Overview
If an application is developed using the microservice framework, the microservice is automatically registered with the corresponding microservice engine after the application is managed and started. You can perform service governance on the microservice engine console by referring to Governing Microservices.
This function is supported by only microservice engine 1.x, and 2.4.0 and later versions.
