Updated on 2024-11-20 GMT+08:00
Why Can't I Select a Node?
Check whether the node is in the normal state: the resource status is Running and the UniAgent status is Running.
For details about how to install the UniAgent, see Performing Operations on a UniAgent.
Parent topic: Patch Management FAQs
