Help Center/ Cloud Container Engine/ FAQs/ Workload/ Workload Exception Troubleshooting/ What Should I Do If the Scheduling of a Pod Fails?
Updated on 2026-06-26 GMT+08:00
Fault Locating
If a pod is in the Pending state and the events contain the information that indicates a pod scheduling failure, you can locate the cause based on the events. For details about how to view events, see How Can I Locate the Root Cause If a Workload Is Abnormal?
Troubleshooting
Determine the cause based on the events, as listed in Table 1.
Table 1 Events related to a pod scheduling failure
Event
Cause and Solution
no nodes available to schedule pods.
There are not any available nodes in the cluster.
Check Item 1: Whether a Node Is Available in the Cluster
0/2 nodes are available: 2 Insufficient cpu.
0/2 nodes are available: 2 Insufficient memory.
The resources (CPUs and memory) on the node are insufficient.
Check Item 2: Whether Node Resources (CPUs and Memory) Are Sufficient
0/2 nodes are available: 1 node(s) didn't match node selector, 1 node(s) didn't match pod affinity rules, 1 node(s) didn't match pod affinity/anti-affinity.
The node and pod affinity configurations are mutually exclusive. No node meets the pod requirements.
Check Item 3: Affinity and Anti-Affinity Configuration of the Workload
0/2 nodes are available: 2 node(s) had volume node affinity conflict.
The EVS volume mounted to the pod and the node are not in the same AZ.
Check Item 4: Whether the Workload's Volume and the Node Are in the Same AZ
0/1 nodes are available: 1 node(s) had taints that the pod didn't tolerate.
There are some taints on the node, and the pod cannot tolerate these taints.
Check Item 5: Tolerations of the Pod
0/7 nodes are available: 7 Insufficient ephemeral-storage.
The ephemeral storage space on the node is insufficient.
Check Item 6: Ephemeral Volume Usage
0/1 nodes are available: 1 everest driver not found at node
The everest-csi-driver on the node is not in the running state.
Check Item 7: Whether the CCE Container Storage (Everest) Add-on Works Properly
Failed to create pod sandbox: ...
Create more free space in thin pool or use dm.min_free_space option to change behavior
The node thin pool space is insufficient.
Check Item 8: Whether the Thin Pool Space Is Sufficient
0/1 nodes are available: 1 Too many pods.
The number of pods scheduled to the node exceeds the maximum allowed.
Check Item 9: Whether the Node Has Too Many Pods Scheduled onto It
UnexpectedAdmissionError Allocate failed due to not enough cpus available to satisfy request, which is unexpected.
The kubelet static CPU pinning is abnormal due to a known community issue.
Check Item 10: Whether the Static CPU Pinning of kubelet Is Abnormal
You can log in to the CCE console and check whether the node status is Available. You can also use the following command to check whether the node status is Ready:
$ kubectl get node
NAME           STATUS   ROLES    AGE   VERSION
192.168.0.37   Ready    <none>   21d   v1.19.10-r1.0.0-source-121-gb9675686c54267
192.168.0.71   Ready    <none>   21d   v1.19.10-r1.0.0-source-121-gb9675686c54267
If the status of all nodes is Not Ready, it means that there are no available nodes in the cluster.
Solution
0/2 nodes are available: 2 Insufficient cpu. indicates that the CPUs are insufficient.
0/2 nodes are available: 2 Insufficient memory. indicates that the memory is insufficient.
If the resources requested by the pod exceed the allocatable resources on the node where the pod will run, the pod scheduling onto the node will definitely fail due to insufficient node resources.
If there are fewer allocatable resources on the node than the resources that a pod requests, the pod scheduling will fail.
Solution
Add more nodes to the cluster. Scale-out is the common solution to insufficient resources.
Inappropriate affinity policies will cause the pod scheduling to fail.
For example, an anti-affinity policy is configured for workload 1 and workload 2. They run on node 1 and node 2, respectively.
If you try to configure an affinity policy for workload 3 and workload 2 and then deploy workload 3 on a node different from one hosting workload 2, such as node 1, it will cause a conflict and lead to the workload deployment failure.
  • node selector indicates that the node affinity is not met.
  • pod affinity rules indicate that the pod affinity is not met.
  • pod affinity/anti-affinity indicates that the pod affinity and anti-affinity are not met.
Solution
  • When configuring workload-workload affinity and workload-node affinity policies, ensure that these policies do not conflict with each other, or the workload deployment will fail.
  • For a workload that has a node affinity policy configured, you need to make sure that supportContainer in the label of the affinity node is set to true. Otherwise, pods cannot be scheduled onto the node and the following event is generated:
    No nodes are available that match all of the following predicates: MatchNode Selector, NodeNotSupportsContainer
    If the value is false, the pod scheduling will fail.
0/2 nodes are available: 2 node(s) had volume node affinity conflict. indicates that an affinity conflict occurs between the volume mounted to the pod and the host node. As a result, the pod scheduling fails.
This is because EVS disks cannot be attached to nodes in different AZs from the EVS disks. For example, a workload pod with an EVS volume that is in AZ 1 cannot be scheduled to a node in AZ 2.
The EVS volumes created on CCE have affinity settings by default, as shown below.
kind: PersistentVolume
apiVersion: v1
  nodeAffinity:
    required:
      nodeSelectorTerms:
        - matchExpressions:
            - key: failure-domain.beta.kubernetes.io/zone
              operator: In
              values:
                - ap-southeast-1a
Solution
In the AZ where the workload's node resides, create a volume. Alternatively, create an identical workload and select an automatically assigned cloud storage volume.
0/1 nodes are available: 1 node(s) had taints that the pod didn't tolerate. indicates that there are some taints on the node, and the pod cannot tolerate these taints.
In this case, you can check the taints on the node. If information similar to the following is displayed, there are some taints on the node:
$ kubectl describe node 192.168.0.37
Taints:             key1=value1:NoSchedule
In some cases, the system automatically adds a taint to a node. The built-in taints include:
  • node.kubernetes.io/not-ready: The node is not ready.
  • node.kubernetes.io/unreachable: The node controller cannot access the node.
  • node.kubernetes.io/memory-pressure: The node is under memory pressure.
  • node.kubernetes.io/disk-pressure: The node is under disk pressure. In this case, follow the instructions described in Check Item 4: Whether the Node Disk Space Is Insufficient to handle it.
  • node.kubernetes.io/pid-pressure: The node is under PID pressure. Follow the instructions in Changing Process ID Limits (kernel.pid_max) to handle it.
  • node.kubernetes.io/network-unavailable: The node network is unavailable.
  • node.kubernetes.io/unschedulable: The node is unschedulable.
  • node.cloudprovider.kubernetes.io/uninitialized: When kubelet is started with an external cloud platform driver specified, it adds a taint to the node, marking it as unavailable. After cloud-controller-manager initializes the node, kubelet deletes the taint.
Solution
To schedule the pod to the node, use either of the following methods:
  • If the taint is added by a user, you can delete the taint on the node. If the taint is automatically added by the system, the taint will be automatically deleted after the fault is rectified.
  • Specify a toleration for the pod containing the taint. For details, see Taints and Tolerations.
    apiVersion: v1
    kind: Pod
      containers:
      - name: nginx
        image: nginx:alpine
      tolerations:
      - key: "key1"
        operator: "Equal"
        value: "value1"
        effect: "NoSchedule"
0/7 nodes are available: 7 Insufficient ephemeral-storage. indicates that there are not enough ephemeral storage space on the node.
In this case, you can check whether the space of the ephemeral volume is limited by the pod. If the ephemeral volume space required by the application exceeds the existing capacity on the node, the application cannot be scheduled to that node. To solve this problem, change the space of the ephemeral volume or expand the disk capacity on the node.
apiVersion: v1
kind: Pod
  containers:
  - name: app
    image: images.my-company.example/app:v4
    resources:
      requests:
        ephemeral-storage: "2Gi"
      limits:
        ephemeral-storage: "4Gi"
    volumeMounts:
    - name: ephemeral
      mountPath: "/tmp"
  volumes:
    - name: ephemeral
      emptyDir: {}
To obtain the total capacity (Capacity) and available capacity (Allocatable) of the temporary volumes on the node, run the kubectl describe node command and check the memory request and limit of the allocated temporary volume on the node.
The following is an example of the output:
Capacity:
  cpu:                4
  ephemeral-storage:  61607776Ki
  hugepages-1Gi:      0
  hugepages-2Mi:      0
  localssd:           0
  localvolume:        0
  memory:             7614352Ki
  pods:               40
Allocatable:
  cpu:                3920m
  ephemeral-storage:  56777726268
  hugepages-1Gi:      0
  hugepages-2Mi:      0
  localssd:           0
  localvolume:        0
  memory:             6180752Ki
  pods:               40
Allocated resources:
  (Total limits may be over 100 percent, i.e., overcommitted.)
  Resource           Requests      Limits
  cpu                1605m (40%)   6530m (166%)
  memory             2625Mi (43%)  5612Mi (92%)
  ephemeral-storage  0 (0%)        0 (0%)
  hugepages-1Gi      0 (0%)        0 (0%)
  hugepages-2Mi      0 (0%)        0 (0%)
  localssd           0             0
  localvolume        0             0
Events:              <none>
0/1 nodes are available: 1 everest driver not found at node. indicates that everest-csi-driver of CCE Container Storage (Everest) is not started properly on the node.
In this case, you can check the daemon named everest-csi-driver in the kube-system namespace and check whether the pod is started properly. If it is not, delete the pod. The daemon will restart another pod.
A data disk dedicated for kubelet and the container runtime will be attached to a new node. For details, see Space Allocation of a Data Disk. If the data disk space is insufficient, the pod cannot be created on the node.
Solution 1: Clearing images
Perform the following operations to clear unused images:
  • containerd nodes
    1. Obtain local images on the node.
      crictl images -v
    2. Delete the unnecessary images by image ID.
      crictl rmi {Image ID}
  • Docker nodes
      docker images
      docker rmi {image-ID}
Do not delete system images, such as the cce-pause image. Otherwise, the pod creation may fail.
Solution 2: Expanding the disk capacity
To expand a disk's capacity, perform the following operations:
  1. Expand the capacity of a data disk on the EVS console. For details, see Expanding EVS Disk Capacity.
    Only the storage capacity of EVS disks can be expanded. You need to perform the following operations to expand the capacity of logical volumes and file systems.
  2. Log in to the CCE console and click the cluster name to access the cluster console. In the navigation pane, choose Nodes. In the right pane, click the Nodes tab, locate the row containing the node, and choose More > Sync Server Data in the Operation column.
  3. Log in to the node.
  4. Run lsblk to view the block device information of the node.
    A data disk is divided depending on the container storage Rootfs:
0/1 nodes are available: 1 Too many pods. indicates excessive number of pods have been scheduled to the node.
When creating a node, configure Max. Pods in the Advanced Settings area to specify the maximum number of pods that can run properly on the node. The default value varies with the node flavor. You can change the value as needed.
Figure 1 Maximum number of pods
On the Nodes page, obtain the Pods (Allocated/Total Available Addresses/Total) value of the node, and check whether the number of pods scheduled onto the node has reached the upper limit. If so, add nodes or change the maximum number of pods.
To change the maximum number of pods that can run on a node, do as follows:
  • For nodes in the default node pool: Change the Max. Pods value when resetting the node.
  • For nodes in a custom node pool: Change the value of the node pool parameter max-pods. For details, see Configuring a Node Pool.
Figure 2 Checking the number of pods
If a pod has an init container with a CPU request that is different from the main container settings, and it is assigned a Guaranteed QoS class while the kubelet uses static CPU pinning (with cpuManagerPolicy set to static), the pod scheduling could fail, resulting in the error UnexpectedAdmissionError.
Community-related issue: https://github.com/kubernetes/kubernetes/issues/112228
Solution
Set the CPU request of the init container to a decimal value that matches the CPU limit and avoid using CPU pinning.
For example: the main container: {"limits":{"cpu":"7","memory":"60G"},"requests":{"cpu":"7","memory":"60G"}}; the init container: {"limits":{"cpu":"6.9","memory":"60G"},"requests":{"cpu":"6.9","memory":"60G"}}
