Assigning an EIP
You need to assign an EIP first before you can use it.
Parameter Settings
Configure parameters as prompted.
Category |
Parameter |
Description |
Example Value |
Basic Configuration |
Billing Mode |
The following options are available:
Pay-per-use |
Region |
Regions are geographic areas isolated from each other. For low network latency and quick resource access, select the region nearest to where your services will be accessed. The region selected for the EIP is its geographical location.
CN-Hong Kong |
Bandwidth Configuration |
EIP Type |
For details, see What Are the Differences Between Static BGP and Dynamic BGP? |
Dynamic BGP |
EIP Pool |
Select your purchased EIP pool. This parameter is available only when Billing Mode is set to Pay-per-use and EIP Type set to EIP Pool. |
eipPool-test |
Billed By |
This parameter is available only when you set Billing Mode to Pay-per-use.
Bandwidth |
Bandwidth (Mbit/s) |
Bandwidth size in Mbit/s. |
100 |
Bandwidth Name |
The name of the bandwidth. The name:
bandwidth |
DDoS Protection |
DDoS Protection |
Cloud Native Anti-DDoS Basic Cloud Native Anti-DDoS Basic provides up to a certain amount (for example, less than 5 Gbit/s) of DDoS mitigation capacity for free. The actual thresholds are displayed on the console. If the attack to an EIP exceeds the threshold, the EIP will be blocked. |
EIP Details |
EIP Name (Optional) |
The name of the EIP. The name:
eip-test |
EIP Details |
Enterprise Project |
Enterprise project that the EIP belongs to. An enterprise project makes it easy to manage projects and group cloud resources and users. The name of the default project is default. For details about creating and managing enterprise projects, see the Enterprise Management User Guide. |
default |
EIP Details |
Tag |
Tags help you quickly identify, organize, and search for your EIPs.
If your organization has configured tag policies for EIPs, you need to add tags to EIPs based on the policies. If a tag does not comply with the tag policies, EIP assignment may fail. Contact the administrator to learn more about tag policies. |
Monitoring |
Monitoring |
Basic monitoring is enabled by default. You can use the management console or APIs provided by Cloud Eye to query the metrics and alarms generated for the EIP and bandwidth. |
Purchase Details |
Required Duration |
The duration for which the EIP will be used. The duration must be specified if the Billing Mode is set to Yearly/Monthly. |
1 month |
Purchase Details |
Auto-renew |
Whether to select Auto-renew. You can select it if the Billing Mode is set to Yearly/Monthly. The auto-renewal period is determined by the required duration.
Purchase Details |
Quantity |
The number of EIPs you want to assign. You can set Quantity only when Billing Mode is set to Pay-per-use. |
1 |
FAQ
