- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Benefits
One-Stop O&M Platform
- Centralized management and O&M
- Synergized ITSM, ITOM, and expert services
- Seamless operations without platform switching
All-in-One Solution
- Atomic O&M capabilities
- Tailored solutions based on the accumulated experience of Huawei Cloud O&M specialists
- Simplified O&M based on best practices derived from secure production, CloudOpsBrain, and fault management
"One Cloud" User Experience
- Full-spectrum resource management, covering Huawei Cloud and customer IDC scenarios
- Multi-perspective data displays for data value mining and informed decision-making
- Cloud-based O&M capabilities extend to customer IDCs and multi-cloud scenarios for high O&M efficiency
