Buying a CCE Standard Cluster
On the CCE console, you can easily create Kubernetes clusters. After a cluster is created, the master node is hosted by CCE. You only need to create worker nodes. In this way, you can implement cost-effective O&M and efficient service deployment.
Precautions
- After a cluster is created, the following items cannot be changed:
- Cluster type
- Number of master nodes in the cluster
- AZ of a master node
- Network configurations of the cluster, such as the VPC, subnet, Service CIDR block, IPv6 settings, and kube-proxy settings
- Network model. For example, change Tunnel network to VPC network.
Step 1: Log In to the CCE Console
- Log in to the CCE console.
- On the Clusters page, click Buy Cluster.
Step 2: Configure the Cluster
On the Buy Cluster page, configure the parameters.
Basic Settings
Parameter |
Description |
Billing Mode |
Select a billing mode for the cluster as required.
Cluster Name |
Enter a cluster name. Cluster names under the same account must be unique. |
Enterprise Project |
This parameter is available only for enterprise users who have enabled an enterprise project. After an enterprise project is selected, clusters and their security groups will be created in that project. To manage clusters and other resources like nodes, load balancers, and node security groups, you can use the Enterprise Project Management Service (EPS). |
Cluster Version |
Select the Kubernetes version used by the cluster. |
Cluster Scale |
Select a cluster scale for your cluster as required. These values specify the maximum number of nodes that can be managed by the cluster. |
Master Nodes |
Select the number of master nodes. The master nodes are automatically hosted by CCE and deployed with Kubernetes cluster management components such as kube-apiserver, kube-controller-manager, and kube-scheduler.
You can also select AZs for deploying the master nodes of a specific cluster. By default, AZs are allocated automatically for the master nodes.
Network Settings
The network settings cover nodes, containers, and Services. For details about the cluster networking and container network models, see Overview.
Parameter |
Description |
VPC |
Select the VPC to which the cluster belongs. If no VPC is available, click Create VPC to create one. The value cannot be changed after the cluster is created. |
Node Subnet |
Select the subnet to which the master nodes belong. If no subnet is available, click Create Subnet to create one. The value cannot be changed after the cluster is created. |
Default Node Security Group |
Select the security group automatically generated by CCE or use the existing one as the default security group of the node.
NOTICE:
The default security group must allow traffic from certain ports to ensure normal communication. Otherwise, the node cannot be created. |
IPv6 |
If enabled, cluster resources, including nodes and workloads, can be accessed through IPv6 CIDR blocks.
Parameter |
Description |
Network Model |
Select VPC network or Tunnel network for your CCE standard cluster. For more information about their differences, see Overview. |
Network Policies (supported by CCE standard clusters using a tunnel network) |
Policy-based network control for clusters. For details, see Configuring Network Policies to Restrict Pod Access. After this function is enabled, if the CIDR blocks of a customer's service conflict with the on-premises CIDR blocks, the link to a newly added gateway may not be established. For example, when a cluster accesses an external address through a Direct Connect connection, the external switch does not support ip-option. If the network policy is enabled, the network access may fail. |
Container CIDR Block |
Specify the CIDR block for containers, which determines the maximum number of containers allowed in the cluster. This parameter is available only for CCE standard clusters. CCE standard clusters allow both manual and automatic CIDR block settings.
Pod IP Addresses Reserved for Each Node (supported by CCE standard clusters using a VPC network) |
Specify the number of container IP addresses that can be allocated to each node (alpha.cce/fixPoolMask) when creating a cluster. This parameter determines the maximum number of pods that can be created on each node and cannot be changed after the cluster is created. When a container network is used, each pod occupies one IP address. If a node's reserved container IP addresses are insufficient, pods cannot be created. For details, see Number of Allocatable Container IP Addresses on a Node. |
Parameter |
Description |
Service CIDR Block |
Configure the Service CIDR blocks for containers in the same cluster to access each other. The value determines the maximum number of Services you can create. The value cannot be changed after the cluster is created. |
Request Forwarding |
Select IPVS or iptables for your cluster. For details, see Comparing iptables and IPVS.
(Optional) Advanced Settings
Parameter |
Description |
IAM Authentication |
CCE clusters support IAM authentication. You can call IAM authenticated APIs to access CCE clusters. |
Certificate Authentication |
CPU Management |
If enabled, exclusive CPU cores can be allocated to workload pods. For details, see CPU Policy. |
Overload Control |
After this function is enabled, concurrent requests will be dynamically controlled based on the resource demands received by master nodes to ensure the stable running of the master nodes and the cluster. For details, see Enabling Overload Control for a Cluster. |
Cluster Deletion Protection |
A measure taken to prevent accidental deletion of clusters through the console or APIs. After this function is enabled, you will not be able to delete or unsubscribe from clusters on CCE. You can modify the function status in the cluster Settings after creating it. |
Time Zone |
The cluster's scheduled tasks and nodes are subject to the chosen time zone. |
Resource Tag |
You can add resource tags to classify resources. A maximum of 20 resource tags can be added.
You can create predefined tags on the TMS console. These tags are available to all resources that support tags. You can use these tags to improve the tag creation and resource migration efficiency.
Description |
You can enter description for the cluster. A maximum of 200 characters are allowed. |
Step 3: Select Add-ons
Click Next: Select Add-on. On the page displayed, select the add-ons to be installed during cluster creation.
Basic capabilities
Add-on Name |
Description |
CCE Container Network (Yangtse CNI) |
This is the basic cluster add-on. It provides network connectivity, Internet access, and security isolation for pods in your cluster. |
CCE Container Storage (Everest) |
This add-on (CCE Container Storage (Everest)) is installed by default. It is a cloud native container storage system based on CSI and supports cloud storage services such as EVS. |
CoreDNS |
This add-on (CoreDNS) is installed by default. It provides DNS resolution for your cluster and can be used to access the in-cloud DNS server. |
NodeLocal DNSCache |
(Optional) If selected, this add-on (NodeLocal DNSCache) will be automatically installed. NodeLocal DNSCache improves cluster DNS performance by running a DNS caching agent on cluster nodes. |
Add-on Name |
Description |
Cloud Native Cluster Monitoring |
(Optional) If selected, this add-on (Cloud Native Cluster Monitoring) will be automatically installed. Cloud Native Cluster Monitoring collects monitoring metrics for your cluster and reports the metrics to AOM. The agent mode does not support HPA based on custom Prometheus statements. If related functions are required, install this add-on manually after the cluster is created. |
CCE Node Problem Detector |
(Optional) If selected, this add-on (CCE Node Problem Detector) will be automatically installed to detect faults and isolate nodes for prompt cluster troubleshooting. |
Step 4: Configure Add-ons
Click Next: Add-on Configuration.
Basic capabilities
Add-on Name |
Description |
This add-on is unconfigurable. |
This add-on is unconfigurable. After the cluster is created, choose Add-ons in the navigation pane of the cluster console and modify the configuration. |
CoreDNS |
Observability
Add-on Name |
Description |
Select an AOM instance for Cloud Native Cluster Monitoring to report metrics. If no AOM instance is available, click Creating Instance to create one. |
Step 5: Confirm the Configuration
After the parameters are specified, click Next: Confirm configuration. The cluster resource list is displayed. Confirm the information and click Submit.
It takes about 5 to 10 minutes to create a cluster. You can click Back to Cluster List to perform other operations on the cluster or click Go to Cluster Events to view the cluster details.
Related Operations
- After creating a cluster, you can use the Kubernetes command line (CLI) tool kubectl to connect to the cluster. For details, see Accessing a Cluster Using kubectl.
- Add nodes to the cluster. For details, see Creating a Node.
