for Python)
- Obtaining the Versioning Status of a Bucket (SDK for Python)
- Configuring CORS for a Bucket (SDK for Python)
- Obtaining the CORS Configuration of a Bucket (SDK for Python)
- Deleting the CORS Configuration of a Bucket (SDK for Python)
- Configuring Tags for a Bucket (SDK for Python)
- Obtaining Bucket Tags (SDK for Python)
- Deleting Bucket Tags (SDK for Python)
Object-Related APIs (SDK for Python)
- Object Upload Overview (SDK for Python)
- Uploading Objects - Text-Based (SDK for Python)
- Uploading an Object - Streaming (SDK for Python)
- Uploading an Object - File-Based (SDK for Python)
- Uploading an Object - Append (SDK for Python)
- Uploading an Object - Resumable (SDK for Python)
- Obtaining the Upload Progress (SDK for Python)
- Uploading an Object - Browser-Based (SDK for Python)
- Object Download Overview (SDK for Python)
- Downloading an Object - Binary (SDK for Python)
- Downloading an Object - Streaming (SDK for Python)
- Downloading an Object - File-Based (SDK for Python)
- Downloading an Object - Range-Based (SDK for Python)
- Downloading an Object - Resumable (SDK for Python)
- Downloading an Object - Obtaining the Download Progress (SDK for Python)
- Uploading an Object - Creating a Folder (SDK for Python)
- Copying an Object (SDK for Python)
- Deleting an Object (SDK for Python)
- Batch Deleting Objects (SDK for Python)
- Obtaining Object Metadata (SDK for Python)
- Modifying Object Metadata (SDK for Python)
- Configuring an Object ACL (SDK for Python)
- Obtaining an Object ACL (SDK for Python)
- Restoring an Archive Object (SDK for Python)
APIs Related to Multipart Upload (SDK for Python)
- Multipart Upload Overview (SDK for Python)
- Initiating a Multipart Upload (SDK for Python)
- Uploading a Part (SDK for Python)
- Listing Uploaded Parts (SDK for Python)
- Listing Multipart Uploads (SDK for Python)
- Assembling Parts (SDK for Python)
- Copying a Part (SDK for Python)
- Aborting a Multipart Upload (SDK for Python)
- Client-Side Encryption APIs (SDK for Python)
- Other APIs (SDK for Python)
- Troubleshooting (SDK for Python)
FAQs (SDK for Python)
- How Do I Make an Object Accessible to Anonymous Users? (SDK for Python)
- How Can I Obtain the AK and SK? (SDK for Python)
- How Do I Obtain an Object URL? (Python SDK)
- How Do I Improve the Uploading Speed of Large Files over the Public Network? (SDK for Python)
- How Do I Specify Content-SHA256? (SDK for Python)
- Why Does the SDK Source Code Contain acs.amazonaws.com? (SDK for Python)
- Setting an Object Expiration Time (SDK for Python)
- What Is Content-Type (MIME)? (Python SDK)
- How Do I Get My Account ID and IAM User ID? (SDK for Python)
Java
- Before You Start (SDK for Java)
- API Overview (SDK for Java)
- Preparations (SDK for Java)
- SDK Download and Installation (SDK for Java)
- Getting Started (SDK for Java)
- Initialization (SDK for Java)
Bucket Management (SDK for Java)
- Creating a Bucket (SDK for Java)
- Obtaining a Bucket List (SDK for Java)
- Deleting a Bucket (SDK for Java)
- Checking Whether a Bucket Exists (SDK for Java)
- Obtaining Bucket Metadata (SDK for Java)
- Configuring a Bucket ACL (SDK for Java)
- Obtaining a Bucket ACL (SDK for Java)
- Configuring a Bucket Policy (SDK for Java)
- Obtaining the Policy of a Bucket (SDK for Java)
- Deleting a Bucket Policy (SDK for Java)
- Obtaining the Region of a Bucket (SDK for Java)
- Obtaining Storage Information of a Bucket (SDK for Java)
- Configuring a Storage Quota (SDK for Java)
- Obtaining a Bucket Storage Quota (SDK for Java)
- Configuring a Storage Class for a Bucket (SDK for Java)
- Obtaining the Storage Class of a Bucket (SDK for Java)
- Bucket Inventory (SDK for Java)
- Parallel File System Management (SDK for Java)
Object Upload (SDK for Java)
- Overview (SDK for Java)
- Uploading an Object - Streaming (SDK for Java)
- Uploading an Object - File-Based (SDK for Java)
- Obtaining the Upload Progress (SDK for Java)
- Creating a Folder (SDK for Java)
- Configuring Object Metadata (SDK for Java)
Multipart Upload (SDK for Java)
- Multipart Upload Overview (SDK for Java)
- Initiating a Multipart Upload (SDK for Java)
- Uploading a Part (SDK for Java)
- Assembling Parts (SDK for Java)
- Code Example of a Multipart Upload (SDK for Java)
- Aborting a Multipart Upload (SDK for Java)
- Listing Uploaded Parts (SDK for Java)
- Listing Multipart Uploads (SDK for Java)
- Configuring Lifecycle Rules (SDK for Java)
- Uploading an Object - Append (SDK for Java)
- Uploading an Object - Resumable (SDK for Java)
- Uploading an Object - Browser-Based (SDK for Java)
Object Download (SDK for Java)
- Downloading an Object - Streaming (SDK for Java)
- Downloading an Object - Range-Based (SDK for Java)
- Obtaining the Download Progress (SDK for Java)
- Downloading an Object - Conditional (SDK for Java)
- Rewriting Response Headers (SDK for Java)
- Obtaining User-defined Metadata (SDK for Java)
- Restoring an Archive Object (SDK for Java)
- Downloading an Object - Resumable (SDK for Java)
- Downloading a Processed Image (SDK for Java)
- Creating a Signed URL for Downloading a Processed Image (SDK for Java)
Object Management (SDK for Java)
- Obtaining Object Metadata (SDK for Java)
- Configuring an Object ACL (SDK for Java)
- Obtaining an Object ACL (SDK for Java)
- Listing Objects (SDK for Java)
- Deleting an Object (SDK for Java)
- Batch Deleting Objects (SDK for Java)
- Copying an Object (SDK for Java)
- Copying an Object - Multipart (SDK for Java)
- Checking Whether an Object Exists (SDK for Java)
- Temporarily Authorized Access (SDK for Java)
Versioning (SDK for Java)
- Configuring Versioning for a Bucket (SDK for Java)
- Obtaining the Versioning Status of a Bucket (SDK for Java)
- Obtaining an Object Version (SDK for Java)
- Copying an Object Version (SDK for Java)
- Restoring a Specific Archive Object Version (SDK for Java)
- Listing Object Versions (SDK for Java)
- Setting an ACL for an Object Version (SDK for Java)
- Obtaining the ACL of an Object Version (SDK for Java)
- Deleting an Object Version (SDK for Java)
- Batch Deleting Object Versions (SDK for Java)
- Lifecycle Management (SDK for Java)
- Cross-Origin Resource Sharing (SDK for Java)
- Logging (SDK for Java)
- Static Website Hosting (SDK for Java)
- Bucket Tag Management (SDK for Java)
- Server-Side Encryption (SDK for Java)
- Client-Side Encryption (SDK for Java)
- Fault Locating (SDK for Java)
- Troubleshooting (SDK for Java)
FAQs (SDK for Java)
- Can I Use This Document for Union SDK?
- How Can I Set an Object to Be Accessible to Anonymous Users? (Java SDK)
- What Is the Retry Mechanism of SDK? (SDK for Java)
- How Do I Obtain the Static Website Access Address of a Bucket? (Java SDK)
- How Do I Obtain an Object URL? (Java SDK)
- How to Improve the Speed of Uploading Large Files over the Public Network? (SDK for Java)
- How Can I Perform a Multipart Upload? (SDK for Java)
- How Can I Perform a Download in Multipart Mode? (Java SDK)
- How Do I Confirm that an Upload is Successful If I Upload an Object to Overwrite an Existing Object with the Same Name in a Bucket? (SDK for Java)
- How Do I Download an Encrypted Object Using a URL? (SDK for Java)
- How Do I Generate an SSE-C Encryption Key?
- How Do I Obtain the Security Token? (Java SDK)
- Does the SDK Support Uploading, Downloading, or Copying Objects in a Batch? (Java SDK)
- Why Does the SDK Source Code Contain acs.amazonaws.com? (Java SDK)
- What Is Content-Type (MIME)? (Java SDK)
- How Do I Get My Account ID and User ID?
Go
- Before You Start (SDK for Go)
- API Overview of OBS SDK for Go
- Preparations (SDK for Go)
- Downloading and Installing OBS SDK for Go
- Getting Started with OBS SDK for Go
- Initializing OBS SDK for Go
Buckets (SDK for Go)
- Bucket API Overview (SDK for Go)
- Creating a Bucket (SDK for Go)
- Obtaining a Bucket List (SDK for Go)
- Checking Whether a Bucket Exists (SDK for Go)
- Deleting a Bucket (SDK for Go)
- Listing Objects in a Bucket (SDK for Go)
- Listing Object Versions in a Bucket (SDK for Go)
- Obtaining Bucket Metadata (SDK for Go)
- Obtaining the Region of a Bucket (SDK for Go)
- Obtaining Storage Information of a Bucket (SDK for Go)
- Configuring a Storage Quota (SDK for Go)
- Obtaining a Bucket Storage Quota (SDK for Go)
- Configuring Storage Class for a Bucket (SDK for Go)
- Obtaining the Storage Class of a Bucket (SDK for Go)
- Configuring a Bucket ACL (SDK for Go)
- Obtaining the Bucket ACL (SDK for Go)
- Configuring Logging for a Bucket (SDK for Go)
- Obtaining the Logging Configuration of a Bucket (SDK for Go)
- Configuring a Bucket Policy (SDK for Go)
- Obtaining the Policy of a Bucket (SDK for Go)
- Deleting a Bucket Policy (SDK for Go)
- Configuring Lifecycle Rules for a Bucket (SDK for Go)
- Obtaining the Lifecycle Configuration of a Bucket (SDK for Go)
- Deleting the Lifecycle Configuration of a Bucket (SDK for Go)
- Configuring Static Website Hosting for a Bucket (SDK for Go)
- Obtaining the Static Website Hosting Configuration of a Bucket (SDK for Go)
- Deleting the Static Website Hosting Configuration of a Bucket (SDK for Go)
- Configuring Versioning for a Bucket (SDK for Go)
- Obtaining the Versioning Status of a Bucket (SDK for Go)
- Configuring CORS for a Bucket (SDK for Go)
- Obtaining the CORS Configuration of a Bucket (SDK for Go)
- Deleting the CORS Configuration of a Bucket (SDK for Go)
- Configuring Tags for a Bucket (SDK for Go)
- Obtaining Bucket Tags (SDK for Go)
- Deleting Bucket Tags (SDK for Go)
- Configuring Bucket Encryption (SDK for Go)
- Obtaining the Bucket Encryption Configuration (SDK for Go)
- Deleting the Bucket Encryption Configuration (SDK for Go)
- Configuring a Custom Domain Name for a Bucket (SDK for Go)
- Obtaining the Custom Domain Name of a Bucket (SDK for Go)
- Deleting the Custom Domain Name of a Bucket (SDK for Go)
- Parallel File System APIs (SDK for Go)
Objects (SDK for Go)
- Object API Overview (SDK for Go)
- Object Upload Overview (SDK for Go)
- Object Download Overview (SDK for Go)
- Creating a Folder (SDK for Go)
- Copying an Object (SDK for Go)
- Deleting an Object (SDK for Go)
- Batch Deleting Objects (SDK for Go)
- Configuring Object Metadata (SDK for Go)
- Obtaining Object Metadata (SDK for Go)
- Configuring an Object ACL (SDK for Go)
- Obtaining Object ACL Information (SDK for Go)
- Rewriting Response Headers (SDK for Go)
- Processing an Image (SDK for Go)
- Restoring an Archive Object (SDK for Go)
- Modifying an Object (SDK for Go)
- Multipart Uploads (SDK for Go)
- Other APIs (SDK for Go)
- Single-Connection Bandwidth Throttling (SDK for Go)
- Troubleshooting (SDK for Go)
- FAQ (SDK for Go)
Android
- Installing the SDK
- Example Programs
- Quick Start
- Initialization
- Bucket Management
Object Upload
- Performing a Streaming Upload
- Performing a File-Based Upload
- Obtaining Upload Progresses
- Creating a Folder
- Performing a Multipart Upload
- Configuring Lifecycle Management
- Performing an Appendable Upload
- Performing a Multipart Copy
- Performing a Resumable Upload
- Performing a Browser-Based Upload
- Object Download
- Object Management
- Versioning Management
- CORS
- Access Logging
- Tag Management
- Troubleshooting
- FAQ
- API Reference
C
- Before You Start
- Downloading and Installing the SDK
- Quick Start
- Initialization
- Bucket Management
- Object Management
- Temporarily Authorized Request
- Accessing OBS Through a User-Defined Domain Name
- Cross-Origin Resource Sharing (CORS)
- Setting Access Logging
- Tag Management
- Troubleshooting
- FAQs
BrowserJS
- Before You Start
- SDK Download Links
- Example Programs
- Quick Start
- Initialization
- Fault Locating
- Bucket Management
Object Upload
- Performing a Text-Based Upload
- Creating a Folder
Object Download
- Performing a Text-Based Download
- Performing a Binary Download
- Performing a File-Based Download
- Performing a Partial Download
- Obtaining Download Progresses
- Performing a Conditioned Download
- Obtaining Customized Metadata
- Downloading an Archive Object
- Object Management
- Access Logging
- Tag Management
- Troubleshooting
- How Do I Upload Files Using a Browser that Does Not Support window.File?
- How Do I Suspend a Resumable Upload Task?
- How Do I Interact with OBS Without Exposing My AK and SK?
- How Do I Upload a Base64-Encoded Image?
- What Do I Do If the Resumable Upload API Reports a "400 InvalidPart" Error?
iOS
- Compatibility
- Quick Start
- Initialization
- Bucket Management
Object Upload
- Creating a Folder
- Appendable Upload
- Pausing and Resuming/Aborting a Resumable Upload
- Object Download
- Object Management
- CORS
- Access Logging
- Tag Management
- Troubleshooting
- FAQ
- API Reference
PHP
- Example Programs
Quick Start
- Before You Start
- Setting Up an OBS Environment
- Preparing a Development Environment
- Obtaining Endpoints
- Initializing an Instance of ObsClient
- Creating a Bucket
- Listing Objects
- General Examples of ObsClient
- Pre-defined Constants
- Initialization
- Bucket Management
- Object Upload
- Object Download
- Object Management
- CORS
- Access Logging
- Tag Management
- Troubleshooting
- FAQs
Node.js
- Downloading an SDK (SDK for Node.js)
- Example Programs (SDK for Node.js)
Getting Started (SDK for Node.js)
- Before You Start (SDK for Node.js)
- Setting Up an OBS Environment (SDK for Node.js)
- Preparing a Development Environment (SDK for Node.js)
- Installing the SDK (SDK for Node.js)
- Obtaining Endpoints (SDK for Node.js)
- Initializing an Instance of ObsClient (SDK for Node.js)
- Creating a Bucket (SDK for Node.js)
- Uploading an Object (SDK for Node.js)
- Downloading an Object (SDK for Node.js)
- Listing Objects (SDK for Node.js)
- Deleting an Object (SDK for Node.js)
- General Ways to Use ObsClient (SDK for Node.js)
- Initialization (SDK for Node.js)
Bucket Management (SDK for Node.js)
- Listing Buckets (SDK for Node.js)
- Checking Whether a Bucket Exists (SDK for Node.js)
- Deleting a Bucket (SDK for Node.js)
- Obtaining Bucket Metadata (SDK for Node.js)
- Configuring a Bucket ACL (SDK for Node.js)
- Obtaining a Bucket ACL (SDK for Node.js)
- Configuring a Bucket Policy (SDK for Node.js)
- Obtaining the Policy of a Bucket (SDK for Node.js)
- Deleting a Bucket Policy (SDK for Node.js)
- Obtaining the Region of a Bucket (SDK for Node.js)
- Obtaining Storage Information of a Bucket (SDK for Node.js)
- Configuring a Storage Quota for a Bucket (SDK for Node.js)
- Obtaining the Storage Quota of a Bucket (SDK for Node.js)
- Configuring a Storage Class for a Bucket (SDK for Node.js)
- Obtaining the Storage Class of a Bucket (SDK for Node.js)
Object Upload (SDK for Node.js)
- Object Upload Overview (SDK for Node.js)
- Uploading an Object - Text-Based (SDK for Node.js)
- Uploading an Object - Streaming (SDK for Node.js)
- Uploading an Object - File-Based (SDK for Node.js)
- Creating a Folder (SDK for Node.js)
- Configuring Object Metadata (SDK for Node.js)
- Configuring a Lifecycle Rule When Uploading an Object (SDK for Node.js)
- Uploading an Object - Append (SDK for Node.js)
- Uploading an Object - Resumable (SDK for Node.js)
- Uploading an Object - Browser-Based (SDK for Node.js)
Object Download (SDK for Node.js)
- Overview (SDK for Node.js)
- Downloading an Object - Text-Based (SDK for Node.js)
- Downloading an Object - Streaming (SDK for Node.js)
- Downloading an Object - File-Based (SDK for Node.js)
- Downloading an Object - Range-Based (SDK for Node.js)
- Downloading an Object - Conditional (SDK for Node.js)
- Rewriting Response Headers (SDK for Node.js)
- Downloading an Archive Object (SDK for Node.js)
- Downloading an Object - Resumable (SDK for Node.js)
- Processing an Image (SDK for Node.js)
Object Management (SDK for Node.js)
- Obtaining Object Metadata (SDK for Node.js)
- Configuring an Object ACL (SDK for Node.js)
- Obtaining the ACL of an Object (SDK for Node.js)
- Listing Objects in a Bucket (SDK for Node.js)
- Batch Deleting Objects (SDK for Node.js)
- Copying an Object (SDK for Node.js)
Multipart Upload (SDK for Node.js)
- Multipart Upload APIs (SDK for Node.js)
- Initiating a Multipart Upload (SDK for Node.js)
- Uploading a Part (SDK for Node.js)
- Assembling Parts (SDK for Node.js)
- Listing Uploaded Parts (SDK for Node.js)
- Listing Multipart Uploads (SDK for Node.js)
- Copying a Part (SDK for Node.js)
- Aborting a Multipart Upload (SDK for Node.js)
- Temporarily Authorized Access (SDK for Node.js)
Versioning (SDK for Node.js)
- Versioning Overview (SDK for Node.js)
- Configuring Versioning for a Bucket (SDK for Node.js)
- Viewing the Versioning Status of a Bucket (SDK for Node.js)
- Obtaining an Object Version (SDK for Node.js)
- Copying an Object Version (SDK for Node.js)
- Restoring an Archive Object Version (SDK for Node.js)
- Listing Object Versions in a Bucket (SDK for Node.js)
- Setting an ACL for an Object Version (SDK for Node.js)
- Obtaining the ACL of an Object Version (SDK for Node.js)
- Deleting an Object Version (SDK for Node.js)
- Lifecycle (SDK for Node.js)
- Bucket CORS (SDK for Node.js)
- Logging (SDK for Node.js)
- Static Website Hosting (SDK for Node.js)
- Tagging (SDK for Node.js)
- Server-Side Encryption (SDK for Node.js)
- Troubleshooting (SDK for Node.js)
- FAQs (SDK for Node.js)
.NET
- Before You Start
- Example Programs
- Quick Start
- Initialization
Bucket Management
- Creating a Bucket
- Listing Buckets
- Deleting a Bucket
- Identifying Whether a Bucket Exists
- Managing Bucket ACLs
- Management Bucket Policies
- Obtaining a Bucket Location
- Obtaining Storage Information About a Bucket
- Setting or Obtaining a Bucket Quota
- Setting or Obtaining the Storage Class of a Bucket
Object Upload
- Performing an Asynchronous Upload
- Creating a Folder
Object Download
- Performing a Streaming Download
- Performing an Asynchronous Download
- Obtaining Custom Metadata
- Performing a Resumable Download
- Object Management
- CORS
- Access Logging
- Tag Management
- Troubleshooting
- FAQ
OBS Basics
- How Do I Obtain an OBS Endpoint?
- How Much Data Can I Store in OBS?
- How Can I Determine Which Region to Store My Data In?
- Does OBS Support Access over HTTPS?
- Can Other Users Access My Data Stored in OBS?
- Why Is an Alarm Reported When I Access OBS and What Can I Do?
- Can Deleted Data Be Recovered?
- What Can I Do If My Access to the OBS Domain Name Failed Due to a CA Certificate Connection Failure?
- Why Did Some of My Data Stored on OBS Get Lost?
- Does OBS Support Traffic Monitoring?
- What Are the Factors That Affect Upload and Download Speeds of OBS?
- What Are the Advantages of Object Storage over SAN and NAS Storage?
- Can Folders in OBS Be Used the Same Way as in a File System?
- What Are the Differences Between OBS, EVS, and SFS?
- How Do I Determine Whether I Am Accessing OBS over an Intranet?
- Will My Bucket Performance Be Affected by Other Users' Services?
- Why Is My Data on the OBS Bucket Overview Page Inconsistent?
- What Can I Do If There Are Packet Loss and Network Instability Problems In Cross-Border Data Transfer Scenarios?
Billing
- Why Does My Bucket Generate Storage Costs Even Though There Are No Objects in It?
- Why Does My Bucket Generate Traffic When There Are No Objects in It?
- Why Am I Still Being Billed After I Purchased a Resource Package?
- Why Am I Still Being Billed for Pull Traffic Used by CDN Acceleration When I Already Have a Pull Traffic Package?
- Why Are OBS Resources Still Unavailable Even Though My Account Has a Valid Payment Method and There Are No Outstanding Bills?
- Do I Have to Purchase a Resource Package? Can I Apply a Package to a Specific Bucket?
- Can I Unsubscribe from or Modify a Resource Package?
- What Can I Do If My Resource Package Expires?
- Do Parallel File Systems Support Resource Packages?
- How Are Requests Counted?
- Can I Purchase Requests?
- Will My Data Write Be Restricted When My OBS Package Has Been Used Up?
- Will the Remaining Package Quota in a Given Month Be Carried over to the Following Month?
- Which Types of Resource Packages Will Reset Their Quota by Month and Which Types Will Not?
- Do I Need to Purchase an Outbound Internet Traffic Package If I Already Have a Pull Traffic Package?
- Why Is There a Charge of $0.01 USD on My OBS Bill?
- Why Is There a Large Amount of Outbound Internet Traffic in My Bill?
Access Control
- Why Is the Message "Access denied" Still Appearing After OBS System Permissions or Bucket Read and Write Permissions Are Allowed?
- Why Can't I Access OBS (403 AccessDenied) After Being Granted with the OBS Access Permission?
- What Is the Relationship Between a Bucket Policy and an Object Policy?
- How Do I Control Access to Folders in an OBS Bucket?
- Why Was the Value of the delivered Parameter Changed to false After I Configured the Bucket ACL for Anonymous Users on the OBS Console?
Buckets and Objects
- Why Am I Unable to Create a Bucket?
- Why Am I Unable to Upload an Object?
- Why Am I Unable to Download an Object?
- Why Can't I Delete a Bucket?
- Why Can't I Delete an Object?
- Why Can't I Access an Object Through Its URL?
- How Do I Preview OBS Objects in My Web Browser?
- Can I Rename an Object?
- Can I Edit Objects in OBS Online?
- How Do I Obtain the Access Path to an Object?
- Can I Modify the Region of a Bucket?
- How Do I Change the Enterprise Project Where My Bucket Belongs?
- Can I Copy a File Between Buckets?
- Can I Move a File Between Buckets?
- Can I Upload Objects with the Same Name to the Same Folder?
- Does OBS Support Resumable Transfer?
- Does OBS Support Batch Upload?
- Does OBS Support Batch Download?
- Does OBS Support Batch Deletion of Objectsor Emptying a Bucket?
- What If an Object Can't Be Found in a Bucket or a 403 Error Is Returned?
- What Should I Do If an Error Message Is Displayed When I Use Internet Explorer to Access an Object URL That Contains Chinese Characters?
- Why Is an Error Reported Even If OBS CORS Has Been Configured?
- How Do I Query the Size of a Folder in a Bucket?
- How Do I Upload Objects Larger Than 5 GB?
Data Security, Migration, and Backup
- How Is Data Security Ensured in OBS?
- Can I Recover OBS Data After It Is Deleted or Overwritten?
- Can I Change the AK and SK or Share Them with Others for Accessing OBS?
- How Do I Migrate Data to OBS?
- How Does OBS Implement Backup and Disaster Recovery?
- How Can I Migrate Data Between SFS and OBS?
- Does OBS Scan My Data for Other Purposes?
- Can Engineers Export My Data from the Background of OBS?
- How Does OBS Protect My Data from Being Stolen?
- How Durable and Available Is OBS?
- What Are the Differences Between Single-AZ and Multi-AZ Storage in OBS?
- What Redundancy Techniques Does OBS Use?
- Versioning
- How Do I Access or Download an Encrypted Object?
- Why Cannot an Authorized Account or User Upload or Download KMS Encrypted Objects?
- Are Additional Permissions Required When I Share an Object with SSE-OBS Encrypted?
- Does OBS Support Encrypted Upload?
- What Techniques Can I Use to Encrypt Data on OBS?
- Will OBS Server-Side Encryption Encrypt My Existing Objects That Are Unencrypted?
- Will I Be Billed for the Encryption Provided by OBS Server-Side Encryption?
- Does OBS SSE-KMS Allow Anonymous Access?
- How Do I Use Cross-Region Replication?
- Why Is the Message "NoSuchBucket" Displayed When I Use a User-Defined Domain Name to Access a Bucket That Can Be Accessed by the OBS Domain Name?
- With CDN Acceleration Enabled, Why Are the Objects in My OBS Bucket Directly Downloaded When I Access Them?
- What Is the Relationship Between OBS Bucket Names and Domain Names?
- Why Is the CNAME Resolution Status Unknown?
- Why Can Only the Domain Names I Bought on Huawei Cloud Be Automatically Resolved In One Click?
- How Do I Use Static Website Hosting?
Image Processing
- How Do I Access Image Processing with a URL?
- After CDN Acceleration Is Enabled, Where Are Processed Images Stored?
- After I Performed Image Processing in My Logging-enabled Bucket, Why Was My Bucket Accessed by IP Addresses Starting with 100?
- How Is Image Processing Billed?
- How Many Image Styles Can I Create in a Bucket?
- Monitoring
OBS Console
- Web Browser Compatibility
- Time Difference Is Longer Than 15 Minutes Between the Client and Server
- The Object Name Changes After an Object with a Long Name Is Downloaded to a Local Computer
- An Object Fails to Be Downloaded Using Internet Explorer 11
- OBS Console Couldn't Be Opened in Internet Explorer 9
- Error Code List
OBS Browser+, obsutil, and Other OBS Tools
- When Downloading a Folder Using obsutil, the Download Speed Slows After the Folder Download Progress Reaches 90%
- With obsutil, Downloading a File Fails After the Download Progress Reaches 99%
- Slow Upload and Download Through obsutil
- How Do I Use the obsutil cp Command to Enable Incremental Upload, Download, or Replication?
- Can I Mount My Parallel File System to a Windows Server?
APIs and SDKs
- Failure with OBS SDK in Uploading a File Greater than 5 GB
- What Can I Do When Error Message "okhttp3.RequestBody.create(java.lang.String,okhttp3.MediaType)" Is Displayed for Java SDK?
- What Are the Differences Between PUT and POST Upload Methods?
- Does an Append Upload Support the Lock Mechanism for Concurrent Operations?
- Why Don't the Signatures Match?
OBS Basics
- Videos
- Glossary
More Documents
- Billing
OBS Console Operation Guide
- Console Function Overview
- Restrictions
- Getting Started
- Storage Classes Overview
- Managing Buckets
- Managing Objects
- Object Metadata
Permission Control
- Overview
- Permission Control Mechanisms
- Bucket Policy Parameters
- Configuring IAM Policies
- Configuring an Object Policy
Application Cases
- Granting an IAM User with the Operation Permissions for a Specified Bucket
- Granting Other Accounts with the Operation Permissions for a Specified Bucket
- Restricting Bucket Access to a Specified Address
- Configuring the Start Time and End Time of Access to Objects in a Bucket
- Authorizing Access Permissions to Anonymous Users
- Authorizing Folder Access Permissions to Anonymous Users
- Versioning
- Logging
- Tags
- Event Notification
- User-Defined Domain Name Binding
- CORS
- URL Validation
- Monitoring
- Related Operations
Troubleshooting
- OBS Console Cannot Be Opened in Internet Explorer 9
- Failed to Configure Event Notification
- Error Code List
OBS Basics
- How Can I Get Started Using OBS?
- Which Types of Data Can Be Stored in OBS?
- Where Is Data Stored in OBS?
- What Is the Relationship Between OBS Bucket Names and OBS Domain Names?
- Does OBS Support Resumable Data Transfer?
- Does OBS Support Batch Deletion of Objects?
- What Are Factors that Affect the Upload and Download Speed of OBS?
- Will There Be Data Left Over in OBS After I Delete an Object?
- Access Control
Buckets and Objects
- What Is the Relationship Between Bucket Storage Classes and Object Storage Classes?
- Why Can't I Find Certain Objects in a Bucket When I Searched for Them?
Security
- Can Background Engineers Export My Data from OBS?
- How Does OBS Prevent My Data from Being Stolen?
- Can a Pair of AK and SK Be Replaced When They Are Being Used to Access OBS?
- Can a Pair of AK and SK Be Used by Multiple Users to Access OBS?
- Which Encryption Technologies Are Supported by OBS?
- How Do I Use Fragment Management?
- How Do I Use Versioning?
- How Do I Use Tags?
- How Do I Use Lifecycle Management?
OBS Basics
- Change History
- Before You Start
- API Overview
- Calling APIs
- Getting Started
APIs
- Configuring Event Notification for a Bucket
- Obtaining the Event Notification Configuration of a Bucket
- Deleting Tags
- Configuring a DIS-Enabled Notification Policy
- Obtaining a DIS-Enabled Notification Policy
- Deleting a DIS-Enabled Notification Policy
- OPTIONS Bucket
- OPTIONS Object
- Uploading Objects - PUT
- Uploading Objects - POST
- Copying Objects
- Deleting Objects
- Restoring Cold Objects
- Error Codes
- IAM Policies and Supported Actions
- Appendixes
- Change History
Tool Guide (OBS Browser+) (ME-Abu Dhabi Region)
- Introduction
- How Can I Locate Common Network Errors?
- Can I Query the Number and Size of Files in a Folder on OBS Browser+?
- Change History
- Tool Guide (obsfs) (ME-Abu Dhabi Region)
Tool Guide (obsutil) (ME-Abu Dhabi Region)
- Getting Started
- Bucket Commands
Object Commands
- Creating a Folder
- Listing Objects
- Copying an Object
- Moving an Object
- Restoring Objects from the Storage
- Common Examples
- Fault Locating
Best Practices
- Change History
- Parallel File System Feature Guide(ME-Abu Dhabi Region)
User Guide (Paris Region)
- Restrictions
- Getting Started
- Managing Buckets
- Managing Objects
- Object Metadata
Permissions Control
- Overview
Application Cases
- Granting an IAM User Permissions to Operate a Specific Bucket
- Granting Other Accounts Permissions to Operate a Specific Bucket
- Restricting Access to a Bucket for Specific Addresses
- Limiting the Time When Objects in a Bucket Are Accessible
- Granting Anonymous Users Permission to Access Objects
- Granting Anonymous Users Permission to Access Folders
- Versioning
- Logging
- Event Notifications
- Cross-Region Replication
- Configuring User-Defined Domain Names
- URL Validation
- Monitoring
Troubleshooting
- Failed to Configure Event Notifications
- Error Code List
FAQ
OBS Basics
- How Can I Get Started with OBS?
- What Are the Factors That Affect Upload and Download Speed of OBS?
- Access Control
Buckets and Objects
- Why Can't I Search for Certain Objects in My Bucket?
- Tools
- APIs and SDKs
Security
- Can a Pair of AK and SK Be Replaced When It Is Being Used to Access OBS?
- Can Multiple Users Share One Pair of AK and SK to Access OBS?
OBS Basics
- Change History
Tool Guide (OBS Browser+) (Paris Region)
- Introduction
- Does OBS Browser+ Support the Migration of Account and Task Information From OBS Browser?
- Change History
- Tool Guide (obsfs) (Paris Region)
Tool Guide (obsutil) (Paris Region)
- Getting Started
- Bucket Commands
Object Commands
- Creating a Folder
- Listing Objects
- Copying an Object
- Moving an Object
- Restoring Objects from the Cold Storage
- Common Examples
- Fault Locating
Best Practices
- Change History
- Parallel File System Feature Guide(Paris Region)
Image Processing (Paris Region)
- Introduction
- Start to Process (Using OBS Console)
- Start to Process (Using APIs)
- Typical Cases
- Obtaining Image Information
- Obtaining Average RGB Value of an Image
- Resizing Images
- Rotating Images
- Cropping Images
- Changing Quality
- Slimming Images
- Image Persistency
- FAQ
- Change History
Permissions Configuration Guide (Paris Region)
- Introduction to OBS Access Control
- Access Requests
- Typical Permission Control Scenarios
Configuration Cases in Typical Permission Control Scenarios
- Granting an IAM User the Permissions Required to List and Create Buckets
- Granting an IAM User the Read/Write Permission for a Bucket
- Granting an IAM User the Read Permission for Specific Objects
- Granting an IAM User the Specified Permissions for Certain Objects
- Granting Permissions to Anonymous Users
- Appendix
- Change History
- Restrictions
- Getting Started
- Managing Buckets
- Managing Objects
- Object Metadata
- Bucket Inventories
Permissions Control
- Overview
Application Cases
- Versioning
- Logging
- Tags
- URL Validation
- Monitoring
Troubleshooting
- Error Code List
FAQ
OBS Basics
- Access Control
Buckets and Objects
- What Do I Do If I Encounter an Error While Trying to Access an Object URL with Full-Width Characters Using Internet Explorer?
- Tools
- APIs and SDKs
Security
- Fragment Management
- Versioning
- Tags
OBS Basics
- Change History
- Before You Start
- API Overview
- Calling APIs
- Getting Started
APIs
- Deleting Tags
- OPTIONS Bucket
- OPTIONS Object
- Copying an Object
- Deleting Objects
- Error Codes
- Appendixes
- Change History
Tool Guide (OBS Browser+) (Kuala Lumpur Region)
- Introduction
- Change History
- Tool Guide (obsfs) (Kuala Lumpur Region)
- Parallel File System Feature Guide (Kuala Lumpur Region)
- Best Practices (Kuala Lumpur Region)
User Guide (Ankara Region)
- Configuration Before Use
- Restrictions
- Getting Started
- Managing Buckets
- Managing Objects
- Object Metadata
Permissions Control
- Overview
Application Cases
- Versioning
- Logging
- Cross-Cluster Replication
- URL Validation
- Task Center
- Two-AZ DR
Troubleshooting
- Error Code 500 Is Returned When a Bucket with the Name of the Bucket Failing to Be Created in AZ 2 Is Created in AZ 1
- Object Upload or Download Errors
- Error Code List
FAQ
OBS Basics
- Access Control
Buckets and Objects
- Does OBS Support Storage Quota Management?
Security
- Durability and Availability
- Versioning
OBS Basics
- Change History
API Reference (Ankara Region)
- Before You Start
- API Overview
- Calling APIs
- Getting Started
APIs
- Deleting Tags
- Configuring Cross-Cluster Replication for a Bucket
- Obtaining the Cross-Cluster Replication Configuration of a Bucket
- Deleting the Cross-Cluster Replication Configuration of a Bucket
- OPTIONS Bucket
- OPTIONS Object
- Copying an Object
- Deleting Objects
- Error Codes
- Appendixes
- Change History
- Parallel File System Feature Guide(Ankara Region)
Tool Guide (OBS Browser+) (Ankara Region)
- Introduction
- Change History
Tool Guide (obsutil) (Ankara Region)
- Getting Started
- Bucket Commands
Object Commands
- Creating a Folder
- Listing Objects
- Copying an Object
- Moving an Object
- Common Examples
- Fault Locating
Best Practices
- Change History
Operation Guide (Leaving soon. Moving to User Guide.)
- Before You Start
- Storage Classes
- Bucket Management
- Object Management
- Data Management
- Data Access
- Data Security
- Data Processing
Image Processing (Leaving soon. Moving to User Guide.)
- Introduction
- Typical Cases
- Resizing Images
- Rotating Images
- Cropping Images
- Converting Image Formats
- Slimming Images
FAQ
- What Is Image Processing?
- How Do I Access Image Processing?
- What Formats Does Image Processing Support?
- Where Are Processed Images Stored After CDN Acceleration Is Enabled?
- Why Was My Bucket Accessed by IP Addresses Starting with 100 After I Performed Image Processing in My Logging-enabled Bucket?
- Parallel File System (Leaving soon. Moving to User Guide.)
Downloading an Object - Resumable (SDK for Go)
Function
Downloading large files often fails due to poor network conditions or program breakdowns. It is a waste of resources to restart the download process upon a download failure, and the restarted download process may still suffer from the unstable network. To resolve such issues, the resumable download API splits the file to be downloaded into multiple parts and downloads them separately. The download result of each part is recorded in a checkpoint file in real time. Only when all parts are successfully downloaded, the result indicating a successful download is returned. Otherwise, an error message is returned to remind you of calling the API again for re-downloading. Based on the download status of each part recorded in the checkpoint file, the re-downloading will download the parts failed to be downloaded previously, instead of downloading all parts. By virtue of this, resources are saved and efficiency is improved.
This API calls ObsClient.DownloadFile to perform a resumable download.
Restrictions
- To download an object, you must be the bucket owner or have the required permission (obs:object:GetObject in IAM or GetObject in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
- The resumable download API, which is implemented based on partial download, is an encapsulated and enhanced version of partial download.
- This API saves resources and improves efficiency upon the re-download, and speeds up the download process by concurrently downloading parts. Because this API is invisible to users, users are unaware of internal service details, such as the creation and deletion of checkpoint files, division of objects, and concurrent download of parts.
- EnableCheckpoint: The default value is False, indicating that resumable download is disabled. In this case, the resumable download API is a simple encapsulation of the partial download API, and no checkpoint file will be generated.
- CheckpointFile: This parameter is effective only when EnableCheckpoint is True.
Method
func (obsClient ObsClient) DownloadFile(input *DownloadFileInput) (output *GetObjectMetadataOutput, err error)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
input |
Yes |
Explanation: Input parameters for a resumable download. For details, see Table 2. |
Parameter |
Type |
Description |
Bucket |
string |
Yes |
Explanation: Bucket name Restrictions:
Default value: None |
Key |
string |
Yes |
Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
VersionId |
string |
No |
Explanation: Object version ID, for example, G001117FCE89978B0000401205D5DC9 Value range: The value must contain 32 characters. Default value: None. If this parameter is left blank, the latest version of the object is obtained. |
DownloadFile |
string |
No |
Explanation: Full path of the local directory to which the object is downloaded. Default value: If the parameter is left blank, the downloaded object is saved in the directory where the program is executed. |
PartSize |
int64 |
No |
Explanation: Part size Value range: The value must be greater than 0 but less than the object size, in bytes. Default value: 9437184, indicating 9 MB for each part |
TaskNum |
int |
No |
Explanation: Maximum number of parts that can be downloaded concurrently Value range: The value must be greater than 0 but not exceed the result of the file size divided by the part size (rounded up). Default value: 1, indicating concurrent downloads are not used. |
EnableCheckpoint |
bool |
No |
Explanation: Whether to enable the resumable download Value range:
Default value: false |
CheckpointFile |
string |
No |
Explanation: File used to record the download progress. This parameter is valid only in a resumable download. Default value: If the parameter is left blank, the file is in the same local directory as the downloaded object. |
SseHeader |
No |
Explanation: Server-side decryption headers. For details, see Table 3. |
IfMatch |
string |
No |
Explanation: Preset ETag. If the ETag of the object to be downloaded is the same as the preset ETag, the object is returned. Otherwise, an error is returned. Value range: The value must contain 32 characters. Default value: None |
IfNoneMatch |
string |
No |
Explanation: Preset ETag. If the ETag of the object to be downloaded is different from the preset ETag, the object is returned. Otherwise, an error is returned. Value range: The value must contain 32 characters. Default value: None |
IfModifiedSince |
time.Time |
No |
Explanation: The object is returned if it has been modified since the specified time; otherwise, an error is returned. Restrictions: The time must be in the ISO8601 format, for example, 2018-01-01T00:00:00.000Z. Sample code: time.Now().Add(time.Duration(24) * time.Hour) Default value: None |
IfUnmodifiedSince |
time.Time |
No |
Explanation: The object is returned if it has not been modified since the specified time; otherwise, an error is returned. Restrictions: The time must be in the ISO8601 format, for example, 2018-01-01T00:00:00.000Z. Sample code: time.Now().Add(time.Duration(24) * time.Hour) Default value: None |
Parameter |
Type |
Description |
Encryption |
string |
Yes if used as a request parameter |
Explanation: SSE-C used for encrypting objects Value range: AES256, indicating objects are encrypted using SSE-C Default value: None |
Key |
string |
Explanation: Key for encrypting the object when SSE-C is used Restrictions: The value is a Base64-encoded 256-bit key, for example, K7QkYpBkM5+hca27fsNkUnNVaobncnLht/rCB2o/9Cw=. Default value: None |
KeyMD5 |
string |
No if used as a request parameter |
Explanation: MD5 value of the key for encrypting objects when SSE-C is used. This value is used to check whether any error occurs during the transmission of the key. Restrictions: The value is encrypted by MD5 and then encoded by Base64, for example, 4XvB3tbNTN+tIEVa0/fGaQ==. Default value: None |
Responses
Parameter |
Type |
Description |
output |
Explanation: Returned results. For details, see Table 5. |
err |
error |
Explanation: Error messages returned by the API |
Parameter |
Type |
Description |
StatusCode |
int |
Explanation: HTTP status code Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
RequestId |
string |
Explanation: Request ID returned by the OBS server Default value: None |
ResponseHeaders |
map[string][]string |
Explanation: HTTP response headers Default value: None |
StorageClass |
Explanation: Object storage class Value range: See Table 6. Default value: None |
AllowOrigin |
string |
Explanation: If Origin in the request meets the CORS rules of the bucket, AllowedOrigin specified in the CORS rules is returned. AllowedOrigin indicates the origin from which the requests can access the bucket. Restrictions: Domain name of the origin. Each origin can contain only one wildcard character (*), for example, https://*.vbs.example.com. Default value: None |
AllowHeader |
string |
Explanation: If RequestHeader in the request meets the CORS rules of the bucket, AllowedHeader specified in the CORS rules is returned. AllowedHeader indicates the allowed headers for cross-origin requests. Only CORS requests matching the allowed headers are valid. Restrictions: Each header can contain only one wildcard character (*). Spaces, ampersands (&), colons (:), and less-than signs (<) are not allowed. Default value: None |
AllowMethod |
string |
Explanation: AllowedMethod in the CORS rules of the bucket. It specifies the HTTP method of cross-origin requests, that is, the operation type of buckets and objects. Value range: The following HTTP methods are supported:
ExposeHeader |
string |
Explanation: ExposeHeader in the CORS rules of the bucket. It specifies the CORS-allowed additional headers in the response. These headers provide additional information to clients. By default, your browser can only access headers Content-Length and Content-Type. If your browser needs to access other headers, add them to a list of the allowed additional headers. Restrictions: Spaces, wildcard characters (*), ampersands (&), colons (:), and less-than signs (<) are not allowed. Default value: None |
MaxAgeSeconds |
int |
Explanation: MaxAgeSeconds in the CORS rules of the bucket. It specifies the time your client can cache the response for a cross-origin request. Restrictions: Each CORS rule can specify only one value for MaxAgeSeconds. Value range: 0 to (231 – 1), in seconds Default value: 100 |
ContentLength |
int64 |
Explanation: Object size in bytes Value range: The value ranges from 0 TB to 48.8 TB, in bytes. Default value: None |
ContentType |
string |
Explanation: MIME type of the file to be downloaded. MIME type is a standard way of describing a data type and is used by the browser to decide how to display data. Value range: See What Is Content-Type (MIME)? Default value: If you do not specify this parameter when uploading an object, the SDK determines the object type based on the suffix of the specified object name and automatically assigns a value to this parameter. |
LastModified |
time.Time |
Explanation: Time when the last modification was made to the object Restrictions: The time must be in the ISO8601 format, for example, 2018-01-01T00:00:00.000Z. Default value: None |
ETag |
string |
Explanation: Base64-encoded, 128-bit MD5 value of an object. ETag is the unique identifier of the object content. It can be used to determine whether the object content is changed. For example, if the ETag value is A when an object is uploaded, but changes to B when the object is downloaded, it indicates that the object content has been changed. The ETag reflects changes to the object content, rather than the object metadata. An uploaded or copied object has a unique ETag after being encrypted using MD5. Restrictions: If an object is encrypted using server-side encryption, the ETag is not the MD5 value of the object. Value range: The value must contain 32 characters. Default value: None |
VersionId |
string |
Explanation: Object version ID Value range: The value must contain 32 characters. Default value: None |
Restore |
string |
Explanation: Restore status of an object. For an Archive object that is being restored or has been restored, this header is returned. For example, ongoing-request="true" indicates that the object is being restored. ongoing-request="false", expiry-date="Wed, 7 Nov 2012 00:00:00 GMT" indicates that the object has been restored. expiry-date indicates when the restored object expires. Restrictions: This parameter is only available for Archive objects. Default value: None |
Expiration |
string |
Explanation: Expiration details of the object. Example: "expiry-date=\"Mon, 11 Sep 2023 00:00:00 GMT\"" Default value: None |
SseHeader |
Explanation: Server-side encryption header information. If SSE-C is used, see Table 7. If SSE-KMS is used, see Table 8. |
WebsiteRedirectLocation |
string |
Explanation: If the bucket is configured with website hosting, the request for obtaining the object can be redirected to another object in the bucket or an external URL. This parameter specifies the address the request for the object is redirected to. The request is redirected to object anotherPage.html in the same bucket: WebsiteRedirectLocation:/anotherPage.html The request is redirected to an external URL http://www.example.com/: WebsiteRedirectLocation:http://www.example.com/ OBS obtains the specified value from the header and stores it in the object metadata WebsiteRedirectLocation. Restrictions:
Metadata |
map[string]string |
Explanation: Custom object metadata. You can add a header starting with x-obs-meta- in the request to define metadata. The custom metadata will be returned in the response when you retrieve the object or query the object metadata. Restrictions:
Constant |
Default Value |
Description |
StorageClassStandard |
STANDARD |
OBS Standard Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response. |
StorageClassWarm |
WARM |
OBS Infrequent Access Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but is instantly available when needed. |
StorageClassCold |
COLD |
OBS Archive Used for storing rarely accessed (once a year) data. |
Parameter |
Type |
Description |
Encryption |
string |
Key |
string |
KeyMD5 |
string |
Parameter |
Type |
Description |
Encryption |
string |
Explanation: SSE-KMS used for encrypting objects Value range: kms, indicating objects are encrypted using SSE-KMS Default value: None |
Key |
string |
Explanation: ID of the KMS master key when SSE-KMS is used Value range: Valid value formats are as follows:
In the preceding formats:
Default value:
Code Examples
This example downloads example/objectname from examplebucket in a resumable download.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 |
package main import ( "fmt" "os" obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs" ) func main() { //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html. ak := os.Getenv("AccessKeyID") sk := os.Getenv("SecretAccessKey") // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // securityToken := os.Getenv("SecurityToken") // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com" // Create an obsClient instance. // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance. obsClient, err := obs.New(ak, sk, endPoint/*, obs.WithSecurityToken(securityToken)*/) if err != nil { fmt.Printf("Create obsClient error, errMsg: %s", err.Error()) } input := &obs.DownloadFileInput{} // Specify a bucket name. input.Bucket = "examplebucket" // Specify the object (example/objectname as an example) to download. input.Key = "example/objectname" // Specify a local full path (/tmp/objectname as an example) for the specified object. If the path is left blank, the current working directory will be used by default. input.DownloadFile = "/tmp/objectname" // Specify whether to enable resumable download. Value true is used as an example. The default value is false, indicating that resumable download is disabled. input.EnableCheckpoint = true // Specify a part size, in bytes. This example sets each part to 9 MB. input.PartSize = 9 * 1024 * 1024 // Specify the maximum number of parts that can be concurrently downloaded. 5 is used as an example. input.TaskNum = 5 // Download the object using resumable download. output, err := obsClient.DownloadFile(input) if err == nil { fmt.Printf("Download file(%s) under the bucket(%s) successful!\n", input.Key, input.Bucket) fmt.Printf("StorageClass:%s, ETag:%s, ContentType:%s, ContentLength:%d, LastModified:%s\n", output.StorageClass, output.ETag, output.ContentType, output.ContentLength, output.LastModified) return } fmt.Printf("Download file(%s) under the bucket(%s) fail!\n", input.Key, input.Bucket) if obsError, ok := err.(obs.ObsError); ok { fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.") fmt.Println(obsError.Error()) } else { fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.") fmt.Println(err) } } |
