Practices for Beginners
After completing basic operations such as account registration and authorization, application resource modeling, and basic O&M configurations, you can use a series of common practices provided by COC based on your service requirements.
Practice |
Description |
It is necessary to establish a standardized incident handling process. |
You can perform chaos drills on your systems and verify and improve the system availability based on the drill results. |
You can check the compliance of host OS patches to prevent service loss caused by missing OS patches. |
