Help Center/ Cloud Operations Center/ FAQs/ Resource Management FAQs/ How Do I Install UniAgent for the First Time?
Updated on 2025-09-11 GMT+08:00
  1. Log in to COC.
  2. In the navigation pane, choose Application and Resource Management. On the Resources page, select a host where no UniAgents have not been installed.
    Figure 1 Installing a UniAgent
  3. On the UniAgent installation page that is displayed, click Manual installation.
    Figure 2 UniAgent installation page
  4. Run the installation command on the page to manually install the UniAgent.
    Figure 3 Manually installing a UniAgent
  5. Click Return to Automatic Installation.
  6. Click Add Installation Host to set the host where the UniAgent is installed as the installation host.
    Figure 4 Configuring an installation host
  7. In the displayed dialog box, enter the information about the installation host and click OK.
    Figure 5 Selecting an installation host
