Help Center/ Cloud Container Engine/ Best Practices/ Terraform/ Creating a CCE Cluster Using Terraform
Updated on 2026-09-08 GMT+08:00
In scenarios where containerized services are rapidly iterated, O&M engineers need to frequently create CCE clusters to deploy and manage containerized applications. To manually create a cluster on the console, engineers need to configure multiple parameters, such as the VPC, subnet, and cluster parameters. The process is complex and error-prone, especially when clusters need to be repeatedly created in multiple environments (development, testing, and production environments).
Terraform allows you to define the cluster creation process as code, enabling one-click, automated creation of CCE clusters and their dependent network resources. It supports version management and repeatable execution, making it suitable for the following scenarios:
  • Automated creation and destruction of test clusters in CI/CD pipelines
  • Batch creation of CCE clusters with consistent configurations in multiple environments
  • Standardized cluster creation process to reduce manual operation differences
Step 1: Create a Project Directory and Initialize the Configuration
  1. Create a CCE cluster management directory (the directory name is user-defined).
    mkdir terraform_cce_cluster
    cd ./terraform_cce_cluster
  2. Copy the prepared provider configuration file to the current directory. The init.tf file has been created in the terraform_hw_demo directory in section "Installing Terraform and Configuring the Huawei Cloud Provider".
    cp ../terraform_hw_demo/init.tf .
Step 2: Create Configuration Files
All the following configuration files are created in the project directory.
  1. Query the AZs.
    Create the az.tf file to query information about all AZs in a region. The information will be used to create resources for the CCE Turbo cluster.
    # Obtain information about all AZs in a specified region (if the region parameter is not specified, the region specified in the provider block is used by default). The information will be used to create resources for the CCE Turbo cluster.
    data "huaweicloud_availability_zones" "test" {}
  2. (Optional) If you need to specify an endpoint, create the endpoints.tf file.
    provider "huaweicloud" {
      insecure  = true  # Skip SSL certificate verification.
      endpoints = {
        ecs = "https://ecs.{region}.myhuaweicloud.com"
        cce = "https://cce.{region}.myhuaweicloud.com"
        vpc = "https://vpc.{region}.myhuaweicloud.com"
    Replace {region} with the actual region (for example, cn-north-7c).
  3. (Optional) Create a VPC.
    If there is already a VPC, skip this step and use the vpc_id variable to specify the existing VPC in subsequent steps. Create the vpc.tf file as follows:
    variable "vpc_id" {
      description = "VPC ID"
      type        = string
      default     = ""
    variable "vpc_name" {
      description = "VPC name"
      type        = string
      default     = ""
      validation {
        condition     = var.vpc_id != "" || var.vpc_name != ""
        error_message = "If vpc_id is not specified, vpc_name must be specified."
    variable "vpc_cidr" {
      description = "VPC CIDR block"
      type        = string
      default     = "192.168.0.0/16"
    # Create a VPC in the specified region (if the region parameter is not specified, the region specified in the provider block is used by default). This VPC is used to provide a network environment for the Turbo cluster.
    resource "huaweicloud_vpc" "test" {
      count = var.vpc_id == "" && var.subnet_id == "" ? 1 : 0
      name = var.vpc_name
      cidr = var.vpc_cidr
    The involved parameters are described in the table below.
    count
    Number of resources to be created. If vpc_id is specified, the existing VPC will be used, and no new VPC will be created.
    name
    VPC name
    cidr
    VPC CIDR block. The default CIDR block is 192.168.0.0/16.
  4. Create a VPC subnet.
    If you have created a VPC in step 2, perform this step. If a subnet already exists, skip this step and use the subnet_id variable to specify the existing subnet. Create the vpc_subnet.tf file as follows:
    variable "subnet_id" {
      description = "Subnet ID"
      type        = string
      default     = ""
    variable "subnet_name" {
      description = "Subnet name"
      type        = string
      default     = ""
      validation {
        condition     = var.subnet_id == "" || var.subnet_name == ""
        error_message = "If subnet_id is not specified, subnet_name must be specified."
    variable "subnet_cidr" {
      description = "Subnet CIDR block"
      type        = string
      default     = ""
    variable "subnet_gateway_ip" {
      description = "Gateway IP address of the subnet"
      type        = string
      default     = ""
    variable "availability_zone" {
      description = "AZ where the CCE cluster is to be created"
      type        = string
      default     = ""
    # Create a VPC subnet in the specified region (if the region parameter is not specified, the region specified in the provider block is used by default). This subnet is used to provide a network environment for the Turbo cluster.
    resource "huaweicloud_vpc_subnet" "test" {
      count = var.subnet_id == "" ? 1 : 0
      vpc_id            = var.vpc_id != "" ? var.vpc_id : huaweicloud_vpc.test[0].id
      name              = var.subnet_name
      cidr              = var.subnet_cidr != "" ? var.subnet_cidr : cidrsubnet(huaweicloud_vpc.test[0].cidr, 4, 0)
      gateway_ip        = var.subnet_cidr != "" ? cidrhost(var.subnet_cidr, 1) : cidrhost(cidrsubnet(huaweicloud_vpc.test[0].cidr, 4, 0), 1)
      availability_zone = var.availability_zone != "" ? var.availability_zone : try(data.huaweicloud_availability_zones.test.names[0], null)
    count
    Number of resources to be created. If subnet_id is specified, the existing subnet will be used, and no new subnet will be created.
    vpc_id
    ID of the VPC where the subnet needs to be created
    name
    Subnet name
    cidr
    Subnet CIDR block. If this parameter is not specified, a subnet is automatically created from the VPC CIDR block.
    gateway_ip
    Gateway IP address of the subnet. If this parameter is not specified, the first IP address in the subnet CIDR block is used.
    availability_zone
    AZ of the subnet. If this parameter is not specified, the first AZ found is used.
  5. Create a network interface subnet.
    CCE Turbo clusters use Cloud Native Network 2.0. You need to create a network interface subnet to provide a network environment for containers. If there is already a network interface subnet, you can use the eni_ipv4_subnet_id variable to specify the existing network interface subnet.
    Create the eni_subnet.tf file as follows:
    variable "eni_ipv4_subnet_id" {
      description = "Network interface subnet ID"
      type        = string
      default     = ""
    variable "eni_subnet_name" {
      description = "Name of the network interface subnet"
      type        = string
      default     = ""
      validation {
        condition     = var.eni_ipv4_subnet_id == "" || var.eni_subnet_name == ""
        error_message = "If eni_ipv4_subnet_id is not specified, eni_subnet_name must be specified."
    variable "eni_subnet_cidr" {
      description = "CIDR block of the network interface subnet"
      type        = string
      default     = ""
    # Create a network interface subnet in the specified region (if the region parameter is not specified, the region specified in the provider block is used by default). This subnet is used to provide a network environment for the Turbo cluster.
    resource "huaweicloud_vpc_subnet" "eni" {
      count = var.eni_ipv4_subnet_id == "" ? 1 : 0
      name              = var.eni_subnet_name
      cidr              = var.eni_subnet_cidr != "" ? var.eni_subnet_cidr : cidrsubnet(huaweicloud_vpc.test[0].cidr, 4, 1)
      gateway_ip        = var.eni_subnet_cidr != "" ? cidrhost(var.eni_subnet_cidr, 1) : cidrhost(cidrsubnet(huaweicloud_vpc.test[0].cidr, 4, 1), 1)
    count
    Number of resources to be created. If eni_ipv4_subnet_id is specified, the existing subnet will be used, and no new subnet will be created.
    vpc_id
    name
    cidr
    CIDR block of the network interface subnet. If this parameter is not specified, a subnet is automatically created from the VPC CIDR block.
    gateway_ip
    availability_zone
    The network interface subnet and the common VPC subnet are subnets in the same VPC, and their CIDR blocks cannot overlap.
  6. Create the cce_cluster.tf file to create a CCE cluster.
    variable "cluster_name" {
      description = "CCE cluster name"
      type        = string
      default     = ""
    variable "cluster_flavor_id" {
      description = "CCE cluster flavor ID"
      type        = string
      default     = "cce.s1.small"
    variable "cluster_version" {
      description = "CCE cluster version"
      type        = string
      default     = null
      nullable    = true
    variable "cluster_type" {
      description = "CCE cluster type"
      type        = string
      default     = "VirtualMachine"
    variable "container_network_type" {
      description = "Container network model"
      type        = string
      default     = "eni"
    variable "cluster_description" {
      description = "CCE cluster description"
      type        = string
      default     = ""
    variable "cluster_tags" {
      description = "CCE cluster tags"
      type        = map(string)
      default     = {}
    # Create a CCE cluster in the specified region (if the region parameter is not specified, the region specified in the provider block is used by default). This CCE cluster is used to deploy and manage high-performance containerized applications.
    resource "huaweicloud_cce_cluster" "test" {
      name                   = var.cluster_name
      flavor_id              = var.cluster_flavor_id
      cluster_version        = var.cluster_version
      cluster_type           = var.cluster_type
      container_network_type = var.container_network_type
      subnet_id              = var.subnet_id != "" ? var.subnet_id : huaweicloud_vpc_subnet.test[0].id
      eni_subnet_id          = var.eni_ipv4_subnet_id != "" ? var.eni_ipv4_subnet_id : huaweicloud_vpc_subnet.eni[0].ipv4_subnet_id
      description            = var.cluster_description
      tags                   = var.cluster_tags
    name
    Cluster name
    flavor_id
    Cluster flavor ID. The default value is cce.s1.small.
    cluster_version
    Cluster version. If this parameter is set to null, the default version is used.
    cluster_type
    Master node architecture. The value can be VirtualMachine (x86) or ARM64 (Kunpeng).
    Container network model. The value can be overlay_l2 (container tunnel network, used for creating standard CCE clusters), vpc-router (VPC network, used for creating standard CCE clusters), or eni (Cloud Native Network 2.0, used for creating CCE Turbo clusters).
    vpc_id
    ID of the VPC used by the cluster
    subnet_id
    ID of the subnet used by cluster nodes
    eni_subnet_id
    ID of the network interface subnet (IPv4 subnet) used by containers
    description
    Cluster description
    tags
    Cluster tags
    The container_network_type parameter determines the type of the cluster to be created and the required network resources. If you select eni, you need to create a network interface subnet. If you select overlay_l2 or vpc-router, you do not need to create a network interface subnet.
  7. Configure resource parameters. The following is an example configuration. Modify the parameters based on service requirements.
    Create the terraform.tfvars file and preset the input parameters required by the resources.
    vpc_name            = "tf_test_vpc"
    subnet_name         = "tf_test_subnet"
    eni_subnet_name     = "tf_test_eni_subnet"
    cluster_name        = "tf-test-cluster"
    cluster_description = "Created by terraform script"
    availability_zone   = "cn-north-7c" # Replace it with the actual AZ.
    cluster_tags        = {
      owner = "terraform"
Step 3: Initialize and Apply the Terraform Configuration
  1. Initialize the environment.
    terraform init
  2. View the execution plan and check whether the resource changes meet your expectation.
    terraform plan
  3. After confirming the plan, create resources. Terraform will ask for your confirmation. Enter yes to confirm the execution.
    terraform apply
  4. View the created resources.
    terraform show
Step 4: Clear Resources
This operation will permanently delete all resources (including the VPC, subnets, and CCE cluster) created by Terraform. Ensure that there is no important service data in the resources before performing this operation.
If you no longer need the resources created by Terraform, run the following command to release them:
terraform destroy
Helpful Links
