Configuring LoadBalancer Ingress Load Balancing for a Persistent-Connection Service
When a containerized persistent-connection service exposes traffic to external systems through a LoadBalancer ingress, pressure-testing may reveal uneven load distribution. This can cause certain backend servers to become overloaded, ultimately affecting overall service performance. To ensure balanced traffic distribution and efficient services, you can fine-tune client connection idle timeout, client request timeout, backend response timeout, and other configurations.
- Client connection idle timeout: defines how long a connection can remain open when no data is being transmitted. For persistent connections, configuring an appropriate idle timeout prevents connections from occupying resources unnecessarily while still keeping them available when needed. If the timeout is too short, connections may disconnect and reconnect frequently, increasing server load. If the timeout is too long, idle connections may consume resources that could be used more efficiently elsewhere.
- Client request timeout: defines how long a server waits for a client to send a complete request after the connection is established. For persistent connections, this prevents the server from waiting indefinitely for client data and preventing resources from being occupied for a long time. A reasonable client request timeout improves server responsiveness and resource utilization.
- Backend response timeout: defines how long a server waits for a backend server to return a response after forwarding a request. For persistent connections, a reasonable backend response timeout prevents congestion caused by slow backend responses. This improves system performance and stability.
- A CCE Turbo cluster is available. The cluster has the Cloud Native Cluster Monitoring add-on installed.
- A dedicated load balancer is available.
- An ECS that can access the Internet is available. The ECS also has Docker and wrk installed.
Step 1: Prepare a Test Image
- Log in to the ECS and create a dockerfile folder.
mkdir ./dockerfile cd ./dockerfile
- Prepare the required Dockerfile, go.mod, and app.go files.
- After the creation, check whether the dockerfile directory contains the following files:
app.go Dockerfile go.mod
- Log in to the SWR image repository and push the image to the SWR repository. For details, see Pushing an Image.
docker tag http-long-conn:v1 {image-repository-address}/{organization}/http-long-conn:v1 docker push {image-repository-address}/{organization}/http-long-conn:v1{image-repository-address} specifies an SWR image repository address. {organization} specifies an SWR organization name.
Step 2: Deploy a Workload in the Cluster
- Access the cluster using kubectl.
- Create a file named http-long-conn.yaml. You can name the file as required.
vi http-long-conn.yaml
The file content is as follows:
kind: Deployment apiVersion: apps/v1 metadata: name: http-long-conn namespace: default labels: app: http-long-conn spec: replicas: 4 selector: matchLabels: app: http-long-conn template: metadata: labels: app: http-long-conn spec: containers: - name: http-long-conn image: {image-repository-address}/{organization}/http-long-conn:v1 # Replace it with the SWR image address you uploaded. ports: - containerPort: 8080 protocol: TCP env: - name: PORT value: '8080' resources: limits: cpu: 100m memory: 128Mi requests: cpu: 100m memory: 128Mi livenessProbe: httpGet: path: /health port: 8080 scheme: HTTP initialDelaySeconds: 30 timeoutSeconds: 1 periodSeconds: 10 successThreshold: 1 failureThreshold: 3 readinessProbe: httpGet: path: /health port: 8080 scheme: HTTP initialDelaySeconds: 5 timeoutSeconds: 1 periodSeconds: 5 successThreshold: 1 failureThreshold: 3 terminationMessagePath: /dev/termination-log terminationMessagePolicy: File imagePullPolicy: IfNotPresent restartPolicy: Always terminationGracePeriodSeconds: 30 dnsPolicy: ClusterFirst securityContext: {} schedulerName: default-scheduler imagePullSecrets: - name: default-secret tolerations: null strategy: type: RollingUpdate rollingUpdate: maxUnavailable: 25% maxSurge: 25% revisionHistoryLimit: 10 progressDeadlineSeconds: 600 --- apiVersion: v1 kind: Service metadata: name: http-long-conn labels: app: http-long-conn namespace: default spec: selector: app: http-long-conn ports: - name: http-0 targetPort: 8080 nodePort: 0 port: 8080 protocol: TCP type: ClusterIP - Create the workload and the Service.
kubectl create -f http-long-conn.yaml
- Check the workload status.
kubectl get pod -l app=http-long-conn
Step 4: Create a LoadBalancer Ingress
- Create a file named elb-ingress.yaml. You can name the file as required.
vi elb-ingress.yaml
apiVersion: networking.k8s.io/v1 kind: Ingress metadata: name: http-long-conn namespace: default annotations: kubernetes.io/elb.port: '8080' kubernetes.io/elb.id: 1fce4b38-c72b-4fd4-8430-62d46c0a7998 #ELB ID kubernetes.io/elb.class: performance kubernetes.io/elb.keepalive_timeout: '300' # Timeout setting for client connections kubernetes.io/elb.client_timeout: '60' # Timeout for waiting for a request from a client kubernetes.io/elb.member_timeout: '60' # Timeout for waiting for a response from a backend server spec: rules: - host: example.com # Use a custom domain name. http: paths: - path: / backend: service: name: http-long-conn port: number: 8080 property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITH pathType: ImplementationSpecific ingressClassName: cce - Create the ingress.
kubectl create -f elb-ingress.yaml
- Test the domain name connectivity.
Step 5: Perform a Pressure Test
Use wrk to perform a pressure test.
wrk -t2 -c100 -d300s -H "Connection: keep-alive" http://example.com/long-connection
Where:
- -t2: specifies that two threads are enabled.
- -c100: specifies that 100 concurrent connections are established.
- -d300s: specifies how long the test will last.
In this example, pressure tests are performed using 100 and 200 concurrent connections, respectively. By viewing the pod monitoring metrics in the Monitoring Center, you can see that the pods are operating in a balanced load-distribution state.
