Enabling Auto Scaling for a GPU Node
If there are not enough GPU resources in a cluster, GPU nodes can be scaled out automatically. This section describes how to create an auto scaling policy for a GPU node.
- You have installed the CCE AI Suite (NVIDIA GPU) and CCE Cluster Autoscaler in the cluster.
- The Auto Node Scale-Out function is enabled. To do so, go to Settings, click the Auto Scaling tab and enable Auto Node Scale-Out under Node Scale-Out Criteria.
Step 1: Configure a Node Pool
- Log in to the CCE console and click the cluster name to access the cluster console. In the navigation pane, choose Nodes.
- In the right pane, click the Node Pools tab and click Create Node Pool in the upper right corner. For details, see Creating a Node Pool.
- After the node pool is created, click Auto Scaling. In the AS Object area, enable Auto Scaling for the target specification and click OK.
Step 2: Create a GPU Workload and Enable Auto Scale-Out
- Use the following YAML to create a GPU workload:
apiVersion: apps/v1 kind: Deployment metadata: name: ac-test namespace: default spec: replicas: 1 # Number of replicas selector: matchLabels: app: ac-test template: metadata: labels: app: ac-test spec: restartPolicy: Always containers: - name: container-1 image: pytorch/pytorch:2.1.1-cuda12.1-cudnn8-devel imagePullPolicy: IfNotPresent command: ["/bin/bash", "-c"] args: - "while true; do nvidia-smi; sleep 10; done" resources: requests: cpu: 250m memory: 512Mi nvidia.com/gpu: 1 limits: cpu: 250m memory: 512Mi nvidia.com/gpu: 1 # Node affinity: Schedule the pod to the target GPU node pool (the one created previously). affinity: nodeAffinity: requiredDuringSchedulingIgnoredDuringExecution: nodeSelectorTerms: - matchExpressions: - key: cce.cloud.com/cce-nodepool operator: In values: - gpu-130-nodepool-67633 # GPU node pool name - Check the pods and nodes in the node pool. The node pool does not contain any node, and the pod is in the Pending state.
- Verify that a node pool scale-out has been triggered.
- Check the pods and nodes in the node pool. A new node is created in the node pool, and the pod is in the Running state.
Step 3: Delete the GPU Workload and Enable Auto Scale-In
If the number of GPU resources required by the GPU workload decrease and the node is idle, you can enable auto node scale-in to save resources.
- Go to Settings, click the Auto Scaling tab, enable Auto Node Scale-In under Auto Scale-In Settings, and configure the scale-in conditions as required. For details, see Auto Scaling.
- Verify that the idle node starts to be scaled in after the GPU workload has been deleted.
- Check whether the node has been removed.
