- What's New
- Function Overview
- Billing
- Getting Started
User Guide
VPC Endpoint Services
- VPC Endpoint Service Overview
- Creating a VPC Endpoint Service
- Viewing a VPC Endpoint Service
- Deleting a VPC Endpoint Service
- Managing Connections of a VPC Endpoint Service
- Managing Whitelist Records of a VPC Endpoint Service
- Managing Port Mappings of a VPC Endpoint Service
- Managing Tags of a VPC Endpoint Service
- VPC Endpoints
- Accessing OBS
- Using Cloud Eye to Monitor VPC Endpoints
- Using CTS to Audit VPC Endpoints
- Permissions Management
- Quotas
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Version Management
- Querying VPC Endpoint Services
- Querying Details of a VPC Endpoint Service
- Modifying a VPC Endpoint Service
- Querying Connections to a VPC Endpoint Service
- Accepting or Rejecting a VPC Endpoint
- Querying Whitelist Records of a VPC Endpoint Service
- Batch Adding or Deleting Whitelist Records of a VPC Endpoint Service
- Querying Public VPC Endpoint Services
- Querying Basic Information About a VPC Endpoint Service
- Changing the Name of a VPC Endpoint Service
- Updating Descriptions of VPC Endpoint Connections
- Batch Adding Whitelist Records of a VPC Endpoint Service
- Batch Deleting Whitelist Records of a VPC Endpoint Service
- Updating the Description of a Whitelist Record of a VPC Endpoint Service
- VPC Endpoints
- Resource Quotas
- Tags
- Application Examples
- Appendix
- SDK Reference
- FAQs
More Documents
- Getting Started
- Viewing Summary of a VPC Endpoint Service
- Viewing Port Mappings of a VPC Endpoint Service
- VPC Endpoints
- Permission Management
- FAQs
- Change History
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
APIs for Managing VPC Endpoint Services
- Querying Connections of a VPC Endpoint Service
- Querying the Whitelist Records of a VPC Endpoint Service
- APIs for Managing VPC Endpoints
- Resource Quota
- Tag Function
- Appendix
- Change History
User Guide (Paris Region)
Getting Started
- Operation Guide
- Configuring a VPC Endpoint for Communications Across VPCs of the Same Domain
- Configuring a VPC Endpoint for Communications Across VPCs of Different Domains
- Configuring a VPC Endpoint for Accessing the Private IP Address of OBS over Private Networks
- Configuring a VPC Endpoint for Accessing the Public IP Address of OBS over Public Networks
- Viewing the Summary of a VPC Endpoint Service
- VPC Endpoints
- Quotas
- FAQ
- Change History
API Reference (Paris Region)
- Before You Start
- API Overview
- Calling APIs
APIs
- Querying Details About a VPC Endpoint Service
- Resource Quota
- Tag Function
- Appendix
- Change History
- Getting Started
- VPC Endpoints
- Quotas
- FAQ
- Change History
- Before You Start
- API Overview
- Calling APIs
APIs
- Resource Quota
- Tag Function
- Appendix
- Change History
- User Guide (Ankara Region)
API Reference (Ankara Region)
- Before You Start
- API Overview
- Calling APIs
APIs
- Resource Quota
- Appendix
- Change History
Show all
VPC Endpoint Overview
VPC endpoints are secure and private channels for connecting VPCs to VPC endpoint services.
You can create a VPC endpoint to connect a resource in your VPC to a VPC endpoint service in another VPC of the same region.
This section describes how to create and manage a VPC endpoint.
Operation |
Description |
Constraint |
Describes how to create a VPC endpoint. |
Describes how to query the summary of a VPC endpoint. |
A VPC endpoint supports a maximum of 3,000 concurrent requests. |
Describes how to delete a VPC endpoint. |
Deleted VPC endpoints cannot be recovered. Exercise caution when performing this operation. |
Describes how to query, add, edit, and delete VPC endpoint tags. |
You can add up to 10 tags to each VPC endpoint. |
